Madden 07 Widescreen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-28-2006, 07:04 PM - Thread Starter
xris2o0o's Avatar
Anyone know how to get widescreen in madden 07 for pc?
i have a budget bigger than my budget.
xris2o0o is offline
post #2 of 14 Old 08-29-2006, 08:19 AM
Q of BanditZ's Avatar
www.widescreengamingforum.com
Check their forums. The site has been going up and down, so be patient.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #3 of 14 Old 08-29-2006, 08:30 AM
TimBob5259's Avatar
I can't get it to run at 1280x720 to my projector. There is an ini file but if I change the settings to that resolution the game reverts back to default.
TimBob5259 is offline
post #4 of 14 Old 08-29-2006, 02:19 PM
scasmflop's Avatar
I've not been able to get it WS either... really annoying since they have so many other resolutions finally. Throw us a bone and include some WS res's. It's not like the engine work for WS hasn't already been done. I guess we should be happy that they finally support the 360 for pc controller.
scasmflop is offline
post #5 of 14 Old 08-30-2006, 06:44 AM
Troubleshooter's Avatar
I also have not gotten it to go widescreen. I changed the ini but it didn't seem like much happened. I gotta say that EA got some big stones to put this out for ~50$ on a PC...It's very mediocre imo in terms of graphics and sound but additionally, there's so many buttons to press now that I commonly screw it up. I can't figure out the mouse gestures thing after a bit of trying and just gave up and went back to keyboard.
-Trouble
Troubleshooter is offline
post #6 of 14 Old 08-30-2006, 08:14 AM - Thread Starter
xris2o0o's Avatar
ive had the same results.. kinda sucks playing the game in a tiny 1600x1200 square on a 23" monitor.. they need to fix this in my opinion..
xris2o0o is offline
post #7 of 14 Old 08-30-2006, 06:44 PM
stim's Avatar
I just checked the widescreengamingforum and found this:
http://www.widescreengamingforum.com...ghlight=madden
I'll test it out later today after I've had a chance to install.
stim is offline
post #8 of 14 Old 08-31-2006, 04:23 PM - Thread Starter
xris2o0o's Avatar
i tried it and cannot get his fix to work.. it doesnt find the hex string.
xris2o0o is offline
post #9 of 14 Old 09-02-2006, 09:01 AM
guessguy's Avatar
worked for me. I can now play in 1440x900
guessguy is offline
post #10 of 14 Old 09-04-2006, 11:18 AM
rbarbier's Avatar
What would the Hex code be for 1280 x 720 or 1216 x 692.
www.thegamefan.com
Proud owner of 3 HD DVD players and 170+ HD DVD movies.
rbarbier is offline
post #11 of 14 Old 09-04-2006, 12:12 PM
sharangad's Avatar
1280 = hex 0500
720 = hex 02D0
hex string ="00050000D0020000"
1216 = hex 04C0
692 = hex 02B4
hex string = "C0040000B4020000"
sharangad is offline
post #12 of 14 Old 09-04-2006, 02:53 PM - Thread Starter
xris2o0o's Avatar
did you have to do a fresh install for this mod to work? as in not changing the resolution at all after install? everytime i do a search on the hex string it says not found.. any ideas?
xris2o0o is offline
post #13 of 14 Old 09-04-2006, 05:41 PM
rbarbier's Avatar
I am having the same issue. It won't find that string.
www.thegamefan.com
rbarbier is offline
post #14 of 14 Old 09-04-2006, 07:11 PM
rbarbier's Avatar
Found this. Going to give it a try:
http://www.widescreengamingforum.com...pic.php?t=6299
www.thegamefan.com
rbarbier is offline
Closed Thread HTPC Gaming
