first HTPC plus gaming build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-14-2012, 09:21 AM - Thread Starter
TheSorc's Avatar
Hi all,
first post (hope this is in the right sub forum)
I am about to build a HTPC and have put together some components and was wandering if you guys could give me some suggestions as to what needs to be changed (if any)
What I want:
1) HTPC for living room (on 1080p TV)
- TV via TV tuner card (with recording etc.)
- Youtube, video on demand, Twitch etc.
- DVD and Blue-Ray
2) Light Gaming with friends in the living room with "reasonable" but not great graphics(e.g. Blur, Audiosurf, LIMBO, Trine 2, Street fighter 4, that kind of thing) I have a dedicated Work/Gaming machine but like the idea of casual gaming on my sofa (console-style)
3) lowish noise but certainly does not need to be silent. I would quite like low power usage as I will use the PC for TV recording etc and he will likely stay on for extended periods of time)
4) upgrade capabilities if I ever want to go 3D or more intense gaming.
My current (planned) build is
MOBA: Asrock H77M
Has USB 3 at front and back, HDMI out, 2xPCI and 2xPCIe for TV card and Wireless card and dolby surround sound (otherwise standard MOBA stuff)
Processor: (really not sure) options:
a)i3-2125 (relatively "future proof" in terms of processor power and should be able to handle simple games graphics. I think I will need discreet graphics if I want to play more demanding games. If I go that route then the graphics part )
b) G620 Pentium (should still be able to handle HTPC video stuff but not able to really play games without discreet graphics
c) scrap Intel and go with Llano?
Graphics: no discrete graphics planned atm but I would like to have the option to upgrade at a later stage
RAM:
Corsair DIMM 8 GB DDR3-1600 Kit (ram is cheap)
storage:
I already have a 60gig SSD for the OS and some mass storage for media
Power supply: not sure what to get but would probably go with something that has good reviews on Newegg
Maybe: Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
case:
Silverstone GD05B USB 3.0 Grandia HTPC Black Micro ATX Case
TV card:
Not sure what to get
DVD/Blue-ray:
LG CH10LS28
OS:
I have a copy of Win7 Home Premium
I guess my biggest problem is deciding on a processor (+- graphics). I like the idea of an SB/IB 1155 system as my main PC is still running an old core-i5 750 and I could easily upgrade the HTPC to use as a main PC when the i5 gives up one day.
Any ideas are welcome.
TheSorc is offline
post #2 of 3 Old 09-15-2012, 06:34 AM
number1laing's Avatar
Liked: 32
I don't think the i3-2125 gpu is that capable, especially at 1080p. I'd pair it with a cheap GPU as well, or yea, go with AMD.
number1laing is offline
post #3 of 3 Old 09-16-2012, 12:31 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
How about an HD 7770 at around $100? It will let you do basic gaming. GTX 660 or HD 7870 would be a whole next level above that.
On the cheap, go with Llano, but if you upgrade graphics later you are more likely to be processor limited.
lespurgeon is offline
Reply HTPC Gaming
