Is center channel needed for gaming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-08-2012, 12:58 AM - Thread Starter
mike kaw's Avatar
Is it okay to run a 4.1 setup with no center for a gaming htpc? My pc mostly for gaming and some music.
My current setup is a pair of polk tsi 100 and 2 tl2s as rears. The 2 front speakers are 2 feet a part. I was thinking of getting a polk c10 center channel later on but don't think i can get it to fit between my keyboard and monitor. Instead, I might get a tl2 center and pair it with the tsi 100. i know its not a good idea to pair a different center with the fronts but i do not have the space.
Is this a good idea or should i just stick with a 4.1 setup?
mike kaw is offline
post #2 of 4 Old 11-08-2012, 09:30 AM
DaveFi's Avatar
Quoted: 174 Post(s)
Liked: 66
DirectSound will support as many speakers as you have. You don't necessarily need a center speaker on any configuration, but if you have the space why not add a center?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is online now
post #3 of 4 Old 11-08-2012, 07:23 PM - Thread Starter
mike kaw's Avatar
i can only fit small sats on my desk. So its not necessary, well my concern is loosing surround sound in games. Is the center channel really important in gaming?
I want to make sure I can still hear people sneaking up behind me in bf3.
mike kaw is offline
post #4 of 4 Old 11-09-2012, 09:24 AM
Yrd
Yrd's Avatar
Quoted: 654 Post(s)
Liked: 460
As long as your sound card supports multiple speakers, you can set whatever options it has listed. If you set it to 4 speaker setup it's going to map the center channel to the two front speakers.
If you set it to 5 you're going to hear people sneaking up on you all day, but you'll hear none of the dialogue and whatever else would be sent to a center channel.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
Reply HTPC Gaming
