Help! Messed up System Colors (especially noticeable in darker shades). - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-26-2012, 12:13 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I have an hd6950. I've recently started noticing innacurate shades in darker areas of games and movies, almost as if the entire pc is running 8 bit colors (i've already checked to make sure this isn't the case).
I think it started when i unlocked the desktop color portion of the amd control panel to see if i could lower red saturation. I played around with gamma a bit while i was there but i reverted it to defaults.
Nothing else was adjusted and everything is set to default.
It is most noticeable in dark games and dark scenes of movies where dark areas look washed out and don't have gradation detail as they should.
I've tried reinstalling videocard drivers after uninstalling them with no luck.
I am using a hitachi 51uwx20b crt rear projection over an hdmi connection from the videocard to a dvi converter into the tv.
Any help is greatly appreciated.
Mik James is offline
post #2 of 4 Old 09-26-2012, 08:59 PM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
If you're using the ATI catalyst drivers. Check a couple places in the drivers. I've never messed with the color options before so I've never run into this issue. But there are a couple places that have color adjustments. There's color in the desktop management, video, and my flat panel tabs. Also check for presets, maybe one was setup and it's being used.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #3 of 4 Old 09-26-2012, 09:26 PM
darklordjames's Avatar
Liked: 94
Do you have anything else HDMI/DVI to hook up to the display? I wouldn't be surprised if the issue was in the CRT's video DACs instead of on the video card side. Also, of the display offers VGA in, that is likely a better input option. DVI/HDMI inputs on analog displays were almost universally bad.
darklordjames is offline
post #4 of 4 Old 09-28-2012, 11:14 AM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Turns out it was a driver issue, fixed after rolling back.
No vga on this tv and im not even sure if the dvi is analog or digital.
Reply HTPC Gaming
