The Chronicles of Riddick: Escape From Butcher Bay - Developer's Cut (PC) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-11-2005, 08:08 AM - Thread Starter
Low Roller's Avatar
I just picked up the PC version of this game. I've only played it for about an hour so far, my initial impressions are quitw favorable. I never played the xbox version(because I don't have an xbox) so I can't compare, but 've read the PC version has some extra content.
There are supposed to be a few extra parts of the game to play through, and once you beat the game, you unlock a commentary mode where you can play through the game again this time listening to the directors commentary, much like DVD extras.
The game looks fantastic, every bit as good as Doom 3. It doesn't run as well as D3 on my system, unfortunately. The good news is the game supports widescreen resolutions I'd to post a few pics, but I can't cause I broke my digital camera over the holidays. I'll at lest try to put up a couple screenshots.
I'll have more to say as I play through the game.
Low Roller is offline
post #2 of 13 Old 01-11-2005, 08:35 AM
Blkout's Avatar
Its a great game on the PC, wasn't that great on the Xbox, there is a very favorable review at Firingsquad.com
Blkout is offline
post #3 of 13 Old 01-11-2005, 03:15 PM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
It's fantastic on Xbox, I highly disagree. Especially for 14.99.
NoThru22 is offline
post #4 of 13 Old 01-11-2005, 03:31 PM
FrankJ.Cone's Avatar
Quoted: 45 Post(s)
Liked: 95
Its an AMAZING XBox game and I am sure it looks fantastic on PC. I am not sure how well its going to control though.. like Splinter Cel it relies on analog movement a great deal.
Frank J. Cone
XBox Live / Steam: FCONE
Please do not form any opinion of the content of this post, it is still in BETA.
FrankJ.Cone is offline
post #5 of 13 Old 01-11-2005, 03:43 PM
Blkout's Avatar
Almost every gaming website agrees that the PC version is the way the game should have been done.
Blkout is offline
post #6 of 13 Old 01-11-2005, 03:49 PM - Thread Starter
Low Roller's Avatar
Like the game so far.
I'm confused how I should set the aspect ratio. I'm playing on my HDTV running at 960x540. Should I set the aspect ratio to 'Normal' or try one of the '4:3-->16:9' settings or the like? These confuse me.
Here's a 4:3(960x720) res with the "Normal" aspect ratio setting.
http://img62.exs.cx/img62/8534/prisonyardnormal1bd.jpg
Here's a 16:9(1280x720) res on the "Normal" setting:
http://img87.exs.cx/img87/1374/priso...9normal3wi.jpg
And, finally, here's a 16:9 res on the "4:3--->16:9" setting:
http://img139.exs.cx/img139/9410/pri...de431691qf.jpg
What should I use for 16:9? If I leave the game set to "Normal" things tend to look right I think. "4:3--->16:9" looks squished horizontally.
The only way these settings make sense to me is if your trying to use a 4:3 res on a 16:9 monitor and have the monitor stretch the image. I've never seen this before. I'll post some more screens when I figure out how to properly run the game, lol.
post #7 of 13 Old 01-11-2005, 11:16 PM
Tabasco's Avatar
Quoted: 16 Post(s)
I just finished replaying this game on the XBOX. I really enjoyed it, though it's way too short. Even with an added level and commentary, I wouldn't want to plop down $40-$50 for it. Obiously the resolution is much higher, but I'm curious how much extra texturing there is. Anyone play both versions yet?
Tabasco is offline
post #8 of 13 Old 01-11-2005, 11:28 PM
redmodel's Avatar
can you use a gamepad for this game on the PC version?
redmodel is offline
post #9 of 13 Old 01-12-2005, 06:51 AM
Javaman's Avatar
Commentary? What a nifty idea! I wish other games would do the same.
Javaman is offline
post #10 of 13 Old 02-21-2005, 12:54 PM
mn3kgtvr4's Avatar
Anyone got this to run smoothly on their PC? Just picked up this game the other day, several crashes right away. Thought it was just config tweaking needed, but now I'm running at only 1.4 shadow detail, everything turned down pretty far, no 3D or EAX, 1024X768 (to match my projector) and still get crashes/reboots every 5-10 minutes which is NOT the case with Doom3 or FarCry or anything else. Here's my specs:
AMD 3000+
asus a7n8x nforce2
1.5g RAM
9800 Pro
Any help is appreciated as it looks like a cool game. The Riddick game forum isn't much help.
mn3kgtvr4 is offline
post #11 of 13 Old 02-21-2005, 02:42 PM - Thread Starter
Low Roller's Avatar
I don't think this will help you, but after I changed the shader model from to 2.0++ to 2.0, the game ran smooth as butter.
Your hardware looks good, plenty of power to run the game well.
post #12 of 13 Old 02-21-2005, 07:46 PM
DaGamePimp's Avatar
Quoted: 443 Post(s)
Liked: 494
I have both the Xbox and PC versions here and the PC version is superior in every way IMO [ but then I do prefer m/kb to a controller for these type of games ] .
-- No problems playing the PC version here either , runs silky smoov ;) .
------- Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #13 of 13 Old 02-21-2005, 07:55 PM
mn3kgtvr4's Avatar
Hmm, I'll have to putz around some more then. It looks like a sweet game. Thanks.
Closed Thread HTPC Gaming
