DVI-D out Video Card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-19-2006, 01:28 PM - Thread Starter
preludejtstyle's Avatar
Quoted: 21 Post(s)
Trying to find a video card that will do at least Oblivion, that also has DVI-D output. Everycard I have found only does DVI-I. Desktop PC.
Any input is appreciated.
AGP 8x btw.
I currently have a 256mb 9250 ATI, but its too crappy. But it does have DVI-D.
What's your choice today?
Follow the Rules
preludejtstyle is offline
post #2 of 7 Old 08-19-2006, 02:22 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
DVI-I accepts both DVI-A (analog) and DVI-D (digital).
MSmith83 is offline
post #3 of 7 Old 08-19-2006, 02:27 PM
kirknelson's Avatar
^^ What he said.
kirknelson is offline
post #4 of 7 Old 08-19-2006, 05:23 PM - Thread Starter
Quoted: 21 Post(s)
thanks. Anyone recomend a card that has DVI-I output that will do good for under $200? I mostly just want to play Oblivion on my new WD-65731 Mitsubishi TV.
Follow the Rules
post #5 of 7 Old 08-19-2006, 11:11 PM
Scotty L's Avatar
for $50 more a 7900GT will do ya good- http://www.newegg.com/Product/Produc...82E16814130033
i see a "recertified" 7800GT on newegg for $194 if u can't spare the change
"ANYONE who pc games that doesn't have a 360 controller for pc use, well frankly isn't a gamer at all."
Scotty L is offline
post #6 of 7 Old 08-20-2006, 04:52 AM
StreetPreacher's Avatar
Good suggestion Scotty, but unfortunately it looks like prelude is part of the shat upon AGP user group, so that card won't work.
The best card currently available for AGP is the nvidia 7800GS, but it's extremely overpriced for what you get. Unfortunately the next best thing is an ATI X850XT PE, if you can find one. An alternative is the X800XT:
http://www.newegg.com/Product/Produc...82E16814102492
I've also been looking around for a new AGP card, and there just isn't much available these days...
EDIT: Looks like you can get a recertified 7800GS for around $200. I'm not sure what kind of warranty you get on the recerts, but it's an option
http://www.newegg.com/Product/Produc...82E16814130046
StreetPreacher is offline
post #7 of 7 Old 08-20-2006, 07:28 AM - Thread Starter
Quoted: 21 Post(s)
thanks.
Follow the Rules
Closed Thread HTPC Gaming
