Game overlay utility that can display CPU/GPU load? - AVS Forum | Home Theater Discussions And Reviews
Old 10-10-2013, 10:28 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
One of the most annoying things about configuring a game is that you don't always know what's holding you back. Fraps gets the job done for frame rate, but I'm wondering if there's anything similar that can overlay not only FPS, but CPU, GPU, sys memory and VRAM usage?
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 10-10-2013, 03:13 PM
moob's Avatar
Quoted: 42 Post(s)
Liked: 95
MSI Afterburner should cover it.
moob is offline
Old 10-14-2013, 11:46 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Yeah, I manger to get afterburner working as an OSD, but it caused so many compatibility issues that I had to stop using it. Maybe it'll eventually be as reliable as fraps or the steam overlay, but it's def not ready yet. It was neat to see exactly what was causing the performance issue though.
bd2003 is offline
Old 10-14-2013, 10:13 PM
Chronoptimist's Avatar
Liked: 532
What games were you using Afterburner with? I use it all the time when tuning performance in games, and have never experienced performance issues with it.
Chronoptimist is offline
Old 10-15-2013, 04:29 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
I'm sure it wasn't the game, it was all the other direct3d mods. 3d vision, modified dx9 files to make 3d vision work (helix mod), d3doverrider, and the steam/origin overlay. Afterburner was just the straw that broke the camel's back.
bd2003 is offline
Old 10-15-2013, 10:33 PM
Liked: 532
I think D3DOverrider and MSI Afterburner conflict with each other, try disabling it.
Once Nvidia introduced adaptive v-sync, I stopped using D3DOverrider. If a game has a way of implementing triple-buffering the correct way, so that there's no additional latency, it's an option within the game's menus.
Forcing "triple-buffering" via D3DOverrider generally adds an additional frame of latency, which adaptive v-sync avoids.
Old 10-16-2013, 04:36 AM - Thread Starter
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Unfortunately, adaptive vsync and 3d vision don't work together.
bd2003 is offline
