Video Card Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-18-2013, 07:52 PM - Thread Starter
motoman's Avatar
I'm wanting to take my old PC out of the closet and use it to stream Motocross races in HD to my big screen with a HDMi hookup. It is a system I built about three years ago but doesn't have a video card. It is a Asus P6X58D MB and a i7 960 3.2 ghz chip with 6 gb of ram. One quirk of this motherboard is the sata connectors sit right under the back end of the video card so a longer card can cause clearance issues as I found out when I upgraded to a EVGA GTX-580 and tried to use it in this system a little over a year ago.
Anyway I need a card with HDMi out to put in this system. It won't be used for anything else so I was just curious how beefy of a card will I need and how much memory? If I could find a card under $100 that would be great. Eventually this system will be passed along to one of my sisters. I just don't know what card would be best for this type of use.
Any suggestions would be appreciated.
Jim
motoman is offline
post #2 of 5 Old 05-19-2013, 02:32 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Looks to me like you can easily fit a dual slot card...
Of course it's not like you'll need to just for video playback, even the current inexpensive cards (under $100) will do what you want to do.
Generally speaking the newer AMD cards will out-perform the comparable Nvidia cards under $150.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #3 of 5 Old 05-19-2013, 07:07 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 412
Newer AMD cards have better power management for low power states too. I would choose something from AMD for this task.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is online now
post #4 of 5 Old 06-11-2013, 09:11 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
HD7750 at well under $100. If you will only be using for video.
lespurgeon is offline
post #5 of 5 Old 06-11-2013, 09:29 PM
257Tony's Avatar
This is all you need for your video playback...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131339
257Tony is offline
Reply HTPC Gaming
