Help for new GPU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-05-2013, 11:36 AM - Thread Starter
urfrontlawn's Avatar
Hi I really need help finding a budget graphics card. My budget is about $200 but less would be great. My current specs are:
Gt 610
AMD fx 41000 3.4 Ghz
8 Gb RAM memory
500 Watt Power Supply
1 terabyte hardrive
Forgot my motherboard sorry it's a gigabyte though
20-22 inch HP monitor
I need to replace my RAM sticks as they are corrupted which I why I'm on a this type of budget any help would e awesome! Thank you in advance
urfrontlawn is offline
post #2 of 2 Old 04-05-2013, 01:14 PM
CrowSS's Avatar
Gt 610
8 Gb RAM memory
1 terabyte hardrive
7850 Sapphire $155 + Bioshock and Tomb Raider
7870 Powercolor for $235 + Bioshock and Tomb Raider Has Tahiti GPU, almost on par with 7950!
Nvidia GTX 660
Use code: EMCXSXV42 to get it for $169
Xbox GT: CROWSSLT1
CrowSS is offline
Reply HTPC Gaming
