Gtx 690 mini DP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-23-2013, 11:16 AM - Thread Starter
mumflaps's Avatar
Hi guys just a quick question
I'm toying with the idea of buying a nvidea GTX 690 gfx card. I want to hook my PC up to my tv through an av receiver. I'm guessing the best option would be to use the gfx cards mini DP. Obviously I will need a mini DP to hdmi adaptor. Will going through an adaptor have any affect on the sound output?
mumflaps is offline
post #2 of 2 Old 03-25-2013, 05:11 PM
RLBURNSIDE's Avatar
Quoted: 1981 Post(s)
Liked: 1535
I do it on my AMD 6950 HDMI / DP, it works fine with audio either way, into my receiver. Basically no difference between DP and HDMI.
RLBURNSIDE is offline
Reply HTPC Gaming
