CPU Motherboard question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-10-2012, 09:10 AM - Thread Starter
mjfoster77's Avatar
SO I have a older mother board and a older cpu. I have a Intel Core 2 Duo E6750 Dual-Core Processor, 2.66 GHZ, 4M L2 Cache, 1333MHz FSB, LGA775
Tray, and a eVGA nForce 680i SLI Motherboard 122-CK-NF68. I have evga 550 ti video cards in sli. Would it be better to A) try and overclock my cpu, or B) buy a better lga 775 cpu, say a quad core cpu. Or should I sell what I have and get a new mobo and cpu.
xbox live:sixsec assassin
mjfoster77 is offline
post #2 of 8 Old 10-10-2012, 09:31 AM - Thread Starter
mjfoster77's Avatar
The pc is used for playing games
post #3 of 8 Old 10-12-2012, 03:02 PM
darklordjames's Avatar
Liked: 94
775 is pretty hard to find good chips for these days. Move to an LGA1155 board or an AM3+ board and look at getting a new CPU. Are you on DDR3, or was 775 still running DDR2? If you are getting new ram also, spent $80 and pick up 16GB. 8GB is barely scraping by these days.
darklordjames is offline
post #4 of 8 Old 10-15-2012, 08:09 PM
gullzway's Avatar
I have the same board on my Dell desktop. I just upgraded the core 2 Duo E6320 (1.8 ghz) to a Q6600 Quad 2.4 (Overclocked to 2.6 ghz) that I bought on ebay for $65.
That along with a Radeon 7750 has taken Battlefield 3 from Unplayable even at low settings, to Playing Flawless on High settings.
gullzway is offline
post #5 of 8 Old 12-10-2012, 06:49 AM - Thread Starter
mjfoster77's Avatar
Ok so I bit the bullet and I order new stuff for my HTPC. Here is the list: Intel 3570k, evga gtx 660 ti 3gb, 16gb G. Skill ripjaws, ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA. and a Cooler Master Hyper 212 Plus. Do any of you guys own any of these, hoping this will last awhile for me.
post #6 of 8 Old 12-10-2012, 09:20 AM
confidenceman's Avatar
Liked: 37
I just got a very similar setup: 3570K, 2x4GB G.Skill Ripjaws @1600, Biostar TZ77B, AMD HD7870, and the Hyper 212. I was able to get my 3570K up to 4.3Ghz pretty comfortably. Temps and voltages are stable after a week. I could tweak more and push it further, but it would take a lot more tinkering with not much more juice. Most folks seem to hover around 4.3-4.5Ghz with these chips. I wasn't able to OC my GPU very far (1150Mhz), but I was also more reticent to push it since I don't feel comfortable cranking up the voltages without more cooling going on.
In any event, I figure I won't have to do much more than upgrade the GPU in a year or two. I purposely chose a more modest GPU knowing that I would replace it down the line and be able to "leapfrog" up a couple of steps more affordably. Yours may get another six months than mine.
PSN & XBL ID: drop me a private message
confidenceman is offline
post #7 of 8 Old 12-10-2012, 11:06 AM - Thread Starter
mjfoster77's Avatar
Thanks for the reply. How do you like cpu cooler? I was gonna go stock, but was talked into upgrading. Why not at this point right. The stuff will be put together on wed. Can't wait.
post #8 of 8 Old 12-10-2012, 12:10 PM
Liked: 37
Cooler seems fine. Not too loud. I get more noise from my case's intake fan. Relatively easy to install. Seems a no-brainer for the price.
My CPU is generally in the 1.2-1.3 range for voltage and doesn't get any hotter than 60C according to HWMonitor and idles right around 30C. I tried knocking the voltage down, but it didn't like it. I figure as long as temps are okay, it should be fine. OC-ing took some fiddling, but it will depend on your motherboard and BIOS options. As long as you take things slowly and deliberately, and you find the right guides and software tools, all should be well. If you haven't done it before, the basic concept for overclocking is to eke out more speed while keeping voltage as low as possible (in order to keep temps low). Be ready to reset your BIOS using the jumpers on your motherboard. A lot of trial and error and testing.
The big difference between the 2500K and the 3570K is that the old 2500 seemed to take whatever you threw at it. The 3570K seems a bit finickier. But just be patient. As I said, I gave up at around 4.3Ghz. I could squeeze more I'm sure, but it was getting a lot harder to find stable settings at 4.4/4.5. And these things also depend on other things too (your PSU, your case temps, your heatsink contact, the idiosyncrasies of your CPU, etc). Since I got reliable and safe results from 4.3, I just left it there. All told, it took maybe 3-4 hours of troubleshooting/testing/tweaking.
Reply HTPC Gaming
