**WARNING** DTS Masters bitstreamed to Yamaha, Onkyo or Integra can damage speakers!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 2245 Old 03-18-2008, 11:41 AM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Originally Posted by Kris Deering View Post
The 2500. I am reviewing it for Home Theater.
Cant wait. Can you post a link in the owners thread when youre done?
shamus is offline
post #92 of 2245 Old 03-18-2008, 11:50 AM
kinglerxt's Avatar
I retested Chronos using the Dolby Digital 5.1 signal instead of the DTSHD sound and there was no loud pop. Rewound and tried again and still nothing so its definitely only the DTSHD source track that has the pop issue on Chronos
"We each pay a fabulous price, for our visions of paradise. But a spirit with a vision, is a dream with a mission" - Rush
kinglerxt is offline
post #93 of 2245 Old 03-18-2008, 11:56 AM
kinglerxt's Avatar
Agreed
Yes its very loud like a loud gun shot or firecracker pop and yes it scares you when you are listening to the soundtrack at normal or above normal levels for movies and it just hits you all of a sudden and you cringe in fear that your speakers are now toast. Luckily they arent but surely they cant take that kind of abuse over and over without some damage if it happens again and you dont know when it will happen
You guys just don't get it. That is not what we are talking about. That pop is just a break in the digital signal. Things have been doing that since the DVD days. That is why so many AVRs and SSPs have adjustable muting for digital signals. This is not a simple pop. If you heard this it would scare you to death.
post #94 of 2245 Old 03-18-2008, 11:57 AM
Kris Deering's Avatar
Quoted: 2015 Post(s)
Liked: 3150
The review is for the print publication. I am not sure if it will be appearing online or not.
My Home Theater
Kris Deering is online now
post #95 of 2245 Old 03-18-2008, 11:59 AM
Midwest User1's Avatar
Originally Posted by jsmiddleton4 View Post
The Fly is the disk I, and a handful of others, have an issue with. Being reported with other disk now as well.
Panasonic BD30 with firmware 1.6 but also did it with firmware 1.4. Yamaha 1800, full range speakers and Klipsch subwoofer.
Have to laugh at folks dissing equipment being "over loaded", cables, etc. This is NOT a cable issue. It is NOT a POP. Those who have experienced it know exactly what is meant and once you do, you'll understand that pop is no where near the idea.
The problem with using the disk on other equipment is whose? Just who do I ask to play back a disk that can potentially damage their speakers? Would you want me asking you?
There is something in the coding, disk media, something, and it is at precisely the same spot for those of us having it with The Fly. It is no universal for all The Fly disk. There is a batch of them that have the problem. So just because The Fly plays fine in one set of equipment does not then mean it is our equipment. It means you have a good disk.
The disks that have the problem need to be put in a lab and tested to see what it is. Fox apparently didn't even bother but just sent me a replacement disk that does the same thing at exactly the same spot.
"...quick burst of bass." Yes but given my dog's response and quick fearful exit I believe it is full spectrum and not just bass. Clearly hurt her ears.
You're correct and that is why I mentioned the sound may very from system to system. It depends on the type of speakers, receiver/amps, and speaker settings that will impact the actual sound one hears. In my case it sounded like a loud bass pop probably because of my overall system settings/system.
Most importantly though for anyone wondering if they've got this issue is the sound is significantlly louder than what the moive track is playing at.
The good news for me is that I'm very confident that it's the disk that has the problem and NOT our equipment.
Midwest User1 is offline
post #96 of 2245 Old 03-18-2008, 11:59 AM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Originally Posted by kinglerxt View Post
Agreed
It hasn't happened to me, but Im a little hesitant to watch any DTS movies now. I listen at very loud volumes and something like that would certainly damage several thousand dollars in equipment.
shamus is offline
post #97 of 2245 Old 03-18-2008, 12:03 PM
kinglerxt's Avatar
Agreed unless you could just dump it to a PC recording device with no monitor speakers hooked up but since its DTSHD you cant take the sound out from the optical due to the copy protection so only way to record it would be thru the air
Of course that should only be done with someones crappy speakers they are willing to lose if it causes damage
Not going to do it on my set
They are already older and I cant afford any more new speakers with all the cash Ive spent in the last 4 months on my HT setup
It is such a quick transient that it would be hard to capture and do justice. Plus I would never recommend reproducing the noise at any normal listening level.
post #98 of 2245 Old 03-18-2008, 12:13 PM
kinglerxt's Avatar
Absolutely agree
I had my volume at around 65 (absolute 0-100 scale) on my Onkyo AVR when I was playing Chronos and heard the bang/pop. It had to be easily 10-20decibels louder than what was playing at the time, which in the case of the Chronos segment that gives the pop/bang!! (38:50 to 38:55) that is playing a slow organ tone with lows and highs mixed together. No way you could miss it. Someone outside my house could of probably heard it, never mind someone in the other rooms of the house, if someone else had been home with me at the time, would have definitely scared my wife or son big time
post #99 of 2245 Old 03-18-2008, 12:29 PM
Fanboyz's Avatar
Quoted: 527 Post(s)
Liked: 162
I say it must be an authoring issue.
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #100 of 2245 Old 03-18-2008, 12:43 PM
FYI. I've watched quite a few DTS HD MA movies now and the only one I've had this sound with was "The Fly" as I don't have any of the other ones listed as culprits. Although I agree it does tend to make someone hesitant to watch a movies DTS HD MA track on a movie they have not scene yet.
Well that's settled let's boycot buying any Fox DTS HD MA titles until they confirm that they'll ensure this problem has been corrected on all of their releases
post #101 of 2245 Old 03-18-2008, 01:29 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Can you please give us a heads up when it's published? Thanks!
bferr1 is offline
post #102 of 2245 Old 03-18-2008, 02:07 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
Mine, I will also have the Denon player sometime today as well.
I use Denon with 30 no loud pop
Brian-HD is offline
post #103 of 2245 Old 03-18-2008, 04:03 PM
kinglerxt's Avatar
Here is the email I received back today from the makers of the Chronos bluray DVD with the loud pop issue:
Hi kinglerxt,
Thank you for the detailed information. Do you have the HD-DVD or Blu-ray
Disc version of CHRONOS?
You are not the first one that has mentioned this to us. It seems that
there is an obvious issue...but we do not know what it is yet. We have had
DTS check the stream...and they verified it was OK. However, with all of the
e-mails and comments on the AVS Forum...we believe this warrants further
investigation. We are looking in to this and will post something on AVS
Forum when we find out what the issue is.
Best Regards,
Richard J. Casey
R&B Films, Ltd.
1057 Lakeville Road
New Hyde Park, NY 11040
Tel: 516-695-0954
Fax: 516-326-0282
Web: www.rbfilms.com
post #104 of 2245 Old 03-18-2008, 04:08 PM
Fanboyz's Avatar
Quoted: 527 Post(s)
Liked: 162
So, this happend with the Panny 30k, Onkyo 8/905-integera 8.8, Yamaha 3800.
Unless the Onkyo and Yamaha use the same DTS HD-MA decoder then the issue based on miss-pressed discs.
Fanboyz is offline
post #105 of 2245 Old 03-18-2008, 04:10 PM
dyerjp's Avatar
i forgot to add that when a co-worker would borrow and play the discs that i have problems with on his bd-30 and his onkyo (forgot the model #), he did not have a problem with the popping noise.
dyerjp is offline
post #106 of 2245 Old 03-18-2008, 04:43 PM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Hi kinglerxt,
Best Regards,
Richard J. Casey
R&B Films, Ltd.
1057 Lakeville Road
Tel: 516-695-0954
Fax: 516-326-0282
Thats cool. Richards a good guy and posts here all the time.
shamus is offline
post #107 of 2245 Old 03-18-2008, 04:57 PM
bunkaroo's Avatar
Well so far since I got my BD30 I've watched Hitman, Mr. Magorium's Blah Blah Blah and I haven't experienced a problem yet. I do have The Fly so I'll watch that one with caution. I have a BD30 and Onkyo 605.
bunkaroo is offline
post #108 of 2245 Old 03-18-2008, 06:37 PM
Liked: 3150
Just tested the scene in The Golden Compass with the Denon 2500. Same loud pop. Actually seemed a bit louder even with the volume on my SSP at about -38. So that is three players so far that have done it with MA tracks in my system; 2 BD and 1 HD DVD.
My Home Theater
post #109 of 2245 Old 03-18-2008, 06:40 PM
thebland's Avatar
Quoted: 1598 Post(s)
Liked: 926
Is this bitstream DTS MA only?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #110 of 2245 Old 03-18-2008, 06:51 PM
Liked: 3150
So far, I don't have a player that will decode DTS-HD Master Audio internally so there is no way to test how it reacts in a player. But if you have a player send out the core via bitstream or have it output PCM (core again) it doesn't have this issue.
My Home Theater
post #111 of 2245 Old 03-18-2008, 07:33 PM
bluemoon737's Avatar
Quoted: 1216 Post(s)
Liked: 1572
So far, I don't have a player that will decode DTS-HD Master Audio internally ...
Does one exist yet?
Sony XBR75Z9D
Yamaha RX-A3050
OPPO UDP-203
bluemoon737 is offline
post #112 of 2245 Old 03-18-2008, 07:43 PM
eci
eci's Avatar
Originally Posted by BluLover View Post
What the heck are you guys babbling about? I only use bitstream, and I use my Onkyo 705. I have seen Fantastic Four 4 times and absolutely no pop at all.
Are you guys sure that you have proper speakers and proper powered subs that can handle lossless audio?
My Onkyo sub used to pop because it was bottoming out, so I upgraded to a bigger badder sub; the Hsu VTF-3 MK3, and all has been beautiful since.
My equipment is:
Onkyo 705
Panny BD30
Subwoofer: Hsu VTF-3.3
ROFL, whats a "proper speaker that can handle lossless audio?"
A speaker is a speaker. If your sub was "bottoming out" you didn't have it setup correctly or it was turned up too loud, has nothing to do with lossless.
eci is offline
post #113 of 2245 Old 03-18-2008, 07:43 PM
eci
eci's Avatar
Originally Posted by bluemoon737 View Post
Does one exist yet?
Denon 3800.
eci is offline
post #114 of 2245 Old 03-18-2008, 10:20 PM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Thanks... that rules out the BD30. Any chance you can try it out on a different receiver? All but one has happened on an Onkyo receiver or pre/pro.
shamus is offline
post #115 of 2245 Old 03-19-2008, 02:09 AM
little_donkey's Avatar
Ok I found the problem, or I think i found it
Well the problem of the loud bang will happen only on Onkyos and Yamahas
Something to do with the DTS chip or something.
Well found different links but in german, and I dont know german.
I know that Yamaha has a Firmware to fix this problem, I don't know about Onkyo.
http://www.areadvd.de/news/2008/2008...e_DTS-HD.shtml
little_donkey is offline
post #116 of 2245 Old 03-19-2008, 03:09 AM
Liked: 1572
Actually it been seen on a few Yamaha's and one Pio as well.
Sony XBR75Z9D
Yamaha RX-A3050
OPPO UDP-203
post #117 of 2245 Old 03-19-2008, 05:02 AM
dyerjp's Avatar
then why does it happen on my pioneer 91-txh then?
dyerjp is offline
post #118 of 2245 Old 03-19-2008, 05:16 AM
shabre's Avatar
I did not think the Golden Compass was released yet?
shabre is offline
post #119 of 2245 Old 03-19-2008, 05:41 AM
Soulstice X's Avatar
Kris Deering is a reviewer, so most likely it is a review copy.
Soulstice X is offline
post #120 of 2245 Old 03-19-2008, 05:43 AM
This has to be a disk problem because if it were the receivers mentioned (now 4 different models have posted on having this issue) then why don't we have it with all of the other movies out there with DTS HD MA? My point is that basic logic deduces it is indeed something within those particulary disk and possibly only with a certain production timeframe for those disk. Also the fact that this sound happens at the exact same spot for anyone who experiences it also points to the disk as the problem. It just seems way to unlikely that 4 different receiver's would all have the "Pop sound" at the exact same spot of a movie if it weren't the movie itself.
Reply Blu-ray Players
Onkyo Tx Sr705 Receiver , Panasonic Blu Ray Disc Player Dmp Bd30k
