I can't get full screen from my PC on my Sammy 5063 - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2005, 08:19 AM - Thread Starter
Jmg416's Avatar
I have been struggling trying to get the setting correct from my PC to my TV. I feel that I have tried every possible combination, but I'm sure I'm missing something. The only 2 things I've been able to do are a shrunken screen that I lose a 2 inch border around the outside. This is in "wide PC" mode. Or I can do the wide screen TV, in which case the screen goes off the edges of the monitor.
Jmg416 is offline
Old 01-07-2005, 08:42 AM
Cush1978's Avatar
The best I've been able to do is a custom resolution of 1248x702 which will have your screen BARELY going off the edge.
Cush
Cush1978 is offline
Old 01-07-2005, 09:31 AM - Thread Starter
Jmg416's Avatar
So it is not actually meant to be an exact fit? I thought the idea was to use the full screen to get a 1-1 pixel mapping. (not entirely sure what that means).
So then that leads to the question, of how do I do the custom resolution. Im using an ATI 9800 Pro, and i had planned on upgradding to the latest catalyst version tonight.
Jmg416 is offline
Old 01-07-2005, 02:29 PM
Cush1978's Avatar
I dunno. With my GeForce, I could simply add a resolution in the display settings. I didn't need Powerstrip or anything. I thought ATI had something that would "optimize" the picture for an HDTV display.
Cush
Cush1978 is offline
