Denon DVD3800BDCI Owner's Thread - Page 26 - AVS Forum | Home Theater Discussions And Reviews
Old 03-20-2008, 10:00 AM
jsteinhauer's Avatar
Originally Posted by RUR View Post
and I get the same results i.e. it works on SM3 and does not work on Fifth Element. Are we sure the test patterns are on the FE disc?
7669 works on Dogma, as well.
jsteinhauer is offline
Old 03-20-2008, 10:01 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Yep, I have accessed them with my Pioneer Elite BDP-HD1. I don't have SM3. I will have to look to see what other Sony / BMG discs I might have.
Interesting...thanks.
Mark
giomania is offline
Old 03-20-2008, 10:02 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Originally Posted by bferr1 View Post
Make sure you are truly at the main menu and not on a set up or special features tab. 7669 only works from the true main menu, not a sub-menu.
Pretty sure I am...the disc "boots" to that menu.
Mark
giomania is offline
Old 03-20-2008, 10:48 AM
banjofan's Avatar
Originally Posted by Anthony A. View Post
do you own both and have you actually done a true side by side comparison?
yes i own both...i chose these titles because they both have alot of film grain...it is distracting on the xa-2 but much smoother on the 3800 to the point where its really not distracting at all
banjofan is offline
Old 03-20-2008, 10:55 AM
banjofan's Avatar
Originally Posted by FilmMixer View Post
Don't forget that AVS is also a Denon dealer
i got mine from AVS...good price and fast service...
banjofan is offline
Old 03-20-2008, 10:57 AM
banjofan's Avatar
Originally Posted by John Ballentine View Post
You had to decrease brightness a ton because Denon defaults to 7.5 IRE instead of "0 IRE" If you like you can change this in the Realta menu "setup level" and put your brightness back to normal.
how do you get to the realta set up menu?
banjofan is offline
Old 03-20-2008, 11:26 AM
mcjimsey's Avatar
Liked: 26
While playing a disc hit "Mode" then "Enter" (Unforntunately it does not come up when paused )
mcjimsey is offline
Old 03-20-2008, 11:41 AM
haggisbingo's Avatar
Quoted: 35 Post(s)
Originally Posted by eulogytool View Post
I'm talking about when I have the 3800 decode the 7.1 DTS-MA soundtrack on Pans Labyrinth, and send the PCM to my 9.8 The 3800 shows DTS-Master but my 9.8 only shows 5.1 PCM. I have the 3800 set to 'HD-Audio' and the output set to 'LPCM'.
I forgot I have X-Men The Last Stand, which is DTS-MA 6.1. So I tested that, the 3800 decoded it, and it shows 7.1 PCM on my 9.8, which I assume is normal, even though it's a 6.1 soundtrack. Anyway, at least I get the back channels that way. Either way, it's no biggie to me, since I can just bitstream.
So, just to let folks know that there may be something wrong with the decoding of 7.1 DTS-MA on Pans Labyrinth, and sending the PCM over HDMI. Since the 3800 is the first and only player that can actually decode DTS-MA, there's really no way to tell, but I am betting that it's just something with Pans Labyrinth, since other 7.1 discs seem to be decoded fine.
Pan's Labrynth is definitely coming out 7.1 on my 3800bd. I'm running analog 7.1, though. If your 3800bd is saying DTS-MSTR and you checked the settings on it so that it is not suppressing the back 2 channels, then it must be some setting in your receiver. Otherwise, why would it work on analog and not HDMI?
"Shoot Em Up" is another (and not so subtle) 7.1 DTS-MA disc to test. You'll definitely be able to hear if the back 2 speakers are working properly...
haggisbingo is offline
Old 03-20-2008, 11:55 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Forgive the ignorant question, but how did you buy one from AVS? What was their price? PM me if you want. Thanks!
bferr1 is offline
Old 03-20-2008, 11:58 AM
eulogytool's Avatar
I don't know, it worked fine with X-Men. Regarding analog, doesn't the 3800 decode DTS-HD fine over anolog, but not HDMI? So apparantly, there are some differences. I'll keep playing around with it..
eulogytool is offline
Old 03-20-2008, 12:00 PM
shamus's Avatar
Quoted: 23 Post(s)
Mark
It doesn't work on the 2500 either!
shamus is offline
Old 03-20-2008, 12:03 PM
shamus's Avatar
Quoted: 23 Post(s)
Originally Posted by EWL5 View Post
I'm using the normal DVE and not "Pro."
I will give the "SOURCE DIRECT" a try. This is my understanding of SOURCE DIRECT: with "SOURCE DIRECT" on, I will get the unadulterated soundtrack straight to my receiver. With it off, the speaker sizes chosen will dictate how the LFE is redirected to the subwoofer based on crossover in the 3800. Is this correct?
If you are using a 1.3 receiver that can can handle the decoding bitstream, or an older HDMI receiver that can do the bass management when sent PCM, than source direct should be set to on.
shamus is offline
Old 03-20-2008, 12:04 PM
Health Nut's Avatar
So are studios mixing 7.1 discrete tracks as a new trend? I assume that the old trend of just using the commercial theater mix is no longer done and that home theater is such a large market that studios re-mix for a home theater soundtrack? This is great news, but it means I'm going to have to go from 5.1 to 7.1 sometime in the near future... which is expensive considering I use (5) B&W N802 and (5) Bryston 7BST per channel... nonetheless, if the mixes are going 7.1, I'll have to upgrade to 7.1 as well.....
I imagine I'll have to put the side channels at 170-180 degrees (directly to the side or slightly forward), and the surround channels at 190 degrees or greater (typical surround position as in the current 5.1)
Health Nut is offline
Old 03-20-2008, 12:22 PM
EWL5's Avatar
Is it safe to assume that since the Source Direct is OFF by default that this machine is catering to the analog crowd?
Pioneer broke my heart.
Denon broke my wallet.
Oppo broke my thinking.
EWL5 is offline
Old 03-20-2008, 12:36 PM
shamus's Avatar
Quoted: 23 Post(s)
Probably just a decision to not hide that feature to people who don't read manuals.
shamus is offline
Old 03-20-2008, 01:22 PM
FilmMixer's Avatar
Quoted: 1727 Post(s)
Liked: 2085
The prep that is going into home video releases hasn't really changed over the last 5 years, i.e. studios that have been putting time and effort (i.e. Disney, Sony, New Line, Lions Gate, MGM, etc.) into doing it still are, and those that were not haven't made any huge strides towards doing anything differently.
In regards to 7.1, New Line and Lions Gate are very pro active about it. Most other studios that I have spoken with aren't running to jump on that bandwagon as of yet... there are some interesting developments coming, but it isn't going to be the norm anytime soon.
And I know this gets into a long discussion, but even when we do make home theater masters, it is rarely much different from the theatrical mix... we mainly compensate for the differnt reference levels, bass management and the like that exist between the theatrical and home environments.
FilmMixer is online now
Old 03-20-2008, 01:38 PM
Health Nut's Avatar
Thank-you... I love any development that will improve home theater... I just love D-Box, discrete tactile, etc...
Old 03-20-2008, 01:46 PM
vdibona's Avatar
Hello,
I just received my 3800 this week. When I hooked it up to my Panasonic plasma TV, I noticed the brightness of the picture was too bright. It is much brighter than any of my other Blu-Ray and DVD players. I have to reduce the brightness control on the TV to -5 (it was 0 originally). The 3800 video controls appear to be all set to standard levels. The technician at Crutchfield was not able find a solution. I am only using the HDMI connection. Can anyone help?
vdibona is offline
Old 03-20-2008, 02:02 PM
banjofan's Avatar
you can get their number from www.avscience.com and they can give you details...i also got my sony vw60 from them last fall...
banjofan is offline
Old 03-20-2008, 02:15 PM
thebland's Avatar
Quoted: 1501 Post(s)
Liked: 852
Originally Posted by vdibona View Post
Hello,
I would guess you have some sort of default setting on with your 3800 that is not a default in your other sources...... That said, post calibration, all should look the same if you can save each source into its own memory.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Old 03-20-2008, 03:02 PM
Mr. Integration's Avatar
Quoted: 162 Post(s)
Liked: 91
for anyone using a lexicon 12hd and this unit. Are you using hdmi and can you get DTSMAHD and which settings do you use?
I know it sounds great and looks great.....but can we communicate with it? If not it is useless:)
Mr. Integration is offline
Old 03-20-2008, 03:19 PM
WestCoastD's Avatar
Quoted: 257 Post(s)
Liked: 96
This is my understanding of SOURCE DIRECT: with "SOURCE DIRECT" on, I will get the unadulterated soundtrack straight to my receiver?
sort of how I understand it, the track is sent "full-range" (or "raw") for the processor to "tweak".
WestCoastD is online now
Old 03-20-2008, 03:37 PM
Hello,
Somehow, the IRE setting "issue" should be at the forefront of this thread. It keeps cropping up. vdibona, set the IRE to zero, instead of 7.5, and you will likely be fine.
Old 03-20-2008, 04:00 PM
EWL5's Avatar
Not exactly. I changed my IRE to 0 and tried recalibrating but the BTB bar disappeared on me on DVE no matter how high the brightness setting goes. Changed back IRE to 7.5 and the BTB bar reappears. I've seen this happen on other devices but letting others know sometimes you don't have a "choice."
EWL5 is offline
Old 03-20-2008, 04:27 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2526 Post(s)
Liked: 3174
That's correct. Some devices will clip Blacker Than Black or Peak White data with one setting and not the other, and it could be EITHER setting that has the problem. Obviously to test that you need to know that your DISPLAY (or intervening AVR) doesn't have its own problem clipping this stuff.
I'm not sure we've actually confirmed whether or not the 3800 has this problem with either of those settings (independent of which setting might be best for working with any given display).
The above is for Component (ANALOG) video output.
For DIGITAL video output (HDMI or DVI) the "correct" choice for RGB data format output for home theater use is "Studio RGB" -- i.e., "black" is encoded as digital 16 instead of digital 0. Blacker Than Black data goes in the range from 1-15 if it hasn't been mistakenly clipped. [NOTE: Technically there is no such thing as "IRE" setup level for Digital video. IRE setup level is a concept that only makes sense for Analog video. This hasn't kept some clever product marketing types from confusing these concepts in menu entries and manuals -- see below.]
Using "Extended or PC RGB" (black encoded as 0) means you HAVE TO lose Blacker Than Black data because there is no such thing as pixel values less than 0 -- i.e., there's no data range to hold that stuff.
Using YCbCr output for HDMI should automatically get you "black"=16 for home theater devices, so the choice here for digital video output usually only rears its head when using RGB output data format. Note that YCbCr (and in particular YCbCr 4:4:4) is the normal default data format for HDMI connections and RGB (either Studio or Extended) is the normal default for DVI connections.
Some devices have a screwy user interface where they make this choice for DIGITAL video using the IRE 0 or IRE 7.5 setting that actually only makes semantic sense for ANALOG video. And some devices have two separate controls -- an IRE setup level for Analog and a Blacks setting for Digital where the Blacks setting has two choices -- which could be labeled just about anything. The weirdest situation however is when even devices with two separate menu items like that STILL alter the Digital video output if you change the IRE setup menu item (or the Analog output if you alter the digital Blacks setup item).
Again, I don't know that we've had enough reports here to know if the 3800 runs afoul of any of these mistakes. We've had a couple reports here that the 3800 may not be sending out the correct DIGITAL video according to these settings, and I'm wondering whether there might be a setting conflict between the Analog and Digital video sides of the setup stuff that might be causing this.
This is just background for folks testing the 3800 and for folks trying to get its video levels properly calibrated using controls in the 3800 and in their display.
And the last gotcha here is that far too many devices treat 480i video specially -- either Component 480i or HDMI 480i. That means testing this stuff needs to be done BOTH for 480i and for whatever other output resolution you commonly use. And again, to test it, you need to know you are using a display (or AVR) that doesn't have its OWN problems with 480i.
We haven't had any good reports here yet on how well the 3800 handles 480i output (either Component or HDMI) -- an item of interest to folks who want to use an external scaler for SD-DVD viewing for CIH screen setups for example.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 03-20-2008, 04:54 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Do you already have the BD version of DVE or are you referring to the SD DVD version?
Mark
giomania is offline
Old 03-20-2008, 05:25 PM
EWL5's Avatar
Mark
SD only. BD version comes out next Tue, I think. But the results concerning BTB are still valid.
EWL5 is offline
Old 03-20-2008, 05:38 PM
Quickster2's Avatar
Originally Posted by jdmi View Post
The Gramophone in Birmingham is supposed to have some on order. A previous post indicated that 6ave.com had some. I ordered mine from them on 3/15, and it should be arriving tomorrow. I didn't feel like waiting. I can't wait to try it out. I'll give my impressions on how it performs with my analog setup.
I talked to the Gramophone as well. I ordered mine today from Audio/Video System in Royal Oak. I have bought all my audio equipment from them (Klipsch & Denon). Brian Scott gives me a decent deal. Thanks for your reply.
Quickster2 is offline
Old 03-20-2008, 05:39 PM
EWL5's Avatar
--Bob
Bob, I can try sending 480i from the 3800 using HDMI and then my TV will scale to the native rez. What should I test?
EWL5 is offline
Old 03-20-2008, 05:57 PM
Read the FAQ!
Liked: 3174
Use the SD-DVD version of Digital Video Essentials.
Confirm that the video calibration to your display which appears to work best for Blu-Ray discs and upscaled SD-DVD discs ALSO works best for SD-DVD discs when output as HDMI 480i from the player. I.e. that the levels that are correct in your TV for Blu-Ray or upscaled SD-DVD don't have to be changed to view SD-DVD at HDMI 480i.
Then double-check that both the Blacker Than Black and Peak White data are present. For Blacker Than Black you will need to temporarily raise Brightness in the Display as you know. For Peak White check that the region that's whiter than the marker dot in the DVE gray scale ramp is distinguishably brighter than the Reference White point marked by that dot. For this last test to be meaningful, you need to know the calibration levels you are using in your Display actually allow it to render Peak White above Reference White distinguishably. If Peak White seems to be clipped to the same level as Reference White try temporarily lowering the Contrast setting in your Display to see if Peak White becomes distinguishably brighter than Reference White.
Run through the other test patterns on DVE to see if you spot anything unexpected compared to what you already have seen when output from the player at higher resolution.
One thing to look for is whether the 3800 crops pixels around any of the edges when set to HDMI 480i output. Another thing to look for is whether the Color Upsampling Error (CUE) appears to be present for HDMI 480i output.
Finally, if you are also using HDMI for audio, confirm that the traditional DD5.1 and DTS from SD-DVDs transmits as expected over HDMI even when it is set to 480i.
If you are not comfortable with any of these tests, please feel free to do just what you know how to do and report that. Any reports at all would be helpful at this point.
--Bob
Denon Dvd 3800bdci Blu Ray Disc Dvd Cd Player
