Help me update my gaming PC build I put together in April - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-21-2013, 11:12 AM - Thread Starter
RRenton's Avatar
http://ca.pcpartpicker.com/p/Qkcx
This is what I was going to get, but I decided to update my home theater first instead. Since then I haven't really been following what parts have been coming out and what parts have dropped in price. What's happened since April that I should know? I heard there's a new Intel CPU but I haven't heard much about it.
I probably won't get the stuff for at least another month, maybe even two, so let me know what's coming up as well please.
Also, I'll be using Dolphin and PCSX2 a lot and I want to be able to play newer games at the highest settings.
RRenton is offline
post #2 of 2 Old 07-22-2013, 06:14 AM
257Tony's Avatar
That's a very good list. I'm not up on Canadian prices, but I believe you could find a 7970 for less than $440 with a bit of shopping. You could also go with the i5-3570k if you wanted to save $100. Otherwise, nice job choosing parts.
257Tony is offline
Reply HTPC Gaming
