Help for new GPU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-05-2013, 11:34 AM - Thread Starter
urfrontlawn's Avatar
Hi I really need help finding a budget graphics card. My budget is about $200 but less would be great. My current specs are:
Gt 610
AMD fx 41000 3.4 Ghz
8 Gb RAM memory
500 Watt Power Supply
1 terabyte hardrive
Forgot my motherboard sorry it's a gigabyte though
20-22 inch HP monitor
I need to replace my RAM sticks as they are corrupted which I why I'm on a this type of budget any help would e awesome! Thank you in advance
urfrontlawn is offline
post #2 of 3 Old 04-07-2013, 11:38 AM
darklordjames's Avatar
Liked: 94
Geforce GTX 650 Ti Boost 2GB. Be very specific that you are getting the Boost version. It is very much a GTX660 Lite, which is a rad card. The 650 Ti is more of a fast 650, which is a lot more cut down. The brand doesn't really matter, just get one with two fans so that it is quieter. The single fan designs are still noisier under load.
The Ti Boost is like $180 at Newegg of I recall? Very compelling offering.
darklordjames is offline
post #3 of 3 Old 04-07-2013, 03:01 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
Paid $169 for mine. Incredible card for the money. The zotac one I have is super quiet too.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Reply HTPC Gaming
