PC gaming on an HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-03-2005, 05:20 PM - Thread Starter
kny3twalker's Avatar
ok I have the computer setup and connected to my HDTV via DVI to HDMI
and I am just trying to decide between the MX Bluetooth Combo or the MX 3100 Combo both made by Logitech
any thoughts on these combos would be appreciated
but the real reason I posted this thread was to get input on what kind surfaces do you all use for mouse/keyboard gaming on a HDTV
I currently have a tray TV, but it is too small and I hate using it
just looking for ideas
and by the way I have a Logitech Cordless RumblePad 2
when not using a mouse and keyboard
kny3twalker is offline
post #2 of 10 Old 04-03-2005, 06:22 PM
StreetPreacher's Avatar
I'd suggest the bluetooth set. If you want to be able to use them at a decent distance then bluetooth is the only way to go. The standard wireless versions I've used are only good for a few feet before cutting out. I can play Half Life 2 from my couch 20 feet away and it still works great!
StreetPreacher is offline
post #3 of 10 Old 04-03-2005, 07:36 PM - Thread Starter
what do you set the mouse and keyboard on when playing ? coffee table or do you have a better solution?
and thanks for the advice
I was kind of leaning towards the Laser mouse cause it could be used on any surface
but I am going to wait to device which bundle to get after I decide what to game on
post #4 of 10 Old 04-03-2005, 08:11 PM
kirknelson's Avatar
Here's a bunch of good solutions.
http://www.levenger.com/PAGETEMPLATE...category=5-344|level=2-3|link=IMG&cm_ven=Froogle&cm_ite=Lap%20Desk%20&engine=froogl e
kirknelson is offline
post #5 of 10 Old 04-03-2005, 09:25 PM - Thread Starter
OMG thank you
have you ever purchased anything from them
cause that exactly want I need
post #6 of 10 Old 04-03-2005, 10:44 PM
dice65's Avatar
play on the recliner ,put keyboard on lap ,mouse on right side arm rest, works good here
dice
dice65 is offline
post #7 of 10 Old 04-03-2005, 10:50 PM - Thread Starter
never seen an armrest big enough or flat enough or any mouse other than the laser mouse then would track on that stuff
every optical mouse I have tried would not track well on cloth or very smooth surfaes like wood
and therefore required a mouse pad
I am thinking about getting one the lap desk but need to decide if I want the cushion and what size
furthermore I could use this for student school work which would be nice
since I tend to do this in my bedroom
post #8 of 10 Old 04-04-2005, 10:10 PM
dice65's Avatar
my recliner is cloth and works great,no mouse pad needed, mouse and keyboard are logitech cordless internet pro, cost me $40 bucks , the recliner is about 12-14ft away from TV , the reciever sits about a foot in ft of tv
dice
dice65 is offline
post #9 of 10 Old 04-05-2005, 08:26 AM
Shkuey's Avatar
I use the logitech bluetooth combo on my couch, keyboard on lap, mouse on the couch next to me. Works like a champ.
Shkuey is offline
post #10 of 10 Old 04-05-2005, 09:29 AM
Same here.
For most casual gaming I'll just use the mouse on the couch cushion next to me, with my keyboard on the left side cushion.
If I need more accuracy then I'll grab a hard coffee table book, and set that on the cushion along with a proper mouse pad. I really only find this necessary for online FPS action though (counterstrike source, etc.).
Also, I haven't tried a 'laser mouse' but the Logitech Bluetooth set includes the MX900 mouse, which is a very capable optical mouse that will work on most surfaces. They only mouse I've had better results with is my old logitech corded optical with the dual optical pickups. I can use that one on the side of my leg and it works well :).
Closed Thread HTPC Gaming
