F.E.A.R. Expansion Demo Tomorrow - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-12-2006, 10:36 PM - Thread Starter
KRaK's Avatar
http://www.gamespot.com/news/6157499...stnews;title;4
Can't wait to check this out. I enjoyed FEAR.
KRaK is offline
post #2 of 10 Old 09-13-2006, 09:45 AM
Q of BanditZ's Avatar
I'm so all over this it's not even funny.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #3 of 10 Old 09-13-2006, 10:51 AM
Joe_M's Avatar
That's sweet. Can't wait for the next release.
There is no "best", best is what's best for you...
Have you tried searching first?
Joe_M is offline
post #4 of 10 Old 09-13-2006, 01:19 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 92
Interesting..why would they release a demo of an expansion...thats kind of odd. Has anything significantly changed?
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
post #5 of 10 Old 09-13-2006, 01:29 PM
Not really. Just more of the same except done better. More open areas and a little bit more diversified level design as well.
post #6 of 10 Old 09-13-2006, 05:58 PM
Statix's Avatar
Unfortunately there is no built in widescreen support. here is the hack for the original game:
http://www.widescreengamingforum.com...pic.php?t=5713
However, this demo does not seem to have the same setup. I have not found a solution yet. If you find a way to make widescreen work please post it here.
Statix
Statix is offline
post #7 of 10 Old 09-14-2006, 07:33 AM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
I just got off a 12-hour work day, so I didn't get to play much at all. All I can say so far is that it's thankfully more of the same and runs smoothly.
Statix,
To run the hack, do the same thing as you did for the original FEAR, but do it in the TimeGate Studios folder at this path: Documents and Settings\\All Users\\Documents\\TimeGate Studios.
By the way, if anyone finds out how to enable EAX Advanced HD in this demo, please let me know.
MSmith83 is offline
post #8 of 10 Old 09-14-2006, 03:26 PM
Statix's Avatar
MSmith,
Thanks for the hack.
One question for you, do you notice much difference between eax 2 and 4?
Statix is offline
post #9 of 10 Old 09-14-2006, 04:16 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
EAX Advanced HD works fine for this demo. The problem was that I forgot to change the audio mixer from Audio Creation Mode to Game Mode. I have EAX effects disabled in Audio Creation mode.
The difference between the two definitely depends on the game that you're playing.
In the original FEAR, the only major difference I could tell is that occlusion effects were implemented in the developer's use of EAX Advanced HD and not with EAX 2. So an explosion or gunfire in one room, for instance, would get muffled if you run behind a wall or enter another room. The sound effects get occluded. EAX 2 apparently introduced audio occlusion, but I haven't heard it used in games using EAX 2. FEAR was a disappointment to me with regards to actual reverb effects, in that the game's limited number of different environments hardly ever allowed for a reasonable use of different effects, and the game used little variation in environmental effects in instances where there could have been much greater variation.
Games like Ghost Recon Advanced Warfighter, Doom 3 and Quake 4 are different stories though. With EAX 2 in general, you can only hear the same environmental effects at once, and there is no fluid transition for these effects.
In the case of Ghost Recon Advanced Warfighter, an example is running from an open space to a narrow alleyway while a squadmate is shouting to you. When entering the narrow alleyway, your squadmate's voice gets a distinctly different echo added to it. Likewise, in Quake 4, running from an outside open space to an interior while constantly firing a weapon results in vastly different reverb effects that change on-the-fly. The effects change exactly at the moment you enter the new environment.
An example difference that is accentuated by Quake 4's environments is the overall positioning of effects. For instance, the sound of enemy fire coming from the rear-right room will sound different from enemy fire coming from the front-left corridor, and the difference in effects can be heard at the same time.
These are just practical examples of the effects added with EAX 3, 4 and 5.
MSmith83 is offline
post #10 of 10 Old 09-14-2006, 08:13 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 92
I couldn't get the hack to work, must be doing something wrong.
The demo was ok, but kinda felt "been there, done that"...I could be FEAR'ed out :)
Closed Thread HTPC Gaming
