Official Bioshock for PC thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 202 Old 09-01-2007, 01:10 AM
DrCrawn's Avatar
Originally Posted by SpeedyHTPC View Post
Does anyone have a clue why I'm getting that dreadful bioshock.exe has faulted in c000005? I am already using nvidia's beta drivers 163.44 and trying windowed mode in XP SP2 compatibility on my Vista 32 bit basic system.
I was starting to enjoy it then it crashes everytime about 3 min into the game. Loading part is fine.
http://www.nvidia.com/object/windows..._hotfixes.html
Give this a try.
I've only played the demo, but really enjoyed that. I'm amazed at how well it looks and runs. I'm buying the game tomorrow.
DrCrawn is offline
post #182 of 202 Old 09-01-2007, 12:30 PM - Thread Starter
DaverJ's Avatar
Quoted: 1036 Post(s)
Liked: 3471
Give this a try.
Even though I wasn't haven't problems, thanks for that link too! Always good to get updates like that, just in case.
DaverJ is online now
post #183 of 202 Old 09-01-2007, 04:36 PM
Trebuken's Avatar
Yeah this about as good a game as there is. It definitely has widescreen issues but I managed it well enough.
I played it in Vista/DX10 with everything turned on (visually) and at 1920x1200. I have a Core2 E6600, 4GB RAM, RAID 0, and that 8800 GTX thing and according to fraps (and with no tinkering) I was getting 45-75 fps. Nothing is overclocked so it is quite impressive how much this game delivers in the fram-rate department as compared to say Lost Planet.
The game was awesome; the hacking was OK, reminds me of a game called Pipe Dreams, and you can almost get enough hacking tools to open every safe if you are careful. The free saves are a little to convenient but the game is story driven enough that you shouldn't worry about it. I reload my saves almost every time I died anyways.
The final confrontation was too easy but it wasn't bad.
Anyone know about the different endings in the game, and if you are rewarded with a longer ending if you save/kill all the little sisters or beat it on hard mode?
Trebuken is offline
post #184 of 202 Old 09-01-2007, 05:03 PM - Thread Starter
DaverJ's Avatar
Liked: 3471
Any responses to this ^^^, please put in a spoiler safe response.
FYI: Spoilers-safe posts have the word "spoiler" with no quotes surrounded by the [] brackets and ending with "/spoiler" no quotes surrounded by the same brackets, much like this:
post #185 of 202 Old 09-03-2007, 08:21 AM
SpeedyHTPC's Avatar
Quoted: 28 Post(s)
Give this a try.
Thanks. The only patch that wasn't on my system is KB940105 and I dont have SLI.
This is a Dell 9200 standard with nothing but a DVD, BFG 8800 GTS 640, Vista basic 32 bit and a Dell 2405. I can't believe it crashes on the game while others can run it well. Its not even hand built.
Same crash as before with all those patches installed.
Problem signature:
Problem Event Name: APPCRASH
Application Name: bioshock.exe
Application Version: 1.0.0.0
Application Timestamp: 46b7d7a9
Fault Module Name: StackHash_e17d
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 00000000
OS Version: 6.0.6000.2.0.0.768.2
Locale ID: 1033
Additional Information 1: e17d
Additional Information 2: 3be9f8a50bddd4313bd572f57066c49b
Additional Information 3: 81dc
Additional Information 4: aa162d78020c3d2d8202ca7dabeada06
Metroid Prime 3 is taking more of my time now as Bioshock fades away.
PS. I would try running it in dx9 mode but how the hell do you get it to run in dx9 when downloaded from Steam? the link shows "applaunch 7076" and I dont think putting a -dx9 is passed to the game.
Toshiba TLP-650, Infocus 4805, Panasonic AE2000, JVC DLA-RS400U
HK AVR-8000, Yamaha RX-V681BL, Sansui (yes they were awesome)
SpeedyHTPC is offline
post #186 of 202 Old 09-03-2007, 11:22 AM
kirknelson's Avatar
In my experience "hand built" systems are far more stable than mass market units. Especially when adding after market hardware like your 8800GTS.
kirknelson is offline
post #187 of 202 Old 09-03-2007, 11:42 AM
DrCrawn's Avatar
Either right click on your desktop shortcut or hit start/all programs/steam, then right click on Bioshock, select properties and change your settings under the compatibility tab.
Good luck.
DrCrawn is offline
post #188 of 202 Old 09-03-2007, 02:13 PM - Thread Starter
DaverJ's Avatar
Liked: 3471
right click on your desktop shortcut Bioshock
Hey... cool -- I right clicked on my BioShock Demo desktop icon and in the menu there's an option that says "Play DirectX9"!
I hope all DirectX 10 games have this option.
post #189 of 202 Old 09-03-2007, 05:02 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
I've been playing the game all day and it just doen't cease to amaze me. The Boston Phoenix gave the 360 version a 10 out of 10, and the PC version deserves it too. I really need a better videocard though, even running it at 1280x800 on my system is really taxing it. Whenever a Big Daddy luimbers closeby it slows down...
Love the sound too. If you don't have a Audigy based card that supports OpenAL, you're really missing something.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #190 of 202 Old 09-03-2007, 05:29 PM
SpeedyHTPC's Avatar
Quoted: 28 Post(s)
Good luck.
My Steam must be something newer or whatever. The place where I put "-dx9" is in the advanced launch options for the game in the Steam menu. Anyhow, I did initialize it in dx9 and it still crashed in the same spot. Perhaps I'm just not looking in the right place. It is strange that none of these anecdotes made a single difference.
If I have to reinstall the OS, I would, heh. Nothing really on this PC, just games and a terminal to my unix boxes.
Yeah I would too if I had the same experience. The 8800 GTS is questionable. Its too bad that the Nvidia support on the GTS is iffy.
post #191 of 202 Old 09-04-2007, 05:39 AM
Libertarian's Avatar
For those wondering about different endings. Yes, there are two different endings to the game. I believe you need to rescue all of the little sisters to get the "good" ending.
There is also a bonus plasmid you get after saving the first three little sisters...and a more powerful version after you save a few more (and do some research on the big daddys.)
No spoilers, but I think you'll find this particular plasmid VERY useful. Go get it!
Libertarian is offline
post #192 of 202 Old 09-05-2007, 03:57 PM
Steve Tack's Avatar
I finished the game a few days ago and got the "good" ending. If anybody wants to describe the other ending (in spoiler tags!), I am a bit curious about it, but I'm not sure I want to replay the game just to see it.
Steve Tack is offline
post #193 of 202 Old 09-05-2007, 07:35 PM
I didn't think the "other" ending made much sense...and it only lasted about 15 seconds.
Doesn't really matter to me anyway...The gameplay is what it's all about.
If you want to see it, just google "bioshock ending" and click the video tab on top of page.
post #194 of 202 Old 09-06-2007, 07:49 AM
Troubleshooter's Avatar
Too funny...I got the evil ending and I honestly didn't understand it either! I thought it was just me.
-Trouble
Troubleshooter is offline
post #195 of 202 Old 09-07-2007, 12:34 AM
rsra13's Avatar
I just finished the game, good ending.
The whole game was a really amazing experience.
So, what to play now?
rsra13 is offline
post #196 of 202 Old 09-07-2007, 10:49 AM
SpeedyHTPC's Avatar
Quoted: 28 Post(s)
I just started again. Miraculously, a complete OS reinstall and nvidia beta drivers, ms hotfixes, vista updates, redownload and reinstall of Bioshock allowed me to play again. Its funny how I see the same freezing reported on 360 platform.
One additional item, if it helps anyone, is that I have to manually set the resolution in default.ini to what I want it, otherwise I get a tiny window on my 1920x1200 desktop. Something in the Vista update won't allow the game to change resolution.
post #197 of 202 Old 09-07-2007, 09:22 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
Oh man. I just had a super huge crash today and could not recover at all. I had to do a totally fresh install of Vista64, and I was so close to the end of BioShock too.
Now let's see if I can somehow salvage my saves because I am no way playing through the game again. If I can't I'm going to pitch a fit.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #198 of 202 Old 09-08-2007, 06:45 PM
rsra13's Avatar
how did that happen? the windows vista crash?
I love Vista, but after 2 months with it I think I could have waited for SP1. But no, I really*needed* DX10
rsra13 is offline
post #199 of 202 Old 09-08-2007, 06:51 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
I have a short in my case somewhere. I really need to replace it, but it's a pain in the ass to transplant all my hardware to a new case, and don't want to bother until it's time to buy a new motherboard.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #200 of 202 Old 10-10-2007, 07:42 AM
Wytchone's Avatar
Quoted: 36 Post(s)
Liked: 48
Bioshock on vista looks amazing. I know im late to the party but it really is a fantasic looking and fun game.
Wytchone is offline
post #201 of 202 Old 11-24-2008, 06:38 PM
WJonathan's Avatar
Bioshock PC is 9.99 at Circuit City this week.
WJonathan is offline
post #202 of 202 Old 11-24-2008, 10:20 PM
BreakStuff's Avatar
jeez... I just purchased it a month ago on Steam for $19.99, at $9.99 its a steal as long as you have the proper horsepower to play it. Great game.
Visit me at petedz.com
BreakStuff is offline
Reply HTPC Gaming
