Shield - nVidia's Android-based, PC game streaming handheld - AVS Forum | Home Theater Discussions And Reviews
post #1 of 76 Old 01-07-2013, 08:00 AM - Thread Starter
joeblow's Avatar
Liked: 233
The Tegra 4 based Shield is available now for $300.
Shield tech specs (Click to show)
Hardware
Form Factor
Flip
Length
5.31 inches
Width
6.22 inches
Thickness
2.24 inches
Weight
1.28 pounds
Color
Black
Primary orientation
Landscape
Sensors
Accelerometer, Gyroscope
Display
Screen size (diagonal)
5 inches
Technology
LCD
Touchscreen type
Capacitive
Performance
CPU brand
Nvidia
CPU model
Tegra 4
Cores
4
RAM
2 GB
Input
Control
D-Pad, Shoulder buttons
Analog stick(s)
2
Connectivity
Wi-Fi
Yes
Wi-Fi support
802.11n, 802.11g, 802.11b
GPS
Yes
Bluetooth
Yes
Bluetooth version
3.0
Audio
Speaker(s)
Stereo
Built-in mic
Yes
Storage
Internal storage
16 GB
External storage
Yes
Supported memory cards
microSD
Software
Game media type
Internal / Downloads
Online store
Yes
Notable apps
Tegra Zone
Ports
Video out
Yes
Headphone jack
3.5mm
Data connections
Micro USB
Power
Capacity
28.8 Wh
Product info snipped from the official FAQ:
What Android games does SHIELD work with?
As SHIELD is a full-featured Android device with a multi-touch screen and access to the Google Play store, gamers can access and play an extensive catalog of Android games on SHIELD. Games optimized for gamepads and 5" landscape displays are going to provide the best gaming experience. Check out the list of SHIELD optimized games available from TegraZone. Beyond the many great titles available through TegraZone, There are a number of other games available on Google Play that offer native controller support. Check out a list of tested Android games.
What are the system requirements for streaming pc games to SHIELD?
The basic requirements are a Wi-Fi router and a modern gaming PC with a GeForce GTX 650 or higher desktop GPU.
The detailed requirements are:
• GPU: GeForce GTX 650 or higher desktop GPU (Notebook GPUs are not supported at this time)
• CPU: Intel Core i3-2100 3.1GHz or AMD Athlon II X4 630 2.8GHz or higher
• System Memory: 4GB or higher
• OS: Windows 8 or Windows 7
• Software: GeForce Experience application and latest GeForce drivers
• Routers: 802.11a/g router (minimum). 802.11n dual band router (recommended). Check out a list of recommended routers.
How does streaming games from my PC to SHIELD work?
NVIDIA uses the H.264 encoder built into GeForce GTX 650 or higher desktop GPUs along with special streaming software integrated into GeForce experience to stream games from the PC to SHIELD over the user's home Wi-fi network with ultra-low latency. Gamers use SHIELD as the controller and display for their favorite PC games as well as for steam big picture. This enables gamers to get a GeForce GTX PC gaming experience anywhere in their home Wi-fi network.
What PC games does SHIELD work with?
For beta we are supporting a select number of Steam games as well as enabling access to Steam Big Picture. Check out the complete list of supported PC games.
PC game streaming is in beta – What does that mean?
The PC streaming beta features a select number of supported games from Steam, access to Steam Big Picture, and a set of recommended routers. After conclusion of the beta period, users will receive a free software update to the official release that includes expanded game support, broader wi-fi compatibility, feature enhancements, and any needed bug fixes based on beta feedback.
What buttons are on the SHIELD controller?
SHIELD provides a full console-grade controller with two joysticks, a D-pad, ABXY buttons, L/R bumpers, L/R analog triggers, Start/Back/Home/Volume buttons, and a multi-function NVIDIA/Power button.
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #2 of 76 Old 01-07-2013, 08:08 AM
Yrd
Yrd's Avatar
Quoted: 659 Post(s)
Liked: 462
I saw it on Engadget and they described it as being like a Dualshock 3. Their picture was horrible contrast black on really dark so you couldn't see it. Now that I see it, it's nothing like a dualshock, except the thumbsticks being in the same orientation.
They said you can play your steam games located on your PC on this device, although I'm not sure why you would want to. Only if it can be done while you're not in your home. I guess it would be a nice way to bring you PC games mobile.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #3 of 76 Old 01-07-2013, 09:03 AM - Thread Starter
joeblow's Avatar
Liked: 233
Haha, it'll be hilarious if this thing allows Steam's Big Picture mode to work so you can play all your compatable games seeing how Valve's Seambox will be announced soon.
joeblow is offline
post #4 of 76 Old 01-07-2013, 09:30 AM
Yrd
Yrd's Avatar
Quoted: 659 Post(s)
Liked: 462
That's exactly what it's supposed to do.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #5 of 76 Old 01-07-2013, 10:26 AM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
Apparently, to play on your TV in the living room, it streams directly from the PC to the wireless receiver connected to your TV, and the Shield itself is just used as a controller connected to the PC. With that being the case, I really just don't see the point for this thing. I mean, it's gotten people talking about it and the Tegra 4, so that's a huge win for Nvidia in itself, but other than that, I don't know.
http://www.anandtech.com/show/6550/more-details-on-nvidias-tegra-4-i500-5th-core-is-a15-28nm-hpm-ue-category-3-lte
XBL/Steam: JHoff80
jhoff80 is online now
post #6 of 76 Old 01-07-2013, 10:36 AM - Thread Starter
joeblow's Avatar
Liked: 233
Interesting. In theory the unit would not become obsolete as PC tech requirements increase because it isn't handling the graphics or the processing.
Also, as internet speeds improve, you would be able to access your gaming library and play them at wifi hotspots outside of the house, and then maybe one day with a 7G cellular connection to play almost anywhere. Just a theory of course.
Hopefully they don't require that your PC has an nVidia GPU like PhysX and 3D Vision..
joeblow is offline
post #7 of 76 Old 01-07-2013, 10:48 AM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
Also, as internet speeds improve, you would be able to access your gaming library and play them at wifi hotspots outside of the house, and then maybe pne day with a 7G cellular connection to play almost anywhere. Just a theory of course.
They do. You need a Kepler or better Geforce so that it can use that chip's encoding engine to encode the video on the fly.
XBL/Steam: JHoff80
post #8 of 76 Old 01-07-2013, 04:32 PM
nathanddrews's Avatar
Quoted: 422 Post(s)
Liked: 356
From AT:
http://www.anandtech.com/show/6564/hands-on-with-nvidias-project-shield-
Anand and I just spent some time playing with NVIDIA's recently announced Project Shield, which is NVIDIA's portable handheld gaming device home to the also just-announced Tegra 4 SoC (4x ARM Cortex A15). I came away pretty impressed with Project Shield ergonomics after initially going in very skeptical (like GPU editor Ryan Smith) about how 38 watt-hours of batteries, a display, Tegra 4, and all the accompanying hardware could possibly feel comfortable stuffed into what boils down to a game controller.
First off, Shield isn't nearly as heavy as I thought it would feel in the hands. I expected Shield to feel very dense, instead the device doesn't feel much different from a wireless Xbox 360 controller with the rechargeable battery pack. I made a point of holding onto the Shield the entire time in a few different positions and didn't feel my hands or arms fatiguing at all. NVIDIA carefully positioned the batteries right around the palm areas, so the heaviest parts of the device are right in-axis with ones palms and arms rather than being elsewhere that would torque one's grip. There's something about the construction that feels balanced and masks the fact that this is actually a sizeable piece of hardware. Shield will have a soft touch bottom and different top texture finish, this first version we played with did not.
NVIDIA was eager to point out that both the D-Pad, triggers, and bumpers are all in the process of being tweaked and tuned, and that the spring preloads and click points on the Shields we played with were nowhere near final. This is good to hear as the D-Pad at present definitely needed to be less mushy and more communicative, we're told this will be replaced with a much more responsive one before Shield is finalized. I didn't have a problem with the analog sticks but would love to feel alignment nubs or texture on the domes.
My biggest thoughts were framed around the placement of the two analog sticks, which at present is places the tops of them in the plane of the buttons and D-Pad. This initially felt very alien, until I realized this is done because the display needs to close shut (the analog sticks would otherwise protrude through the screen) but felt a little bit awkward. I'm used to the 360 controller personally, which has analog sticks that protrude above the plane of the buttons. I can see one getting used to this as it feeling awkward is simply an artifact of my prior exposure and trained response to the 360 controller.
The 720p 5-inch "retinal" display indeed exceeded my visual acuity and was hard to pick out individual pixels on, though I still think there's too much bezel on Shield that should be taken up with more display. Something like a 5.5" 1080p display would make much more sense, but that's probably reserved for another iteration. The biggest concern is how smaller features on PC games played back on the Shield would be difficult to pick out. NVIDIA claims it will mitigate this by working with game developers on appropriate titles or offering a pinch to zoom feature to let users read small elements. Obviously some games with lots of text (they offered the example of EVE Online) can't possibly work perfectly, but I had no problems playing a few levels of Assassins Creed 3 and Black Ops 2 on Shield. I could see some H.264 artifacts while playing on Shield, higher bitrates could solve that problem easily.
Wireless connectivity on the Shield is courtesy Broadcom's latest BCM43241 which is 2x2:2 802.11a/b/g/n, which is the right thing to do in a platform that so strongly leverages wireless display and control. Responsivity while playing PC games on the Shield was extremely good, I couldn't detect any lag.
At the front of the Shield is a small gap and grille, it turns out that heatsink in the NVIDIA press event video was in fact real, as air is drawn from the front of the Shield, over the heatsink, and exhausted out the back. There is indeed a fan inside, albeit a small one. NVIDIA says it won't come on all the time during normal use, and after playing a few Android games natively (Hawken) on the device this seemed to be the case. One Shield left in the sun did have the fans kick on though, which are essentially inaudible. I didn't actually feel Shield get hot at all during use, but that heatsink wasn't just for show in the press event video/demo, it's real.
At the very back are the microSD, microHDMI, microUSB, and headphone jack. I'm told these are also changing slightly and would honestly like to see the headphone jack come around to the front.
What really struck me about the Shield was how very far from ergonomic the device appears, and yet how surprisingly comfortable it is to hold. NVIDIA nailed the underside ergonomics almost perfectly, there's a small ledge for your fingers to rest on, and the palm cups are indeed reminiscent of the 360 controller.
Android 4.2.1 on the Shield felt extremely responsive and fluid. I am very impressed with browser scrolling in both Chrome and Browser.apk, the latter of which is now a huge optimization target for NVIDIA. The rest of the UI was also very fluid. I should note that NVIDIA is not allowing benchmarking at present, so we can't say anything but just subjective impressions about Tegra 4 performance.
We recorded a video of gameplay on the Shield and are uploading it as fast as CES connectivity will afford.
nathanddrews is offline
post #9 of 76 Old 01-07-2013, 04:51 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5036
Aaannnnndd the position of the joysticks ruins the whole thing for me. frown.gif
Scott Simonian is offline
post #10 of 76 Old 01-08-2013, 07:26 AM
Quoted: 422 Post(s)
Liked: 356
Please forgive me if this is unreasonable or out of line, but "don't knock it 'til you try it". wink.gif I shed a couple tears the first time I was unable to replace my original Xbox "Duke" controller, but over time I got used to the S. Gam zeh yaavor.
Personally, I think it looks pretty cool, but I'll probably never buy it as I already can game on my TV via my computer with a controller or m+k. The draw for me is limited.
post #11 of 76 Old 01-08-2013, 08:02 AM
Bass Enabler
Liked: 5036
I tried it about a decade ago when it was the Playstation 2 controller. *shudders* Nnnnoooo thank you.
Trust me, I had a hard time moving away from the duke to the "s" controller way back but at least the joysticks were in the same position and they still are today with the current 360 controller. That's the only comfortable layout for me. The "I have fingers an inch long" joysticks from all the Playstation controllers.... I.... I just can't do it. It's uncomfortable, it's unwieldy and I just can use them.
post #12 of 76 Old 01-08-2013, 08:41 AM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
Man, that D-pad on there looks absolutely horrible.
Anthony1 is offline
post #13 of 76 Old 01-08-2013, 09:48 AM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
I have no interest in this thing at all myself, but I do wonder if part of the reason they used this layout is because they expect most Android games won't have analog joystick support, and will instead use the D-pad.
XBL/Steam: JHoff80
post #14 of 76 Old 01-08-2013, 10:13 AM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
What is your guess on how much this thing is going to cost ?
Anthony1 is offline
post #15 of 76 Old 01-08-2013, 10:40 AM
Quoted: 422 Post(s)
Liked: 356
10" Android tablets with the latest hardware are generally $400-500 (excluding models with 64GB+ storage or cellular contracts). 7" versions are usually $300-400. I would expect this device to fall at or below $300. But then this is NVIDIA, so $999.99. rolleyes.gif
post #16 of 76 Old 01-08-2013, 11:00 AM
Bass Enabler
Liked: 5036
Lol! That sounds true. I vote ~$500 cuz I can't see it selling at all if it's any more than that.
nathanddrews likes this.
post #17 of 76 Old 01-08-2013, 12:21 PM
Quoted: 422 Post(s)
Liked: 356
Yeah, they can't really go too high. Next-gen consoles are on the way and will be $400, most likely. All the Shield does is play Android games or wirelessly interact with your already-expensive gaming rig. In reality, it's a WiiU for your PC. It doesn't actually play its own exclusive content (TWIMTBP notwithstanding). It's a pretty hard sell if it costs more than a next-gen console.
This is probably what NVIDIA thinks is its secret weapon: GRID
http://www.nvidia.com/object/cloud-gaming.html
NVIDIA, like everyone else, watched and waited on the sidelines while OnLive suffered and died just to introduce its own cloud gaming service.
post #18 of 76 Old 01-08-2013, 12:32 PM
Yrd
Yrd's Avatar
Quoted: 659 Post(s)
Liked: 462
Said it won't be sold at a loss, so whatever cost of parts, plus a little markup.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #19 of 76 Old 01-08-2013, 09:02 PM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
I have a feeling it's going to be like $399.99 or something crazy like that, which is a bit crazy because the new Xbox is coming this November for the same price.
Anthony1 is offline
post #20 of 76 Old 01-09-2013, 05:18 AM
DaverJ's Avatar
Quoted: 1324 Post(s)
Liked: 3722
...If the rumors are true. Nothing has been announced about a new Xbox yet.
DaverJ is online now
post #21 of 76 Old 01-09-2013, 06:16 AM
Quoted: 422 Post(s)
Liked: 356
Nothing official. It's the same thing every time - the Internet pattern hasn't changed since late 90s. Rumors and leaks from manufacturers/employees ramp up. The company "doesn't comment" on rumors. New device is announed at a show. I'm actually surprised the 360 has lasted this long - EIGHT years!
Chances are that Microsoft is going to continue its subsidized pricing model and offer the console for less with a Live subscription. $400 on its own or $300 with Live @ $8/mo for 2 years. Cellular companies are making a killing, why not consoles?
post #22 of 76 Old 02-05-2013, 02:37 AM - Thread Starter
joeblow's Avatar
Liked: 233
BL2 demo on the new unit:
joeblow is offline
post #23 of 76 Old 02-05-2013, 08:54 AM
Trogdor2010's Avatar
Youtube video's apparently aren't working on avsforums. Try the direct link.
http://www.youtube.com/watch?v=UF7V3h24w38
nathandrews
It would be more like a $100-$200 console with a $20-$40 monthly price for 2 years. Cell phones make a killing because of the low entry level contract prices. By themselves what is a $600 cell phone costs $100 with a contract. If the consoles somehow cost above $500, I guarantee you they will go with subsidized pricing.
Trogdor2010 is offline
post #24 of 76 Old 02-05-2013, 09:48 AM - Thread Starter
joeblow's Avatar
Liked: 233
Sorry about that; the post above has been fixed.
joeblow is offline
post #25 of 76 Old 02-05-2013, 12:25 PM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
look at how close that guys thumbs are to each other (in the video 3 posts above). How did that design make it that far ?
Anthony1 is offline
post #26 of 76 Old 02-05-2013, 02:01 PM - Thread Starter
joeblow's Avatar
Liked: 233
joeblow is offline
post #27 of 76 Old 05-14-2013, 11:50 AM - Thread Starter
joeblow's Avatar
Liked: 233
Shield can be yours for $350. Pre orders start May 20 for a June 2013 release:
In January at CES 2013, NVIDIA surprised the crowd at its press conference with the reveal of Project SHIELD, an Android portable game console that could also stream Windows PC games on Steam. Today, NVIDIA revealed that the console has had a slight name change; it will now be called just SHIELD and it will be priced at $349.
NVIDIA's blog states that pre-orders for SHIELD will begin on May 20th to the general public but people who signed up to receive updates on the console's website have been given a way to start their pre-orders right now. The console will go on sale in June (no specific date yet) and will be available via several retailers, including Newegg, GameStop, Micro Center and Canada Computers.
The SHIELD console will be the first to have NVIDIA's Tegra 4 mobile processor with four CPU cores, 72 GPU cores and 2 GB of RAM. The console itself has a five-inch 720p display that's connected to a full sized game controller with dual analog joysticks, a full D-Pad, "left and right analog triggers, full-sized bumpers and A/B/X/Y buttons."
There's also 16 GB of storage, the latest version of the Android OS, a microSD slot, a mini-HDMI port, a micro-USB 2.0 port, support for WiFi and Bluetooth wireless and integrated speakers. The Steam game streaming support will be released in a beta version when the SHIELD console goes on sale and will require that the Steam PC to which the console connects has at least a NVIDIA GeForce GTX 650 desktop GPU or higher, along with either Windows 7 or Windows 8.
joeblow is offline
post #28 of 76 Old 05-15-2013, 03:05 PM
LexInVA's Avatar
Quoted: 676 Post(s)
Liked: 280
If I could get it without the display for $250, I'd be sold instantly but I'm not too big on the clunky design with that 720p display attached to it. Otherwise, I'm looking forward to it and will give it a test drive when I can.
LexInVA is offline
post #29 of 76 Old 05-17-2013, 09:26 AM
number1laing's Avatar
Liked: 32
I kind of want one of these. But, you know, one that is well-designed and not ridiculously ugly.
number1laing is offline
post #30 of 76 Old 05-17-2013, 10:11 AM
Liked: 786
$350 for a handheld? Seriously? LOL.
slowbiscuit is offline
Reply HTPC Gaming
