How should I increase the size of my OS drive: SSD 128gig - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-06-2013, 10:54 PM - Thread Starter
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4168
Hey guys. Some of you are familiar with my new build.
http://www.avsforum.com/t/1428975/well-i-took-the-plunge-and-ordered-gear-for-my-new-htpc
So far, I have little to complain about. Thing runs games maxed out at very playable framerates. The 3tb harddrive holds every game I own on it with room to spare. My OCZ Vertex4 SSD is awesome but I am now finding myself hitting the limits of its capacity. 128gigs only goes so far. I'd like to increase the size to something like 256-512gigs. Probably 256 as the prices are more reasonable to me.
What I'd like to do is clone the drive to a larger capacity so I can simply swap the drive in and not have to do anything. The though occurred to me though: how do I do it? I have well over a terabyte of games on my 3tb HDD but almost all of them have been 'moved' using Steam Mover. I would assume that if I were to 'clone' the SSD it would think that all that content is actually on the SSD when it isn't. This would be a HUGE problem for me. Having to re-download all those games is a huge waste of time and a lot of trouble, even if it doesn't sound like a big deal. I also figure that if I were to do a clean Win7 install, which doesn't sound all that bad, would be a pretty big pain in the ass because all those games have junction points on the SSD with the OS.
Is adding a second 128gig and going with RAID0 going to work? To me, that would require blanking the original 128 too.
Ugh.
What do I do?
Scott Simonian is offline
post #2 of 11 Old 01-06-2013, 11:01 PM - Thread Starter
Bass Enabler
Liked: 4168
Actually..... I had another thought.
Would it just be easier to add another SSD of whatever size and just use Steam Mover to move over games to that new drive (with no OS) that I want played off an SSD? Maybe that would be easier. Yay, nay?
post #3 of 11 Old 01-06-2013, 11:16 PM
mekret's Avatar
This is pretty much what I do. 2 Vertex 4's; 1 for OS and programs, other for games.
mekret is offline
post #4 of 11 Old 01-06-2013, 11:31 PM
Nolij's Avatar
thats what i would do too. i have a corsair gt 180gb and it is very fast. I too am hitting the limits of at least how far i want to occupy the drive. am i also looking at getting another ssd for games and maybe a cache for a lot of the adobe work i do, though im not too sure that would work well since adobe caching likes spinning drives. tried with PS and not much a difference. nice build specs by the way.
Nolij is offline
post #5 of 11 Old 01-06-2013, 11:38 PM
mekret's Avatar
Also, why not just "move" back the games you aren't playing or that you rarely play?
mekret is offline
post #6 of 11 Old 01-07-2013, 12:10 AM - Thread Starter
Bass Enabler
Liked: 4168
Cool. So I think I'll just do that because it's easier and works out the same in the long run.
Why? Because there is a terabyte worth of them and I'm not going to subject myself to all that work. tongue.gif
post #7 of 11 Old 01-07-2013, 01:39 AM
darklordjames's Avatar
Liked: 94
Samsung 840 500GB is $350 on Amazon. It's actually cheaper per gig than the 250GB version. Read speeds are fantastic. There are faster writes out there on other drives, but that doesn't really matter on a Steam drive.
Keep in mind that SSDs really like to be able to run TRIM, and TRIM really likes to have 25% of the drive free. Once you drop below 25% free space performance takes a crap real quick on all our fancy SSDs. Luckily, the controller on our drives doesn't care where that free space is located, so just don't put it in a partition in the first place.. smile.gif My 128GB drive is running a 100GB partition so that I can never leave too little free space. A 250GB drive should run a 200GB partition and 400GB partition on a 500GB drive.
The short of it is this: Leaving a good chunk of free space lets the SSD do cleanup in its spare time at its leisure. Low space on an SSD makes cleanup an emergency whenever you need to write something, meaning far more read activity at the time of writes, slowing everything down. Drives already have 5-10% set aside that you never see, so as a user we need to set aside that extra 15-20%.
darklordjames is offline
post #8 of 11 Old 01-07-2013, 02:11 AM - Thread Starter
Bass Enabler
Liked: 4168
I know what you're saying, James. As just this past week having a couple very large games (>25gigs) on it got my SSD nearly clogged up. Just like HDD's I've owned it got all slow like when ~75% full.
I'm not hearing good things about the non-pro 840's though so I don't think I'll be throwing $350 that way when right now I don't really even want to spend much over $200 for a 256gig I know I'll like. Just my opinion, feel free to ignore it.
post #9 of 11 Old 01-07-2013, 08:46 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
I'm not sure what you're having trouble with. If you clone the drive, nothing will change except the hardware. All the links will still be the same.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #10 of 11 Old 01-07-2013, 10:05 AM - Thread Starter
Bass Enabler
Liked: 4168
That's what I would like to think but some programs don't work well with the junctions. JDiskReport will show that I have well over a terabyte of content on my 128gig SSD which is physically impossible. tongue.gif
post #11 of 11 Old 01-13-2013, 02:28 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
I've done this plenty of times with Acronis. Never an issue.
almostinsane is offline
Reply HTPC Gaming
