No sound with Samsung BD-P1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-27-2008, 10:49 PM - Thread Starter
bemaniac's Avatar
So my parents have a Samsung BD-P1000 hooked via HDMI into a Denon AVR-2307CI.
I am getting video but no sound at all.
I have tried every setting imaginable on the Denon AND the Samsung BD player, and I have not been able to get sound working. I also have a cable box hooked into the Denon receiver via HDMI and it works perfectly.
Does anyone have any suggestions? I've also tried updating the firmware, and nothing has helped.
bemaniac is offline
post #2 of 7 Old 03-28-2008, 12:13 AM
ChrisW6ATV's Avatar
Have you tried using the optical audio output, or analog to see if you get anything? Also, when you said the cable box sends audio over HDMI properly, did you then plug the Samsung player into that same HDMI input to test it?
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #3 of 7 Old 03-28-2008, 12:29 AM - Thread Starter
bemaniac's Avatar
I have plugged the Samsung HDMI directly into the TV. Nothing.
Optical audio into the receiver. Nothing
Analog audio into the receiver. I get sound.
bemaniac is offline
post #4 of 7 Old 03-28-2008, 06:50 AM
BAMAVADER's Avatar
Quoted: 17 Post(s)
You may need to assign digital/HDMI inputs on the Denon...
<><<br />
RTR
BAMAVADER is offline
post #5 of 7 Old 03-28-2008, 09:38 AM - Thread Starter
bemaniac's Avatar
Done that. That also didn't help.
bemaniac is offline
post #6 of 7 Old 03-28-2008, 11:07 AM - Thread Starter
bemaniac's Avatar
Well, I just got off the phone with Samsung. They're fairly convinced it is a faulty player. Since the player is probably out of warranty (it's my parents' player, and I'm fairly certain they've had it for at least a year), they said it would cost $165 to fix.
I'm probably just going to go out and get a new one (any suggestions?). Hopefully I won't have such bad luck this time.
bemaniac is offline
post #7 of 7 Old 03-28-2008, 12:37 PM
badboi's Avatar
Location: East of the Sun, West of the Moon (Home Farm, Emme
Quoted: 70 Post(s)
Liked: 92
You said you get sound out from the analog connections? Can you set it up with the 5.1 analogs? It might save you from spending unnecessary money on a repair.
As far as a recommendation, I really don't have one at this point in the game. I'm waiting to see what's coming in the next few months from Panasonic and a few others. But if I absolutely had to buy something now, I'd go with a Panasonic.
badboi is offline
Reply Blu-ray Players
