Which Front Projector for variety of PC games at different resolutions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-14-2006, 11:14 PM - Thread Starter
drizzo4shizzo's Avatar
Hello all
I need a (preferably 16x9 capable) projector which I can also use to play my PC games, some of which only support traditional resolutions like: 640x480, 1024x768, 1280x1024, etc.
I don't need flexible placement and have pretty good light control, but I'd like to focus on what the projectors can do with their scalers and various input resolutions.
1. What I want to know is can a 1080p model display 1280x1024 from a PC without scaling?
2. How does a 720p model look with a 1024x768 signal fed to it? I may go for a 1280x768 model instead - I assume this works well?
3. What happens when I shove a super low res picture like 320x240 of something across to the PJ. Think MAME, ie pac-man, frogger, etc. I want to get that "The Frogger is bigger than your HEAD" effect :D These ROMs all have different (usually very low) resolutions - will any PJ out there blow these up to the max size preserving aspect ratio?
4. Can these PJs just take a standard pixel-mapped input signal of the panel resolution and display it 1:1? If so - would I have to play games with the refresh rate to get this working?
Any other related comments or suggestions?
Dan
drizzo4shizzo is offline
post #2 of 2 Old 09-15-2006, 10:17 AM
Snype32's Avatar
I am using a Mits. HC-3000. It sports a native res. of 1280x768, and 1024x768. It does both 16:9 and 4:3. It works very well, and I have been very happy with it.
http://www.projectorcentral.com/Mitsubishi-HC3000U.htm
don't let the lumen rating fool you... this projector is bright...
Snype32
Snype32 is offline
Closed Thread HTPC Gaming
