Artefacts caused by game or hardware? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2012, 10:13 AM - Thread Starter
jake51's Avatar
Quoted: 108 Post(s)
I've been wondering if things like shimmering in games are caused by the game, the hardware and/or the screen
My hardware is very capable - Intel Core i7, GTX580, 8 GB RAM - and I run games at High or higher @ 1920x1080
My screen is a 27 inch Benq
But still I see things like shimmering
Not a lot, but it's there if I look hard (now if I could just stop doing that)
Is that a limitation in the game or is it caused by hardware?
Jakob
jake51 is offline
post #2 of 3 Old 09-08-2012, 11:08 AM
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
norm that is sign of something is over heating unless the game is coded badly . If the vid card is OC'd then that could cause the probm. Also it could be the vid driver ver you ae using. You can try diff drivers and see. Just a guess.
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
post #3 of 3 Old 09-09-2012, 01:28 PM
darklordjames's Avatar
Liked: 94
Depends on what you mean by "shimmering". That would be a common way to refer to aliasing, in which case you would want to look in to anti-aliasing methods to apply.
darklordjames is offline
Reply HTPC Gaming
