hooking mupltiple monitor up and need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-07-2012, 09:03 AM - Thread Starter
killa2009's Avatar
I currently have a gtx 550 and i plan on buying another. i want to be able to hook up multiple hdtv or led tv.
1. so my question is, do i need to have the same version led tv or can i have a vizio and sony.
2. Also does the tv have to be the same size? i only ask because i wanted to know if i could do a quick test.
3. can i use multiple led tvs and connect a cable box?
thanks for help
killa2009 is offline
Reply HTPC Gaming
