What's the proper way to install a motherboard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-18-2006, 12:22 PM - Thread Starter
slackeyed's Avatar
A "standoff" is the small brass threaded piece of hardware right?
Just to clarify; I would
1. Ensure that the brass standoffs are installed on the backside of the case
2. Lay the motherboard down.
3. Fasten a metal screw through the motherboard and into the brass standoff below.
And finally, what is the rubber stud/screw type piece for... the ones that come with a new computer case?
slackeyed is offline
post #2 of 2 Old 08-18-2006, 03:25 PM
kirknelson's Avatar
Yep, that's right. Just make sure all the stand-offs align with the motherboard mounting holes before you start screwing it down.
I don't know what you mean by "rubber stud/screw type piece" so I can't help you there. Might be some kind of vibration dampener since it's rubber.
kirknelson is offline
Closed Thread HTPC Gaming
