Opteron HW Question - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2006, 11:07 PM - Thread Starter
WirelessGuru's Avatar
Question for any nerds out there...
Can I run two Opteron 150's on a dual 940 socket board, or would I have to use Opteron 200 series processors?
Last Watched 3D: Oz the Great and Powerful
It should be called Violet-Ray
WirelessGuru is offline
Old 07-31-2006, 07:26 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
2xx required, socket 940.
1xx are socket 939, and do not have enough HT links for SMP, besides their own cores.
They are usually just Athlon 64s with 1mb L2 per core. The 165 was somewhat popular with overclockers when it was basically the same price as a 3800 X2 with double the L2 and reached just as high on clockspeeds. Unfortunately, the price cuts did not touch them at all and there are no AM2 versions. There is almost no reason to buy one today :(
Although the AM2 4000 and 4400 also have 1mb per core, they discontinued them almost immediately and did not have the price cuts. I did see a supposed lower thermal AM2 4000 on one site currently priced between the 3800 and 4200, but I'm not sure if its a misprint.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
Old 07-31-2006, 10:12 AM
DrCrawn's Avatar
Older Opteron 1xx were originally s940 actually. When AMD moved to fab 90nm from 130nm, they did not make 1xx series Opterons in 90nm (s940), instead moving the single socket server/workstation platform to s939 in order to use cheaper non-registered DDR1.
The important thing here is paying attention to the socket. SMP requires two things, s940 and either 2xx or 8xx series chips.
The old s940 1xx series Opterons were single socket server chips as well.
DrCrawn is offline
Old 08-01-2006, 12:44 PM
MC FLMJIG's Avatar
Yup was a misprint... i bought one though... if it can OC to 2.6-2.8 I'm set!!!
I'm no nerd either ;)
MC FLMJIG is offline
Old 08-02-2006, 07:03 PM - Thread Starter
Thanks for the confirmation guys. I got a good deal on a 100 series Opteron, probably because it was the older 940 socket instead of the 939 socket version. It works pretty good for me even though I should have stayed away from the VIA MB chipset. OMG, can't VIA get their driver issues straightened out?
Old 08-08-2006, 10:51 AM
DrCrawn's Avatar
i run a Asus SK8V with an Opteron 254 (officially not supported) that uses VIA K8T800 northbridge...no problems with VIA for me. Despite the board not having bus locks and using AGP, it's the most stable board I've ever used.
Don't forget you need registered DDR for s940, and I would recommend turning ECC on in the BIOS settings.
DrCrawn is offline
