got new pc, vista premium--what else do I need for HD DVR ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-18-2007, 07:49 PM - Thread Starter
gdog2004's Avatar
I currently have a dual tuner dvr thru the cable company and I am happy with everything but the HD space. Its a moto 6416 and it cant be expanded.
The PC I got is a AMD X2 4200, 1gb of ram and it uses onboard graphics(I know this has to change) .
I have a 50" a2000. Is using the pc instead of the dvr a good option ? My pc has vista home premium installed.
thanks for any help.
gdog2004 is offline
post #2 of 2 Old 04-19-2007, 06:29 PM
Trebuken's Avatar
You should check out the HTPC forum. You will want a good capture card, and a good front-end (Media Center maybe if it is included with premium).
Other than that, a dedicated hard drive and a lot of patience tweeking everything is about all you will need...
Trebuken is offline
Reply HTPC Gaming
