Equalizer for PC that can be controlled via Android - AVS Forum | Home Theater Discussions And Reviews
Old 08-02-2014, 09:34 PM - Thread Starter
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
I am using iTunes on my PC, sadly the Android based remote for the iTunes does not cover the built in EQ for iTunes, is there a separate EQ that I can use that can be installed and be remotely controlled by an Android Device ?
qguy is offline
