Bf2 1.4 patch probm's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-06-2006, 11:14 AM - Thread Starter
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
Anybody getting inconsistant probms after the 1.4 patch. I had to reload BF2 and all the addons twice before the Full 1.4 patch took. But now its real flakey. Some times I get errors say I have a mod'd install and kicks me off or when I try to run the new map, it kicks me. Well for me it looks like another DICE update that screwed up more then they fix...and now they want us to eventually pay to be beta testers for the BF2142.
EDIT: my BAD....The installs was at the same time as it seems as a stick of mem was going bad...tried reinstalling again but kept failing....thats another gig dead after confirming with mem test... :o
So doing an install now with just 1 gig and see what happens.
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
post #2 of 5 Old 09-07-2006, 07:49 AM
Jim S's Avatar
So what's the verdict...install or skip it? Is the new map available for co-op?
Jim
Jim S is offline
post #3 of 5 Old 09-07-2006, 08:41 AM
CoolCanuck's Avatar
I installed it a few days ago and haven't had any problems so far -- I like the new map too. Some good close quarters urban combat, combined with a bit of open-range tanks. Not sure if the map is available for co-op.
Visit the Red-Meadow Theater!
CoolCanuck is offline
post #4 of 5 Old 09-07-2006, 04:37 PM - Thread Starter
Tinker's Avatar
Basicly if you want to play online, you have to install all the patches.
Tinker is offline
post #5 of 5 Old 09-07-2006, 05:55 PM
sandiego1's Avatar
patch works without problems for me, new map is pretty nice and comparable to karkand
sandiego1 is offline
Closed Thread HTPC Gaming
