Lip sync in movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-26-2013, 03:19 PM - Thread Starter
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
I'm having a problem with some videos played on the HTPC. It's fast enough
Windows 7 64bit
AMD 245e CPU
4GB RAM
ATI 5450 PCI-E videocard
Onboard sound, coaxial/optical out
Pioneer LX-5090 plasma
DVI-HDMI to Yamaha AV amp, onto Samsung 24" monitor
HDMI-HDMI to Oppo switcher then onto Pioneer
Should I set the Pioneer to 24hz? If the movie is 24hz, should I do that or setting to 60hz ok for all videos?
For movies the Pioneer is set to primary and I just load up MPC and start the video. Dual display is set to single screen, as when I switch off the Samsung it seems to mess around with dual display then sets single display mode. So I just have the Pioneer to primary.
Media Player Home Cinema edition 64 bit.
There are a few options in ATI, I've disabled all the post processing except for de-interlace and enforce smooth video playback. I've noticed a few things like real time correction, vsync, etc. MPC HC is using the ATI hardware acceleration.
MPC HC has a ton of options, all I've done is set DTS/DD SPDIF output
I tried the movie in VLC and it seems to keep the audio in sync. But I prefer MPC HC.
I have tried other videos and some do go out of sync the longer I leave it. The tearing test looks fine.
fatbottom is offline
post #2 of 4 Old 03-28-2013, 05:41 PM
rich3fan's Avatar
Quoted: 20 Post(s)
Your question might be better asked in the Home Theater Computers sub-forum:
http://www.avsforum.com/f/26/home-theater-computers
Keep calm and drive a Camaro
rich3fan is offline
post #3 of 4 Old 03-29-2013, 01:47 AM - Thread Starter
fatbottom's Avatar
Liked: 519
ok. can a mod move it?
I notice MPC HC has audio sync however it's not like it's out straight away. Sometimes it takes a while for it to drift.
post #4 of 4 Old 04-14-2013, 07:04 AM - Thread Starter
fatbottom's Avatar
Liked: 519
This is doing my head in.
I think it's only out in Dolby Digital. In DTS it seems ok
So I don't want to apply delay in the HTPC or on the processor because then DTS will be out.
Right I put a 250ms delay and that seems to fix it, when viewing on the plasma, but on the monitor it's out of sync. Corrected Dolby Digital, I haven't tried DTS.
Reply HTPC Gaming
