First HTPC Gaming/Theater Room Help Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-20-2013, 01:03 AM - Thread Starter
pbrandt's Avatar
I had started a thread in the Home Theater Computer section looking for help on my first build. I have learned a lot from reading through countless forum posts, members on AVS, and other websites. I was referred over here as my mindset has changed. I do like playing video games such as BF4 and COD. I am awaiting Titanfall!!! I have a PS3 currently and will more than likely get a PS4. I was thinking that there really is not much of a point to getting an Xbone since a lot of the games come out on PC. If figured why not make my budget HTPC that I was starting to order a little better and skip the Xbox.
What I care about...
Ripping DVD's and Blu-rays (also 3d)
Possibly put in a Ceton InfinitiTV4
Quiet (While watching movies. Doesn't matter when playing games)
Decent game graphics (as good as PS3)
XBMC (Should be no issue?)
Eventually setup NAS to store all movies and games on
I made tons of different builds on pcpartpicker from $350 to $1000. The one listed below is towards the top of my budget.
Here is the build I am looking at (Never built a Gaming PC so please critique my build)....
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor  ($219.95
Motherboard: ASRock Z77 Extreme4-M Micro ATX LGA1155 Motherboard  ($129.98
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($76.99
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk  ($88.99
Case: Silverstone SST-GD08B (Black) HTPC Case  ($139.99
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99
Total: $690.89
Do I need a separate GPU
I have Windows 7 Home Premium 64bit already. (WMC)
Probably just pick up a cheap Blu-ray drive
Thanks for any feedback you can provide!!!
Phil
pbrandt is offline
post #2 of 13 Old 12-20-2013, 10:39 AM
darthrsg's Avatar
Location: Barrel of Burning Trash On A Cold Skid Row Street
Quoted: 2089 Post(s)
Liked: 2523
Looks pretty close to my lowly rigg. Should be fine. I added an Nvidia GTX 550 ti for like 120 bucks to mine a while back and haven't looked back. Streams across the house with no transcoding, plays all the games with the sliders all the way to the right, etc. I don't have a bluray drive in it. Your spec looks fine for what you want.
darthrsg is online now
post #3 of 13 Old 12-20-2013, 10:52 AM - Thread Starter
pbrandt's Avatar
I was looking to add a GPU, but wasn't sure which one?
Do you think it will be quiet while watching movies or television?
pbrandt is offline
post #4 of 13 Old 12-20-2013, 11:07 AM
darthrsg's Avatar
Liked: 2523
I'm no guru but my card never spins the fans while watching movies but will fire up on games. I don't use mine in a strict home theater sense but I do use it daily. I've no doubt some here can weigh in on that aspect. I have a few USB drives that get loud sometimes but the definition of loud varies. My 360 sounds like a lawnmower and heats the room but my PC never gets that loud.
pbrandt likes this.
post #5 of 13 Old 12-20-2013, 11:50 AM
Marafice Eye's Avatar
Liked: 420
That's a great budget build for an HTPC. If you're looking for a cheaper GPU that's still got some horsepower to play games, keep an eye open for deals on the GTX 760. There's really no better bang for your buck card.
As Darth said, in almost all cases, while watching movies and such, you'll never hear the GPU fans, and heck, even during most gaming you won't either unless it starts to get crazy hot.
pbrandt likes this.
Marafice Eye <--- All gamertags listed there - Twitch TV Channel YouTube Channel
__________________________________________________ _
Marafice Eye is online now
post #6 of 13 Old 12-20-2013, 02:39 PM - Thread Starter
pbrandt's Avatar
I am not sure on this, but how many PCI slots will I need. I think the mobo that I listed will suffice.
Correct me if I am wrong but these are the items that would use these 4 slots...
Discrete GPU (1 to 2 slots)
Ceton InfinitiTV4 (1)
Phil
pbrandt is offline
post #7 of 13 Old 12-20-2013, 05:06 PM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
I just took a quick peek at a pic of the motherboard you have listed and you have plenty of slots for cards. I think it had 4 or 5 slots, so depending on how big your video card is, you still have slots.
pbrandt likes this.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #8 of 13 Old 12-20-2013, 05:38 PM - Thread Starter
pbrandt's Avatar
Unless anyone has any other recommendations I am going to start ordering parts in a few days. I will hold off on the discrete gpu for now. Probably add that in a few months.
Do prices ever tend to drop after the first of the year?
pbrandt is offline
post #9 of 13 Old 12-20-2013, 06:31 PM
darthrsg's Avatar
Liked: 2523
Yeah. Prices are all over the place. I know this is AVS and you're scum if you don't pay out the nose but I would not sweat getting an "old" card.
post #10 of 13 Old 12-20-2013, 10:14 PM
Liked: 420
A 660Ti is still a great card for gaming if you're looking for something a tad cheaper.
post #11 of 13 Old 12-22-2013, 10:58 PM - Thread Starter
pbrandt's Avatar
I ended up changing the mobo I planned on getting due to a fair amount of bad reviews. So heres the problem. No matter what board you look at they all have issues!
I switched to the following board
Asus P8Z77-M Micro ATX LGA1155 Motherboard
The only issue that I possibly see is that once I get a discrete GPU, it may overlap the PCI Express slot I will need for my Ceton InfinitiTV 4.
Does anyone else see this as being an issue?
Should I consider going to a full ATX mobo instead?
If so which model preferably Gigabyte or Asus?
Phil
pbrandt is offline
post #12 of 13 Old 12-23-2013, 09:55 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
You can put the mini slot into one of the bigger slots. It's not an issue. As long as it physically fits, it will work. PCIe cards.
pbrandt likes this.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #13 of 13 Old 12-23-2013, 09:59 AM - Thread Starter
pbrandt's Avatar
Thank You! I was reading some more and I thought that would work, but wasn't sure.
pbrandt is offline
Reply HTPC Gaming
Ceton Infinitv 4 Usb Quad Tuner External Device For Watching Digital Cable Tv On The Pc Usb 2 0 Inte
