pv gaming monitor help. APPLE - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 01-10-2013, 12:24 PM - Thread Starter
LOA5000's Avatar
what setting are you using for picture settings?
LOA5000 is offline
post #32 of 40 Old 01-10-2013, 02:13 PM
jhoff80's Avatar
Quoted: 383 Post(s)
Liked: 340
I'm using the settings on this post:
http://www.overclock.net/t/1257538/microcenter-now-carrying-the-27-2560x1440-korean-ips-monitors/250#post_17389912
The second color profile, with the settings:
Have Eco on Standard, Brightness 80, Contrast 50, DCR OFF, and '6500k' white point color setting.
I created a profile using this method, and it is attached below. To use it you must match the above settings mentioned (from a factory reset) in addition to changing the color temp from 6500k to 'USER'. Then set your color values to the following:
RED 100
GREEN 85
BLUE 73
Again, leaving DCR OFF and ECO STANDARD with default Brightness/Contrast.
Although you might want to try this for lower brightness:
http://www.overclock.net/t/1257538/microcenter-now-carrying-the-27-2560x1440-korean-ips-monitors/360#post_18170097
XBL/Steam: JHoff80
jhoff80 is online now
post #33 of 40 Old 01-11-2013, 09:33 PM
headcase151's Avatar
Quoted: 16 Post(s)
I got the Microcenter Auria.The first one had 3 dead pixels.I returned it when they got more stock.No dead pixels,no back light bleediing.I use the display port 1.2,and i can get sound thru the speakers.The stand is a little wopply.So i got a monitor arm,works great.
headcase151 is offline
post #34 of 40 Old 01-12-2013, 03:26 AM - Thread Starter
LOA5000's Avatar
I think I like game mode on and user mode with 100%. I tried the setting he's got and it dosent look as nice as my old gate way. The gate way monitor really has an amazing picture. This monitor is nice to tho I like it its a little bigger and has the better ressulution. With the ips and the led I thought it would have a better picture
LOA5000 is offline
post #35 of 40 Old 01-12-2013, 10:35 PM
Yrd
Yrd's Avatar
Quoted: 557 Post(s)
Liked: 414
I have a strong urge not to ever click that link, I don't know why.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #36 of 40 Old 01-13-2013, 01:07 AM - Thread Starter
LOA5000's Avatar
I founf one dead pixel on the rite side of my monitor it only shows on the white black test and like one other. On green red and blue it blinks off
LOA5000 is offline
post #37 of 40 Old 01-13-2013, 07:40 AM
Alfred Wirsle's Avatar
do some research! have a look around and make sure your really happy with what you choose.
As far as gaming go, its really hard to go past benq panels. One of the few brands that specifically design everything about their monitor for gamers. In particular this one, http://gaming-monitors.com/products/benq-xl2420t-professional-gaming-monitor/, is the best of the best right now for gaming.
If your looking for CAD/gfx work you prolly want one focusing on colours and max size. But for games = benq.
Alfred Wirsle is offline
post #38 of 40 Old 01-13-2013, 11:12 AM
Yrd
Yrd's Avatar
Quoted: 557 Post(s)
Liked: 414
Problem with the Benq monitors, for me, is they only use TN panels. 1080p is the max, besides the other downsides. But they have fantastic refresh rates, if thats what you want.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #39 of 40 Old 01-13-2013, 11:08 PM - Thread Starter
LOA5000's Avatar
Yeah screw that. Id be better with my gateway. I am thinking of exchanging this one or getting the Asus ips 27 led 2560x1440 5ms
LOA5000 is offline
post #40 of 40 Old 01-14-2013, 10:55 AM
Yrd
Yrd's Avatar
Quoted: 557 Post(s)
Liked: 414
Why do you not like the new monitor? I've been considering the Asus myself. But it just has too many cons in reviews that I'm not sure I can settle for. LED does not make a better picture. The only benefit to LED is smaller size and less power consumption.
We need cheap OLED monitors already.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
Reply HTPC Gaming
