need some samsung dlp PC hook up help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-14-2005, 10:40 PM - Thread Starter
Hellraiser's Avatar
OK, Im trying to hook up a laptop to a HLN series samsung dlp through the VGA port on the TV. Seems to be many types of VGA cables...so this is the cable I found...is this ok?
http://http://www.cablestogo.com/pro...2807&sku=29606
SXGA should handle the resolution fine right...or is this all non-sense and any VGA cable will do?
Hellraiser is offline
post #2 of 7 Old 02-15-2005, 11:44 AM
Cush1978's Avatar
Yeah, any VGA cable should do, but if your video card supports it, DVI is the better way to go.
Cush
Cush1978 is offline
post #3 of 7 Old 02-15-2005, 01:01 PM - Thread Starter
Hellraiser's Avatar
Well its a laptop...and I've had a hard time finding a laptop with a dvi port on it.
Plus i've been told its better to save the dvi port for copy protected mediums...not exactly sure what that means just yet ...still researching.
post #4 of 7 Old 02-15-2005, 03:30 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
With VGA be sure to get a good quality cable [ especially for longer runs - anything over 5m ] .
------- Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #5 of 7 Old 02-16-2005, 03:16 PM
cyberbri's Avatar
Liked: 53
And make sure your laptop supports 1280x720 resolution, which is what you'll want to output to the TV (or something smaller like 1232x702 to get rid of overscan, if that's an issue for your set).
cyberbri is offline
post #6 of 7 Old 02-16-2005, 09:05 PM - Thread Starter
Hellraiser's Avatar
I'm sure its an issue with HLN's ...prob not HLP's .......but even if my laptop does not support that resolution I can use a program like powerstrip to make a custom rez right?
post #7 of 7 Old 02-18-2005, 02:44 PM
Ozy666's Avatar
That might depend on the graphics chip in your laptop. Some integrated graphics chipsets might not support it.
Ozy
Ozy666 is offline
Closed Thread HTPC Gaming
