Trying to set 5.1 upmixing to 7.1 with PLIIx --- which game can I use to test? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-20-2013, 10:18 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
I would like to make sure my 7.1 speakers are working properly in Windows. I have tested with Hitman: Absolution and Metro: Last Light and both of them output in 7 channels, but they must support 7.1 natively as even when I disable EXTD Surround on my Yammy, I still hear them.
What I'm looking to do is make sure that games in 5.1 will properly upmix to 7.1, with EXTD Surround & PLIIx
Can anyone tell me a game that is definitely only in 5.1? That way I can test with PLIIx on and off. I should get either 5 of 7 channel output depending on how it's set.
WeApOn is offline
post #2 of 12 Old 06-20-2013, 12:51 PM
macks's Avatar
Liked: 31
If you set your speakers in Windows to 7.1 then all sound should be bumped up to 7.1 by windows. Some programs override this but I don't believe any games will.
macks is offline
post #3 of 12 Old 06-20-2013, 01:03 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
By 'override', do you mean that some programs will limit it to 5.1?
So essentially my receiver will not ever need to engage PLIIx? That would make sense as to why turning it on or off didn't make any difference.
How does Windows handle the extra sound? Does it have a similar type of PLIIx algorithm built in?
WeApOn is offline
post #4 of 12 Old 06-20-2013, 06:00 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
bump
WeApOn is offline
post #5 of 12 Old 06-20-2013, 08:04 PM
macks's Avatar
Liked: 31
You should really post this in the normal htpc section. You will get more attention.
macks is offline
post #6 of 12 Old 06-21-2013, 07:20 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
This one? http://www.avsforum.com/f/94/home-theater-gaming
Sorry, there are so many sub-forums. Made a post there hoping I would get some attention.
WeApOn is offline
post #7 of 12 Old 06-21-2013, 08:01 AM
macks's Avatar
Liked: 31
Forums -> Video Components -> Home Theater Computers
I can't promise anyone there will know how Windows pushes audio to all speakers.
macks is offline
post #8 of 12 Old 06-21-2013, 06:33 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
Just found one example that proves my initial worry to be true --- If I have my computer speakers set to 7.1, certain applications will not be in 7.1, and PLIIx will not work in upmixing the 5.1 to 7.1
EIther due to the program sending silent data to the two extra channels, or some other reason... The only fix is to change my PC settings to 5.1 and keep PLIIx, then it works.
I tested with a game that output 5 channels when I told Windows I had 7. From what it seems, it was sending silent data to the other two channels, so my PLIIx would never kick in.
My original intention was to avoid having to switch between telling Windows that I have 7 speakers(when I use native 7.1 content) or that I have 5 speakers(when the above example happens, causing two silent channels).
Unless anyone else has an idea, I think the only solution will be to keep Windows set at 5.1 and apply PLIIx. The downside of this will be that true 7.1 content will end up being 5.1 --> PLIIx upmixed to 7.1. I'm not sure how negative this is, as I don't know the technical facts behind the differences.
Unfortunately it doesn't seem like I have any other options, as one program to another this will differ, but the only way to maintain 7 channel output ALL THE TIME is to force 5.1 and PLIIx.
Can anyone shed some light on the detrimental effects of using 5.1 & PLIIx for true 7.1 content, versus using native 7.1?
WeApOn is offline
post #9 of 12 Old 06-24-2013, 01:30 AM
darklordjames's Avatar
Liked: 94
Just leave Windows set to 7.1. Your setup will just leave two of the speakers unused in the cases of incoming 5.1 PCM, which is the most correct way to handle it. Forcing 5.1 all of the time just results in things being wrong more often than not. Running 7.1 out of Windows means the audio is always correct, it just doesn't use some speakers sometimes.
What you are advocating is exactly like forcing a PS3 to run stereo all the time, just because Hulu wraps the 2.0 source inside of an additional 3.1 channels of empty air.
darklordjames is offline
post #10 of 12 Old 06-24-2013, 07:15 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
I can certainly appreciate and understand this theory. However I might personally prefer the extra channels even when they're not necessary. For the games I have tested with, the sound was far more enveloping and immersive. I will certainly consider this idea however depending on how things sound in the future. I would hate to waste the use of those extra two channels if most content would normally block those channels.
WeApOn is offline
post #11 of 12 Old 06-27-2013, 09:35 AM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
You have two options: Set Windows to 5.1 or 7.1
5.1 - Your receiver using PLIIx will add in the extra 2 channels to the best of its ability, PC will only output 5 discrete channels so native 7-channel content will not be fully utilized
7.1 - Your PC will output 7 channels to your system and you will have 7 discrete channels of playback. Content that only supports 5 channels will leave you without sound on 2 speakers.
Really your best bet is to set it to 7.1 and just switch it to 5.1 for content you know to be 5 channel. I have a feeling most games will be just fine outputting 7.1. I really don't know of a 'best of both worlds' option for you.
Osirus23 is offline
post #12 of 12 Old 06-27-2013, 09:47 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
I found that there wasn't as many native 7.1 games out there. 5.1 with PLIIx seemed to almost always guarantee that I would get 7 speaker output. I haven't heard too many opinions on 5.1 with PLIIx versus native 7.1, but from what I heard, native 7.1 isn't a major difference versus 5.1 upmixing to 7.1 via PLIIx.
For me the best situation is outputting on 7 speakers all the time -- that's the most immersive. To do that I will have to keep 5.1 enabled in Windows and PLIIx on my receiver -- I happy with that for now. Unless I hear that native 7.1 will sound way better than 5.1 upmixed, I am happy this way. smile.gif
WeApOn is offline
Reply HTPC Gaming
