Best controller for HTPC ROMS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-25-2013, 07:41 PM - Thread Starter
doozer12's Avatar
I've been playing some old school NES roms and would really like a decent controller. Is the wireless Xbox 360 the best bet? I tried using a ps3 controller with a Bluetooth adapter but just couldn't get it working right. My PC got screwy after installing the software and drivers for it. I use a windows 7 based HTPC and have been using JNES as my emulator. Is the setup for the Xbox controller fairly easy? Thanks for the help!
doozer12 is offline
post #2 of 9 Old 03-25-2013, 10:10 PM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
http://www.retrousb.com/index.php?cPath=21
Anthony1 is offline
post #3 of 9 Old 03-26-2013, 04:09 AM - Thread Starter
doozer12's Avatar
Thanks for the link. Those look cool! I was hoping for a good wireless solution. Thats why I was hoping the 360 controller would work. I just dont have one yet.
doozer12 is offline
post #4 of 9 Old 03-26-2013, 11:42 AM
taskman's Avatar
Quoted: 17 Post(s)
I have been use the Xbox PC controller for several years now on my HTPC. I would say its OK but the issue is the D-Pad. On the generic xbox 360 controller its not as smooth as the older controllers. I upgraded to the new controller a year ago: http://www.amazon.com/Xbox-360-Wireless-Controller-Transforming-Charge/dp/B00936K09S/ref=dp_ob_title_vg.
It has an interchangeable D-Pad so that it stands up and turns into a traditional D-Pad shape. Its fairly good and IMO probably the best compromise out there, especially on the wireless front. I would suggest you go buy it at Gamestop and if you don't like it, just return it.
taskman is offline
post #5 of 9 Old 03-27-2013, 03:51 AM - Thread Starter
doozer12's Avatar
Thanks for the advice. I like the looks of that one. I assume I would need the wireless game receiver too? Or is the xbox controller bluetooth?
doozer12 is offline
post #6 of 9 Old 03-27-2013, 05:20 AM
DaverJ's Avatar
Quoted: 1328 Post(s)
Liked: 3729
No bluetooth - you'll need the Xbox 360 Wireless Gaming Receiver for Windows.
Note that many (most?) sold separately from the "Microsoft Xbox 360 Wireless Controller for Windows" are knock-offs, but may work fine nonetheless.
DaverJ is offline
post #7 of 9 Old 03-27-2013, 02:05 PM
taskman's Avatar
Quoted: 17 Post(s)
The receiver comes with the unit and I don't think it can purchased separately. It will be obvious because one controller will be much more then the rest. It should say PC windows on the front label and will mention the receiver. It actually isn't Bluetooth, its 2.4Ghz and the range is pretty ridiculous. I can be outside my apartment and still operate though blindly, heh. Last item is any xbox 360 controller works with the receiver in case your doing some two player or more ROM action.
taskman is offline
post #8 of 9 Old 03-28-2013, 09:51 AM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
Generally though with those you need to manually install the driver from Device Manager.
XBL/Steam: JHoff80
jhoff80 is offline
post #9 of 9 Old 03-28-2013, 10:21 AM
DaverJ's Avatar
Liked: 3729
Yep, but at least it's easy.
I have a knock-off and it automatically installed the driver in Windows 8 - works great.
DaverJ is offline
Reply HTPC Gaming
