GTX 680 FTW Overclock help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-25-2013, 10:02 PM - Thread Starter
Mikeclough24's Avatar
Quoted: 85 Post(s)
Liked: 29
So i i'm looking for someone to either help me overclock using evga precision X or if i could get a link to a guide for beginners that would be great also.. I've tried googling it and youtube but can't seem to find anything that is very helpful. my specs are -
- i7 3770k
- ASrock z77 extreme4
- Corsair 750W PS
- Corsair H100i cpu cooler
- GTX 680 FTW 4gb
- GSkill sniper 16gb
Mike Clough #24
Mikeclough24 is offline
post #2 of 10 Old 05-25-2013, 10:32 PM
N8DOGG's Avatar
Quoted: 1117 Post(s)
Liked: 1221
https://www.youtube.com/watch?v=U9D03zTItR4
N8DOGG is offline
post #3 of 10 Old 05-25-2013, 10:42 PM - Thread Starter
Quoted: 85 Post(s)
Liked: 29
ive seen this and some others on youtube but looking for a little more detail.. im pretty much a beginner.. maybe even just tell me where to put the mem clock offset and gpu clock offset and the power target/temp target... i can toy with it from there keeping an eye one my temp etc..
Mike Clough #24
post #4 of 10 Old 05-26-2013, 08:03 PM
N8DOGG's Avatar
Liked: 1221
We can't really tell you where to put your sliders as every chip is different. Add as much voltage as it will allow and start out at 100mhz over core and mem and test it out. go max power target. Your temps will be fine, nothing can go wrong, your not going to hurt anything if you oc too much, it will crash and you will have to back off your core or mem from your oc. You should be good for 200-250 core and 200-400 mem on your card but they are all different.
That video explains it pretty well. The more you want to OC, the more voltage you will need to give it. It doesn't allow you to give it so much voltage that you'll wreck anything, so no worries, you can't harm your card.
N8DOGG is offline
post #5 of 10 Old 05-26-2013, 09:42 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
As far as I am aware that model 680 does not have an unlocked voltage (it can be hard modded or bios unlocked but I don't think it is unlocked in stock form).
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #6 of 10 Old 05-26-2013, 10:03 PM - Thread Starter
Quoted: 85 Post(s)
Liked: 29
i found this video to really help.. i havent tried upping the voltage but i might try that so i can OC a little more.. right now im running power target max, gpu clock +65, mem clock +475 and bf3 only crashes every hour or so so i will try cranking the voltage a little at a time. what would you guys say the safe temps would be? its been running bf3 around 57ish and the stress test oc scanner around 71-73.
Mike Clough #24
post #7 of 10 Old 05-26-2013, 10:04 PM - Thread Starter
Quoted: 85 Post(s)
Liked: 29
post #8 of 10 Old 05-26-2013, 10:06 PM
lurkor's Avatar
Quoted: 29 Post(s)
Liked: 34
I'll state the obvious again as usual. Since no two chips are created equal in the eyes of geek, overclocking is more art than science. A bit like alchemy, but without the toxic fumes (unless you really go hog wild.)
That being said, I was under the impression the FTW cards were among the highest of the factory overclocks, so maybe it may be in your best interest to leave well enough alone in the long run. It's always a compromise with noise usually being the worst case offender.
On the other hand there are those who enjoy tinkering with their systems as much as gaming, but they tend to have a knack for pushing things further than they should. The moral of the story is, just because someone on the net claims they can push 1.21 gigawatts, doesn't mean it's such a good idea.
lurkor is offline
post #9 of 10 Old 05-27-2013, 07:32 AM - Thread Starter
Quoted: 85 Post(s)
Liked: 29
Well noise is a complete non-factor to me because the pc behind a wall. I just enjoy learning how it works mostly. I am completely new to the pc world, just got interested about a year ago and just enjoy learning how it all works.
Mike Clough #24
post #10 of 10 Old 05-29-2013, 06:43 PM
N8DOGG's Avatar
Liked: 1221
Your GPU can go into the 90c with no problems. Your temps are actually pretty low. You've got lots of room temp wise....
N8DOGG is offline
Reply HTPC Gaming
