The Microsoft Flight Simulator X demo is out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-09-2006, 10:21 PM - Thread Starter
chris5977's Avatar
It's on fileplanet. I'm downloading now!
PSN Gamertag: chris5977
In War: Resolution
In Defeat: Defiance
In Victory: Magnanimity
In Peace: Good Will
Winston Spencer Churchill
chris5977 is offline
post #2 of 8 Old 08-10-2006, 01:11 PM
stu1811's Avatar
Downloading...
stu1811 is offline
post #3 of 8 Old 08-10-2006, 02:56 PM - Thread Starter
chris5977's Avatar
I have the following rig:
amd 64 3400, 1gig RAM, X800XT, 1920x1200 monitor.
I tried to run it at the native rez of my monitor on medium settings and got about 1fps. It was completely unplayable. I am used to running FEAR, BF2, MSFS 2004, at this rez, so that was a bit of surprise.
I'll dial down the resolution and report back tomorrow.
In War: Resolution
In Defeat: Defiance
In Peace: Good Will
post #4 of 8 Old 08-10-2006, 09:13 PM
mking2673's Avatar
I ran medium res with all settings on highest and got about 20FPS
amd 64 3800
2 gigs ram
7800 gt
Overall it runs A LOT slower than 2004 but doesn't seem to look that much better. Maybe I need to spend more time with it.
PS3: WilliamShattner
Bf 2: WilliamShattner
Xbox live: WilliamShattner
mking2673 is offline
post #5 of 8 Old 08-10-2006, 10:04 PM - Thread Starter
chris5977's Avatar
amd 64 3800
2 gigs ram
7800 gt
Resolution?
In War: Resolution
In Defeat: Defiance
In Peace: Good Will
post #6 of 8 Old 08-10-2006, 10:45 PM
mking2673's Avatar
1152x864, I haven't tried any onthers yet.
I looks fairly acceptable at a lower framerate because there really isn't much action (as compared to racing or an FPS). Of course for a longer flight a framerate above 30 would be needed.
I played it some more tonight and again I was expecting a lot more in terms of visuals. To me the ground still looks circa 1999 and the few buildings scattered about don't cut it. I am sure the DX 10 will help, but I wonder how much. To me the framerate hit isnt worth upgrading for what appears to be smallish improvments in looks.
post #7 of 8 Old 08-12-2006, 10:50 AM
kirknelson's Avatar
Yowza, this thing is a dog. You have to have SLI to run it at acceptable settings. On my system (Athlon "Barton" 3200+, 1.5GB RAM, 6800GT) it didn't look any better than FS2000 cause I had to run everything so low.
I wish they had included some US scenery. Flight dynamics are as arcade as ever, even with the realism settings maxed, and they made the engine controls less accessable which makes flying controllable pitch props a real chore. :rolleyes:
It is still a MS sim afterall. Nice eye candy if your system can handle it, but for real enthusiasts and pilots, stick with X-Plane.
kirknelson is offline
post #8 of 8 Old 08-12-2006, 04:50 PM
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
It doesnt seem to have SLI support. I tried to run with max settings at 1920x1080 with 7900GTX SLI'd, AMD 64 X2 4200@2.5 and slide show nigtmare...also it didnt look that good either with all graphics set to max. Just luv how all the buildings pop up... :rolleyes: . Its a real DOG of a demo.
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
Closed Thread HTPC Gaming
