HTPC Specs...What Do You Think?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-03-2013, 09:35 AM - Thread Starter
MAC20's Avatar
i'm in the process of going from my PS3 to a gaming PC. here's what ive spec'd out. Also ill be putting a TV tuner in the PC so i can hook it up to my AV unit. That was one of my reason for going this route was because i couldn't find a TV tuner to hook up to my av unit and it doesn't have a tuner on it. but anyway here's my specs tell me what you think
Motherboard:
MSI H77MA-G43 LGA 1155 Intel H77 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard with UEFI BIOS
Intel H77
Core i7 / i5 / i3 (LGA1155)
DDR3 1066/1333
Processor with CPU Liquid Cooler:
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
22 nm Ivy Bridge 77W
8MB L3 Cache
4 x 256KB L2 Cache
CORSAIR Hydro series H50 High Performance Liquid CPU Cooler
1700 RPM +/- 10% 57 CFM
Fan Dim. 120mm x 152mm x 27mm
Fan Noise 30.32 dBA
Graphic Card:
GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
1280 Stream Processors
2GB 256-bit GDDR5
PCI Express 3.0 x16
Power Supply:
Rosewill BRONZE Series RBR1000-M 1000W Continuous@40°C, 80Plus Bronze Certified
ATX12V v2.31 / EPS12V v2.92
100-240V
80 PLUS Bronze Certified
Modular Design
Efficiency up to 87%
135mm Blue LED Dual-ball-bearing Fan
RAM:
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Timing 7-8-8-24
Cas Latency 7
Voltage 1.5V
OR
Timing 9-9-9-24
Cas Latency 9
Voltage 1.5V
Optical Drive:
LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner
All being placed in a Micro ATX Case with plenty of ventilation and fans.
MAC20 is offline
post #2 of 6 Old 09-03-2013, 10:49 AM
Marafice Eye's Avatar
Liked: 423
Very nice specs, but that PSU is overkill, you can save some by stepping down. For reference, my new build is 4770K and a 780 Classified, and at full load will pull maybe 500w (putting in a 750w PSU). Step down to a good bronze certified 750-800w. even if you end up crossfiring another 7870, a 750-800w would be plenty. Get a nice SeaSonic 750w, or 800w and you'll be fine.
Marafice Eye <--- All gamertags listed there - Twitch TV Channel YouTube Channel
__________________________________________________ _
Marafice Eye is online now
post #3 of 6 Old 09-03-2013, 12:07 PM - Thread Starter
MAC20's Avatar
thanks for the input... i was wondering if 1000w was to much. i will definitely step it down to 750w. do you have any input on a good tv tuner?
MAC20 is offline
post #4 of 6 Old 09-03-2013, 12:19 PM
Liked: 423
Hauppauge makes good tuner cards and external tuners, check some of them out.
post #5 of 6 Old 09-03-2013, 12:25 PM - Thread Starter
MAC20's Avatar
thanks. much appreciated.
MAC20 is offline
post #6 of 6 Old 09-03-2013, 08:06 PM
MarkcusD's Avatar
Quoted: 49 Post(s)
Liked: 45
Ceton or Silicon Dust for cable card tuners. I use the HD Homerun Prime external tuner.
psn: markcusd
X1: MarkcusD
MarkcusD is offline
Reply HTPC Gaming
