One gaming PC....two different rooms. - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2013, 06:18 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Getting pretty tired of lugging my HTPC back and forth from my desktop setup to my theater....there has to be a way to make this work. I'm willing to run whatever cables I have to.
Right now I've got a desktop setup with a 3D monitor connected via dual link DVI, and USB peripherals. Audio is analog stereo.
On the other setup I've got a 3D plasma that's connected to a receiver, both audio and video feed over HDMI. In the theater I've got a few wireless peripherals, such as a handheld keyboard and a 360 controller, that need to be within range.
I've currently got a hardwired gigabit ethernet connection running between the rooms, but I'm pretty sure that's not even enough for the HDMI.
So....anyone that's got something similar know of a good way to go about this?
I'm thinking that having the HDMI and DVI connected at the same time will cause issues, because it'll assume it's a multi monitor setup - and the displays have such radically different requirements that it'll just be asking for trouble. Same with the HDMI/analog audio....so I'm willing to connect/disconnect cables as necessary.
The main issue is the ~100ft HDMI and USB cable runs. Anyone ever run those cables that far? I'm assuming I'll need some sort of signal booster? It needs to be able to flawlessly carry 1080p/60 or 720p/60/3D, alongside 7.1 PCM.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 07-29-2013, 08:59 AM
Nitemage's Avatar
Quoted: 38 Post(s)
I'm doing this with a passive 75' monoprice hdmi cable. I use a 6' HDMI cable from the PC to a monoprice 1X2 Mini HDMI Splitter. One cable from the splitter goes to the monitor the other to the projector in my home theater. I'm then using a usb booster to run usb over cat5 75 feet. The usb then goes from the booster into a 6 port powered hub in the home theater where I plug in my keyboard, mouse, IR receiver.
The USB over cat5 cab definitely go that far. I'm not sure about the HDMI, monoprice sells passive 100 ft cables but that is kind of stretching the distance.
Nitemage is offline
Old 07-29-2013, 09:07 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
I think I might be able to get the run down to 75ft....but I still need it to support high speed HDMI, since I'll be transmitting 3D. I dont see monoprice selling any high speed cables over 50ft.
The USB seems like the easy part at least.
bd2003 is offline
Old 07-29-2013, 09:29 AM
Nitemage's Avatar
Quoted: 38 Post(s)
While not rated as a high speed cable my 75' cable allows for 1080p, 3d, and HD audio. I'm using a monoprice 75ft 22AWG CL2 Standard HDMI Cable - Black. I think it really depends on your how much signal your source is putting out and whether the display can handle the reduced signal.
Nitemage is offline
Old 07-29-2013, 09:32 AM
Nitemage's Avatar
Quoted: 38 Post(s)
The other option is to run hdmi over cat5 which will require 2 cat5 cables between the transmitter and receiver. It works for longer distances but is more expensive.
Nitemage is offline
Old 07-29-2013, 11:08 AM
Monger's Avatar
Liked: 66
I run hdmi over cat6(75') and It works fine for 1080p/60, but I've never tried 3d on that run. It's supposed to work though. The only issue is it's susceptible to interference from stuff like ceiling fans so the picture will flicker when I turn my fan on or off.
An hdmi cable, unless it's fiber, probably isn't going to work for you at that distance.
Monger is offline
Old 07-29-2013, 11:13 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
An hdmi cable, unless it's fiber, isn't going to work for you at that distance.
Hmm...well they sell one way cables that are supposedly boosted. I figure I'll give the simple solution a try, and if it doesn't work, then I'll give the cat6 bridge a try.
bd2003 is offline
Old 07-29-2013, 11:26 AM
Monger's Avatar
Liked: 66
Even your equipment will make a difference in your results. All you can do is give it a try.
I lost 3d at 35 feet and the other guy has it working at 75.
Monger is offline
Old 07-29-2013, 11:30 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
It's too bad there isn't a simple real time compression box that can squeeze the signal down to a manageable 50-100mbps without losing too much quality. I could probably live with that, even if it adds 20-30ms of lag.
bd2003 is offline
Old 07-29-2013, 12:03 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
For the USB extender....will it work through a switch? I already have both rooms connected via a 75ft cat6 cable, there's a switch on both sides....can I just plug one side into one switch, and the other into the other switch? Or do I need a separate dedicated cat6 cable?
bd2003 is offline
Old 07-29-2013, 06:17 PM
Monger's Avatar
Liked: 66
Not inherently, no.
Somebody might make such a thing, but it would probably be costly.
edit: Here's one for 450, but it is somewhat limiting in functionality.
Monger is offline
Old 07-29-2013, 06:32 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Not inherently, no.
Hmm...well I ordered a 75ft HDMI cable that claims to support 3d over that distance. Also a 60ft USB cable that makes a similar claim...and a powered hub to stick on the end of it. Hopefully it works!
bd2003 is offline
Old 07-29-2013, 07:00 PM
Monger's Avatar
Liked: 66
Hopefully it all works out!
I remember my weekend of doing electrical, pulling wire, installing everything and sweating my ass off only to not have a stable signal at my projector. So I waited all week for my new active extenders to arrive and everything looked great. That Friday night I made popcorn in the popcorn machine, popped a blu ray in my ps3, went to select the movie and nothing. My ps3 drive had died. eek.gif
Monger is offline
Old 07-31-2013, 03:19 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Got the cables today....the 75ft HDMI cable works fine at all resolutions. USB also seems to work fine with the 60ft cable and a powered hub at the other end.
These are super thick cables, I'm sure my wife will appreciate them running through the kitchen.
Glad the hardware works, but I suspect the software side of getting everything to work correctly will be the real problem.
bd2003 is offline
Old 07-31-2013, 06:56 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Well nevermind that....it all works flawlessly!
When just the desktop setup is on, because the receiver/TV downstairs isnt on, it doesnt even register the other display. It just defaults to the desktop monitor with 3d vision, and output through the analog. As soon as I turn on the TV, it automatically sets the defaults to use 3DTV play and the HDMI audio...turn the display off, and it automatically switches back audio and video. It couldn't possibly work any smoother! I'll never have to drag the PC back up and down, plug in all the wires...and my desktop is always there.
Now all I need to do is figure out how to get my xbox controller or remote keyboard to wake the PC out of standby.
bd2003 is offline
Old 07-31-2013, 07:00 PM
Marafice Eye's Avatar
Liked: 420
Dude! Nice! Glad to hear it all works.
Marafice Eye <--- All gamertags listed there - Twitch TV Channel YouTube Channel
__________________________________________________ _
Marafice Eye is offline
Old 07-31-2013, 07:08 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
You can't even imagine how stoked I am that it works as well as it does. I was resigned to still have to deal with some amount of manual cable swapping and software fiddling....but it all just works!
bd2003 is offline
Old 07-31-2013, 07:11 PM
Liked: 420
I'm the same way just from having 4 monitors lol. I simply cannot go back to single monitor anymore, and probably no less than 3. Having all this screen real-estate is too hard to let go of.
But that aside, who will write game reviews? Mine are not really up to snuff, at least compared to the detail yours go into. So you may need to power on that console some more.
Old 07-31-2013, 07:26 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
The way I figure it, AVS is all about getting the best quality. Unless all the progress they made in the past few years in getting PC games to work well on TVs goes away, I'm probably going to put a heavy emphasis on the PC version, and the consoles will just be there for exclusives and multiplayer.
DaverJ likes this.
bd2003 is offline
Old 07-31-2013, 07:50 PM
Monger's Avatar
Liked: 66
Glad it went so smoothly.
And you have a very understanding wife!
Monger is offline
Old 08-01-2013, 03:30 PM
RemoWilliams84's Avatar
Quoted: 56 Post(s)
Liked: 300
Glad yours went smoothly. I ran a 100 ft hdmi from my pc room to living room. Tested the cable before running it and all was fine, but when I was running the cable under the carpet apparently it got kinked or something. Hooked it up and no picture. Ended up pulling it all out, cursing and giving up until about a year later (about a month ago) when I bought my wireless hd setup. Has worked flawlessly for me.
Xbox Gamertag/PSN ID: RemoWilliams84
"I started out with nothing, and I still got most of it." -Seasick Steve
RemoWilliams84 is offline
Old 08-01-2013, 03:39 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
wireless HD...for gaming?
bd2003 is offline
Old 08-01-2013, 03:58 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
I have dual wireless HD units running and they work fine with gaming, no additional lag.
My only issue is with multiple people up moving around the rooms sometimes I get signal interference that makes the picture get a little fuzzy (does not drop though).
I went ahead and wired direct HDMI from game room to HT and at about 50' total I can only maintain 100% signal by using a couple of powered 1x2 splitters (one is right at the PC and the other is about half way).
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
Old 08-01-2013, 04:03 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Tell me more about these wireless HD units....
bd2003 is offline
Old 08-08-2013, 10:03 AM
Quoted: 56 Post(s)
Liked: 300
Review I put up a while back:
http://www.avsforum.com/t/1476809/my-iogear-gw3dhdkit-wireless-3d-digital-kit-review
Old 08-12-2013, 05:08 PM
PubFiction's Avatar
Quoted: 17 Post(s)
Liked: 36
If you are using any type of phone or tablet based remote control you can set your computer to wake on lan with various apps. I use unified remote for windows phone and android on my HTPC.
PubFiction is offline
Old 08-12-2013, 05:28 PM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Ya, that's what I ended up doing. Still kind of annoying that I can't wake it with the controller though.
bd2003 is offline
