List of games with discrete 7.1 support. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 01-27-2013, 02:46 AM - Thread Starter
Ugly1's Avatar
I know for sure about Diablo 3 working and that's it I know of. Are there any other 7.1 enabled games any body else here knows about? I know of tons that aren't 7.1. We need a 7.1 battlefield game.
Edit:
Compiled List (The ones I've gotten working):
1. Diablo 3
2. Need for Speed Most Wanted (2012)
Ugly1 is offline
post #2 of 24 Old 01-27-2013, 08:06 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4942 Post(s)
Liked: 8365
Need For Speed: Most Wanted (2012) has 7.1 support
Mark Henninger
imagic is online now
post #3 of 24 Old 01-27-2013, 02:00 PM - Thread Starter
Ugly1's Avatar
Sweet. Thanks for the tip. Got it working. Sounds awesome. Now I may have to go get a new racing wheel. Love it.
Everybody be sure to buy multiple copies of these to reward the developers for this proper behavior.
This can't be all there is is it!?!?
Ugly1 is offline
post #4 of 24 Old 01-27-2013, 02:29 PM
Anthony1's Avatar
Quoted: 588 Post(s)
Liked: 352
This is one area where consoles have a slight advantage. Shiz... The PS3 had lossless 7.1 back in 2006.
Anthony1 is offline
post #5 of 24 Old 01-27-2013, 03:06 PM - Thread Starter
Ugly1's Avatar
Oh now you've done it. While I'm glad were finally emerging from the dark ages I don't know that I'd consider the proprietary and expensive to liceense overcomplicated solutions which now hold the audio path for ransom and fianally available by '06 necessarily better than what I could see from a slight tweak on AC97. Sure, developers could buck Sony and go another direction but good luck getting software companies to risk upsetting that sony cash cow. Other than the progress stifling affect I guess I'm OK with hdmi as long as some 7.1 software hurries up and starts showing up. I'm not kidding man,. Diablo 3 and Need For Speed Most Wanted sound bad to the bone.
Ugly1 is offline
post #6 of 24 Old 01-28-2013, 07:54 AM
macks's Avatar
Liked: 31
The consoles also claim to support 1080p. How many games are actually made with 7.1 for the consoles?
macks is offline
post #7 of 24 Old 01-28-2013, 09:23 AM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
I thought all PC games had 7.1 support (and more) as long as they had DirectSound support? (pretty much all modern PC games) They support as many speakers as you have.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #8 of 24 Old 01-28-2013, 10:17 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5280 Post(s)
Liked: 4165
Nearly ALL games on PC have support for 7.1 as long as DirectSound is used and it is most of the time. I could play a game from pre-2000 and have it in 7.1 surround.
Consoles.... heh.
Scott Simonian is online now
post #9 of 24 Old 01-28-2013, 03:00 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Consoles.... heh.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #10 of 24 Old 01-28-2013, 03:09 PM
Bass Enabler
Liked: 4165
post #11 of 24 Old 01-28-2013, 06:44 PM - Thread Starter
Ugly1's Avatar
How do you enable directsound? Most of the new games I'm trying don't have a choice for "direct sound" or even how many speakers. Most just seem to do 5.1 and have a bunch of volume sliders in the sound config area. NFS and Diablo 3 both have a 7.1 selection you must make and when I do it works. I've recently tried Dishonored, Far Cry 3, Dungeon Siege 3, the Witcher 2 and Skyrim and couldn't get 7.1 out of any of those though they could do 5.1.
Ugly1 is offline
post #12 of 24 Old 01-29-2013, 07:46 AM
rich3fan's Avatar
Quoted: 20 Post(s)
Keep calm and drive a Camaro
rich3fan is offline
post #13 of 24 Old 01-29-2013, 07:50 AM
rich3fan's Avatar
Quoted: 20 Post(s)
Ugly1, in Windows 7 (and probably newer & previous versions) Directsound, which is a function of DirectX, is enabled by default. (Correct me if I'm wrong guys)
rich3fan is offline
post #14 of 24 Old 01-29-2013, 08:21 AM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
As long as you have multiple speakers configured properly in the Playback Devices and the game supports DirectSound you will get multi-speaker output.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #15 of 24 Old 01-29-2013, 08:30 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
DS no longer exists and has been replaced by XAudio2. DS games and apps still work with XAudio2 though, because it emulates DS. Dave pretty much summed it up but some older stuff doesn't work as well under XAudio2 as it did with DirectSound.
LexInVA is offline
post #16 of 24 Old 01-29-2013, 05:15 PM
Bass Enabler
Liked: 4165
Pretty much, yes.
This. The OP needs to double-check the standard Windows audio settings and make sure 7.1 speaker layout is selected. It should just default to 2ch but maybe 5.1 when HDMI is plugged in. I have no idea cuz I set it to 7.1 right away.
post #17 of 24 Old 01-29-2013, 06:27 PM - Thread Starter
Ugly1's Avatar
Pretty much, yes.
OK so I'm running windows 7 with all the latest updates, configured for 7.1 in windows audio settings (set this way long ago and apparently working since test runs through all channels), device manager and everything else I know to check seems to be alright with everything the way it is.. Everything else seems working: bitstreamed high def from TMT5, passed 7.1 pcm, dolby digital and dts's seem fine. All these things properly light up correctly on my pre/pro as expected and 7.1 works great with Diablo 3 and Need for Speed Most Wanted 2012.
I'm curious, have you actually tested that you get 7.1 on any of the games I've mentioned (Dishonored, Far Cry 3, Dungeon Siege 3, the Witcher 2 and Skyrim), I failed tp get 7.1'ing , and if so are you sure it is a discrete signal and not just some remixed and affect laden version of some other channel which was already there?
BTW just so I'm clear...I'm only interested in software putting out 7.1 not some fake dsp post processed hack of a 5.1 stream like dolby pro logic IIx.
Ugly1 is offline
post #18 of 24 Old 03-13-2013, 02:47 PM
djoye's Avatar
I know I'm coming into this kinda late but...
PS3 is capable of supporting 7.1 surround but it is entirely up to the game developer to support it. If you are always getting 7.1 surround from games, then you probably have virtual surround or matrixing enabled on your receiver. Some games support discrete 7.1 and many are just 5.1; it depends on how thorough the programmers are at implementing the audio engine in their game and also depends on the audio engine used in the game; for example, Batman Arkham Asylum on PS3 and PC supported 7.1 because it used FMOD for its audio engine but Arkham City only supported 5.1 because it used Wwise. Wwise only supports up to 5.1 channels.
You don't enable DirectSound, it's a component built into older games.. As has been said, DirectSound is an outdated audio engine from the Windows XP era used in many older games; it's a component embedded into the game. Most games now days don't use DirectSound but use a number of audio engines such as FMOD, Wwise, XAudio2, and OpenAL. Dishonored only supports up to 5.1 because it uses Wwise and Wwise only supports up to 6 channels. Far Cry 3 and Skyrim use XAudio2 which supports 7.1 output but the programmers were perhaps incompetent and failed to implement the necessary programming to get those games to see an 8 channel speaker configuration. The Witcher 2 uses FMOD and I'm certain that this game supports 7.1 so I'm not sure why that's not working for you. Make sure that your speaker configuration in Windows is set to 7.1. I use analog output from my X-Fi card so I haven't tested these games through HDMI; maybe HDMI audio does something with Witcher 2 that prevents it from detecting 7.1 channels.
I'm slightly enthusiastic about PC gaming audio so I created a page with my findings of what audio API the game uses and what channel output it supports:
http://satsun.org/audio/
That stuff is mostly about gaming with direct analog connections from a sound card to a receiver. I think using HDMI automatically mixes bass to the subwoofer and I'm guessing you guys are probably using HDMI. When using analog connections, if the game isn't specifically programmed to route audio to LFE then you get no subwoofer usage unless you tell the sound card software to do bass redirection.
PC Game Audio - http://satsun.org/audio/
djoye is offline
post #19 of 24 Old 03-14-2013, 01:18 AM
Bass Enabler
Liked: 4165
http://stuffiputupwith.net/audio.html
Wow! Thanks for this list. Seriously.
post #20 of 24 Old 03-14-2013, 06:02 AM
rich3fan's Avatar
Quoted: 20 Post(s)
Yes, thanks for the list djoye. And your page also answered some questions I had about the audio in games. cool.gif
rich3fan is offline
post #21 of 24 Old 03-14-2013, 10:24 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
You are our game audio hero right now.
I just recently hooked up my soundcard to my receiver. Analog, 5.1, small room, not enough space for 7.1. So that's a nice list to see. I've set my sound card to handle the crossover, but I have yet to actually play anything but Dishonored and Rocksmith since hooking it up. Seeing which ones have actual LFE channels is a nice little bonus.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #22 of 24 Old 03-14-2013, 10:42 AM
djoye's Avatar
Lemme know if anything on the page needs to be clarified. It's just something I kinda threw together.
djoye is offline
post #23 of 24 Old 03-14-2013, 12:01 PM
Bass Enabler
Liked: 4165
Seemed pretty accurate from my recent experiences with my new computer in my HT room which is 7.1 capable. I have mine hooked up with HDMI though. Really, it's the same thing. Your AVR might not be able to use bass management using the analog in but my old (pre-HDMI) Harmon Kardon could. It would allow you to run the analog pure or digitize it for use with bass management. But anyway... the poor use of audio in general with gaming keeps me annoyed thru the years. tongue.gif
post #24 of 24 Old 07-21-2013, 11:22 AM - Thread Starter
Ugly1's Avatar
Wow, sweet post and site djoye. I guess I need to look at my old posts more.
I'll have to have another try running The Witcher again sometime soon. Maybe I blew it.
Been too busy to play anything new lately.
BTW yes it is an HDMI link I use. My Asus ATI6850 based card outputs to my Onkyo PRSC885 preamp. As far as I can tell it's all setup properly as encoded streams are detected encoded by the pre and the 7.1 kicks in via Diablo 3 as soon as I make the change in the game options. I'm guessing if it's set up right for Diablo to work, then other games should work too???
Edit: my setup sends all discrete channels from the pc but my preamp has the option of creating a sub channel from the other channels when one doesn't exist. I turn that on because music sounds better that way.
Ugly1 is offline
Reply HTPC Gaming
