Sony's new interpolation-free "Motionflow Impulse" is low-lag, and great for HTPC gaming. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 09-09-2013, 02:44 PM - Thread Starter
Mark Rejhon's Avatar
Liked: 106
Hello,
Those of you running HTPC's on new Sony HDTV's: HX920 Series, HX923 Series, HX925 Series, HX929 Series, XBR-55HX950, XBR-65HX950, KDL-47W802A (Budget), KDL-55w802A (Budget), KDL-55W900A, W905A Series, XBR-55X900A (4K Ultra), XBR-65X900A (4K Ultra)
1. Load up a fast 60fps game (or use TestUFO Moving Photo Test)
2. Enable Motionflow Impulse. Turn off ambient light sensor for brighter picture.
3. Motion now looks as clear as CRT or plasma. No fake frames or interpolation!
This setting is available in Game Mode. It does flicker like a CRT (because of motion blur eliminating strobe backlight), but it is very high-efficiency, eliminating approximately three-quarters of LCD motion blur. This looks great in 60 frames per second games such as FPS and racing from the HTPC.
Related AVSFORUM Post: New CRT Quality LCD's With Zero Motion Blur
(General thread about strobe backlights, not specific to HTPC's).
DaverJ and barrelbelly like this.
Mark Rejhon
www.BlurBusters.com
BlurBusters Blog -- Eliminating Motion Blur by 90%+ on LCD for games and computers
Rooting for upcoming low-persistence rolling-scan OLEDs too!
Mark Rejhon is offline
post #2 of 25 Old 09-09-2013, 05:56 PM
joeblow's Avatar
Liked: 233
Thanks for the post - it is very relevant for this subforum.
However, I do have to ask the obvious: what does "low-lag" mean? If it is below one frame of lag, that would be outstanding. If it is around one frame, that's still very good. Two frames of lag is acceptable for many gamers unless they are in to fighters or music games, three becomes a barely accetable level for almost any gamer, and more than that is completely unacceptable.
So how many lag frames exist with this new tech turned on? And if the feature is turned off in Game Mode, what are the lag frames then? How was the lag detected? Maybe the thread link has this info; I'll read through it now.
For the record, I have a 60" Sony 3D set from a couple of years back, and turning on Motion Flow easily adds 3-4 frames of lag in game mode with it turned off. I always enjoy seeing improvements in tech so I hope they are onto something here. With Motion Flow on, it does a decent job at smoothing over the visuals, making it appearthat the frame rate is higher than it really is.
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #3 of 25 Old 09-09-2013, 07:58 PM - Thread Starter
Liked: 106
Depends on the strobe backlight, but generally less than one frame of added lag.
-- LightBoost adds less than one frame of lag (LightBoost), it is only +4ms (half of 1/120sec).
-- Sony's Motionflow Impulse mode adds less than one frame, for a total of less than two frames of total lag.
They are low-lag when compared to yesterday's interpolation and yesterday's inefficient scanning backlights. Many motionflow modes used to take 100 milliseconds, so these are ultra-low-lag modes in comparison. Measurements of Motionflow Impulse using Leo Bodnar:
I have some good news about the impulse mode on the sony 2013 KDL-55W905A.
The impulse mode is now available in gaming mode and the input lag in that impulse mode is only 30 ms!
The even better news is that it has been tested with the Leo Bodnar input lag tester, so a highspeed camera input lag test, will probably show 15 ms less.
So there you go, lightboost quality gaming that does not have the way too heavy 120fps requirement. The flickering is still there though.
Good chance that the same low input lag will be valid for the much cheaper Sony w805 as well.
Here is the review, the part about impulse mode is just above the Conclusion:
http://www.hdtvtest.co.uk/news/sony-kdl55w905a-201305172987.htm?page=Performance
So that's a Motionflow mode, zero interpolation artifacts (no fake frames), and adds less than one extra frame of input lag on top of baseline input lag. Which is low-lag, compared to yesterday's Motionflow.
Keep in mind that once lag differential is small, the motion blur elimination can actually cause faster human reaction times that outweigh the minor strobe-related input lag. During fast strafing / turning / panning, you can identify enemies quicker while in motion, without stopping moving. Strobe backlights make the input lag differential so small on some displays (+4ms) that the improved human reaction time often starts to outweigh the tiny input lag. The era is finally here now where high-efficiency motion blur reduction backlights are now worthwhile for computer/gaming use, finally free of interpolation artifacts, and the unreasonable lag is gone. Strobe backlights are even better at 120Hz, however, since half a frame of lag at 120Hz is just 4ms.
DaverJ likes this.
Mark Rejhon
www.BlurBusters.com
post #4 of 25 Old 09-10-2013, 09:05 AM
joeblow's Avatar
Liked: 233
This part is confusing:
There is no "probably" when a proper lag test is conducted. Is it 30ms (almost two frames) of lag added with impulse mode or a confirmed 15ms (about one frame)?
joeblow is offline
post #5 of 25 Old 09-10-2013, 01:54 PM - Thread Starter
Liked: 106
The Leo Bodnar test is well known by all sites (HDTVtest, displaylag.com, TFTCentral, myself, etc), to return different input lag values than the SMTT input lag results. Leo Bodnar uses three flashing squares, top edge, center, and bottom edge. The top returns smaller values (similiar to SMTT). The middle is average input lag, and the bottom is worst-case input lag. On plasmas and LightBoost, all values appear as the same. On CRT's and LCD's, they are scanned as the signal comes in sequentially, so the top value is smaller.
Lag Test Method #1: The Leo Bodnar test is 100% confirmed.
Lag Test Method #2: The SMTT test value is NOT confirmed.
We be know SMTT (CRT zero-relative method) is "probably" 15ms because historically, stuff that said 30ms on Leo Bodnar -- often reports 15-20ms on SMTT (CRT zero-relative measurements). A good explanation of the input lag behaviours are found at these links:
http://www.displaylag.com/testing-method/
http://www.hdtvtest.co.uk/news/input-lag/
Mark Rejhon
www.BlurBusters.com
post #6 of 25 Old 12-11-2013, 02:36 PM
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1518
Sony did it.., the mistake of the year... their 'smart' engineers decided to enable their interpollation algorithm (after the latest firmware updates) at 'Impulse' mode, and there is no way back.... you can't disable it now....OMG. frown.gif
Impulse mode was the only MotionFlow option where the Sony 4K had the best motion resolution from any other LED in the market, with NONE Interpolation.... sadly now.. Sony's Impulse mode features bad interpollation, large motion blur and this mode now is just a dimmed mode that noone will ever use... frown.gif
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #7 of 25 Old 01-12-2014, 10:53 AM
Erik Garci's Avatar
Originally Posted by ConnecTEDDD View Post
Sony 4K
Are you saying that only the Sony 4K models are affected? My Sony TV has Impulse but is not 4K, so I am wondering if I should avoid upgrading the firmware, or if I can downgrade the firmware after upgrading.
Erik Garci is offline
post #8 of 25 Old 01-12-2014, 12:07 PM
Liked: 1518
Sony 4K
Hello, I have tested only the Sony 55X9005 with tons of reference motion evaluation videos, after the problems I found, some days later they released a newer firmware where the motion performance become worst... frown.gif
post #9 of 25 Old 04-21-2014, 08:01 PM
Chomby's Avatar
Hey Connec, do you know what firmware version you tested with?
I have an Australian model Sony KDL-55W800A/802A TV, and I've been using impulse mode on firmware PKG4.201GAA with it working flawlessly. I have been using it on PS3 and PS4 games that run at 60fps. I have probably played games using impulse mode for about 40-50 hours.
However, I recently updated my firmware to PKG4.401GAA and impulse mode is no longer working as intended. Motion blur is reduced to a minimum, but there is a serious ghosting and image doubling of objects when moving. I think you are right in that Sony has enabled frame duplication in this mode. It really makes no sense to me at all, as that what the other modes are for. I updated to the latest firmware as of 21/04/12 (PKG4.410GAA) but impulse mode is still broken.
I'm getting in contact with Sony to try see what's up. I mainly use the TV for gaming so this is a major deal breaker for me. I've had the TV for about 6 months.
Chomby is offline
post #10 of 25 Old 04-22-2014, 01:43 AM
Liked: 1518
Hi, I don't remember the exact firmware version where the added the frame interpolation to the Impulse mode, but this was general the strategy of Sony for all the TV/Projector line where the Impulse mode was available.
They are still trying to improve the frame interpolation upon every update but the ghosting is still here, I'm checking frequently various models with no good news... frown.gif
post #11 of 25 Old 04-22-2014, 08:05 AM
Erik Garci's Avatar
Have you noticed any extra lag when playing games now?
Also, have you tried downgrading to the previous version?
post #12 of 25 Old 04-22-2014, 09:08 AM
Chomby's Avatar
I haven't spent enough time using it to tell if there is an increase in input lag. I wouldn't use it to game now anyway as the motion has too much ghosting.
I've tried, Sony prevent you from downgrading firmware :(
I've contacted them about it and they'll get back to me in about a week.
Chomby is offline
post #13 of 25 Old 04-22-2014, 09:42 AM
Erik Garci's Avatar
OK. Did you try doing a factory reset first?
Link: How to perform a factory reset on the TV
By the way, I have a KDL-47W802A that still has the previous version (PKG4.201AAA), and I always use Impulse (which is the main reason I bought this model), so I will avoid upgrading. I am interested in finding out how Sony will handle this issue.
post #14 of 25 Old 04-22-2014, 09:58 AM
Liked: 1518
Hi Eric, factory reset don't touch the firmware version.
post #15 of 25 Old 04-22-2014, 09:59 AM
Chomby's Avatar
A factory reset changed nothing unfortunately. I'll post here further when I get more information from Sony.
Well whatever you do, don't update your firmware. I'm kicking myself, I loved that smooth, smooth motion...
Chomby is offline
post #16 of 25 Old 04-23-2014, 09:53 AM
sodaboy581's Avatar
Quoted: 25 Post(s)
Liked: 38
This thread just legit depressed me. I was thinking about upgrading my really old KDL46EX400 bedroom TV with a 50" Sony W series TV that has Impulse mode... I kinda wanted to use it for gaming now and then... I might still be able to do it, provided the firmware with the TV in the box hasn't been updated too far... but I'm really scared with what Sony is doing with their latest firmware update. Hope they realize the mistake, fix it, and never mess it up... but it sounds like this problem has been in effect for over 4 months now and I'd have expected them to fix it already if they were going to. Pretty sad!
Will have to make sure the manufacture date of the TV I purchase, if I find one, is before November of last year and NEVER connect it to the Internet. :P
Samsung UN65KS800, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is online now
post #17 of 25 Old 04-23-2014, 05:04 PM
Liked: 1518
Hello, It's pretty difficult to locate a new unit with so old firmware, it must be from the first released models mid-2013, models that produced around (sept-november 2013) are coming loaded with the updated firmware. frown.gif
post #18 of 25 Old 05-01-2014, 09:59 PM
Chomby's Avatar
I haven't heard back from Sony's tech support, but I'm still in contact with their customer service department. They asked me to provide some footage of the ghosting so I took a few pictures and uploaded them to imgur: https://imgur.com/a/bHXAQ
Apologies for the horrible quality, it was taken with a phone camera. It does give you an idea of the ghosting though with Rayman Origins @60fps.
Chomby is offline
post #19 of 25 Old 05-11-2014, 10:42 PM
Chomby's Avatar
Hey guys, good news. I tested the new Sony KDL50W800B with Impulse mode and I can confirm it works as intended (reduces motion blur and low input lag).
I'm not sure if my panel (KDL55W802A) is faulty or if the firmware upgrade altered something.
Chomby is offline
post #20 of 25 Old 09-01-2014, 06:49 PM
Liked: 0
Hey ConnecTEDDD, any more mention on the Impulse mode being fixed in later firmware updates after PKG4.401GAA? I've been looking at the KDL40W600B and thank God I found this thread. Please reply at your earliest convenience.
Zach
Zekester3000 is offline
post #21 of 25 Old 09-02-2014, 04:00 AM
Liked: 1518
Zach
Hi, I have just checked using a lot of reference motion evaluation videosthe Sony KD-55X9005A using the latest firmware PKG4.470EUA, they have finally removed the interpollation from the Impulse mode, the frame ghosting is here, there 2 frames trails that are moving with the objects also, generally the motion resolution is very good, like It was initially when the display released.
post #22 of 25 Old 09-02-2014, 12:19 PM
Liked: 0
Thanks for the reply. So you're saying that the Impulse mode is back to what it was like before the update that made it look crappy? And I didn't really get what you were saying about the frame ghosting. Is it still there, and if so, why? Is the ghosting there when I turn on the Impulse mode, or does it appear only when I put a certain setting on?
Zach
post #23 of 25 Old 09-02-2014, 03:28 PM
Liked: 1518
Zach
Now Impulse mode has the same motion resolusion like the initial firmware release, you can see the problem that is still there (ghosting trails) if you connect your PC to your Sony and try these tests:
http://www.testufo.com/#test=photo&p...uit=0&height=0
It's something like that...
post #24 of 25 Old 09-03-2014, 08:50 AM
Liked: 0
So you think that they will fix the image ghosting soon? I'm getting extremely close to buying a new HDTV (my old 2009 Vizio LCD 720p 60hz is starting to get out of date, probably will still use it for a computer monitor)and the KDL40W600B is at the top of my list. Can you give me an overview of the Impulse mode on the KDL40W600B?
Zach
post #25 of 25 Old 09-03-2014, 08:53 AM
Liked: 1518
Zach
I have no idea if they are capable to fix that.
I haven't tested the 40W600B.
Reply HTPC Gaming
