IR to BT Converters (yes there are 4 of them): Comparisons/User Reviews - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 252 Old 06-09-2008, 02:49 PM
x64Man's Avatar
I am anxiously awaiting the PS3 Toothfairy to be available again.
I was fortunate enough to get the PS3Toothfairy first round out and it works like a thing of beauty. I purchased the bare bone kit, assembled and functioning with my Harmony One in less than 30 minutes. Great product.
x64Man is offline
post #92 of 252 Old 06-09-2008, 03:17 PM
sharkshark's Avatar
Quoted: 14 Post(s)
amazing, thanks for the more complete breakdown, it's nice to see it all in one place.
Being a right impatient bastard (hell, once I've jumped the gun let's go whole hog! ah, mixed metaphors, like butterflied in mustard!) I picked up at EB Games a $10 old skool PS2 remote =with= the IR repeater. I found for $20 at the Source (formerly Ratshack) a PS1/2>USB controller adapter. Plugged in the IR repeater to the adapter, and (as per the original post I read eons ago at Remote central) it works.
As per above, it lacks the main PS button, of course, so shutdown is a manual process (not such a big deal in my setup as I've got my Monster 5100 doing a timed shutdown anyway). Power on also is hardly a big deal, as I'm not so far away that it's an issue. What's more disconcerting is that with the PS2 remote nav is flaky as hell. In the XMB one press of the left/right button jumps sometimes one, sometimes two or three columns. This no doubt is the result of the details I read regarding BT functionality, namely, that it's expecting (like MIDI!) an on followed by an off signal, rather than continuous send with normal IR. Going to procrastinate today from real work and get it running on the Nevo, will advise to those desperate for updates from lil' ol' me...
Additionaly, the mapping of the buttons isn't straightforward either, with play/pause not working as expected. The start button does the trick, as do the four "shape" buttons (is there a l337 expression for them?). In terms of mapping to a normal remote I'm a bit at a loss, would be happy (to not barf in this thread) if someone could point to a good place that would outline in one place the corresponding play/pause/stop buttons (ie., "start=play/pause", "X=enter", etc.)
Man, it's stupid that Sony's not on the ball with this... There's money to be made!
sharkshark is offline
post #93 of 252 Old 06-09-2008, 03:30 PM
sharkshark's Avatar
Quoted: 14 Post(s)
ps.
Originally Posted by Beerstalker View Post
Requires the remote control to send out the macro for power down (PS, down, down, PS held for 3.5 seconds, X, X). Some Universal remotes cannot be programmed with a 3.5 second button hold, so the macro will not work with them.
Found this: http://ir2bt.com/forum/viewtopic.php...843b5bf7b58866
I wasn't getting the need for the first sequence, but see it's for during gameplay...
I -get- that the colour buttons and PS don't have a PS2 equivalent, but I don't get why it's not a simple matter of me having the hex codes for these controls and to use the PS2>IR dongle. There's obviously more to it then that or else the Nyko and Shmartz units would have incorporated.
I take it, then, that the IR blasters use unique IR codes that are then translated to BT signals, rather than "raw" PS2 sends. Correct?
post #94 of 252 Old 06-09-2008, 03:37 PM
sharkshark's Avatar
Quoted: 14 Post(s)
Originally Posted by sharkshark View Post
Additionaly, the mapping of the buttons isn't straightforward either, with play/pause not working as expected.... this thread) if someone could point to a good place that would outline in one place the corresponding play/pause/stop buttons (ie., "start=play/pause", "X=enter", etc.)
http://www.ir2bt.com/buttonmap1.htm
Yeah, I'm quoting myself now. It's come to that.
post #95 of 252 Old 06-09-2008, 06:17 PM - Thread Starter
dogdoctor's Avatar
A recent firmware update has the power off macro is built into the unit itself. Users just send a single discreet power off command from their remote, and the Pro sounds out the entire power off macro (so you don't have to sit there and point the remote at the unit for 5 seconds while the PS3 shuts down). Mike is still working to get direct IR control working, but as of right now it is not.
So is the macro there or not?? Did I miss a post about the firmware update. Or are you stating that it is coming. BTW - very good synopsis. - will merge to the first post.
PSN ID: dogdoctor
dogdoctor is offline
post #96 of 252 Old 06-09-2008, 06:22 PM - Thread Starter
dogdoctor's Avatar
Hey Beer - I've seen you on the IR2BT site...I haven't been able to get the H800 to do color PS3 icons (or any icons (ie square, circle, etc.) ) for that matter. It seems like it is a regional thing because some UK posters are making it work. Any success on your end?
PSN ID: dogdoctor
post #97 of 252 Old 06-09-2008, 10:40 PM
sharkshark's Avatar
Quoted: 14 Post(s)
well, been toiling with trying to make the IR adapter do the trick (silly intuition telling me it should...)
(x-posting to the Nevo kids! http://www.avsforum.com/avs-vb/showt...=978419&page=3)
Short version: I can of course "teach" my remote all the codes I need... CCF import from other sources didn't work quite as well as I would have liked, but the "this ain't gonna work" factor is set out by the fact that XMB nav is too quick (as above), skipping over columns when nav'ing. Unfortunately I can't reduce the IR transmission time as far as I know to a point where it'd be fixed.
Anyone notice this with their PS2>PS3 solution (ie., PS3IRX1)?
post #98 of 252 Old 06-10-2008, 09:12 AM
Beerstalker's Avatar
Liked: 24
The firmware update has been posted on Mike's site, and people have successfully updated their units. Some people with Hex programmable remotes have got the new built in macro to work, but I'm not sure if anyone that has a Harmony has got it to work yet. I do not have the PS3IR-Pro, so I can't really verify anything.
What remote to you have? I'm not familiar with the H800.
Edit/ Just looked back through your old posts and saw that you have the Harmony 880. There are no color PS icons for the 880. Only for the Harmony One and the 1000. You can add text icons to the 880 if you would prefer them to writing out the command. Here is a link to the icons I used.
http://www.avsforum.com/avs-vb/showp...&postcount=763
Beerstalker is offline
post #99 of 252 Old 06-10-2008, 01:47 PM
sharkshark's Avatar
Quoted: 14 Post(s)
...just ordered the IR4PS3 from Benoit... There's a great comprehensive guide that he sends out, and given the fact that there are built in macros for some of the more challenging sequences for certain remotes, the fact that it's built directly upon a Sony BT remote board, and, well, that it's from a nice guy in Quebec made it an easy choice. There's no option for AA or USB power, but it's about half the price of the other unit, and it's ready to ship if you should make the plunge.
Should be getting it asap. Beer, I recommend adding his device to your (fine) summary above as it may help others, and I second the fact that the summary should be in the first post of this thread.
post #100 of 252 Old 06-10-2008, 03:27 PM - Thread Starter
dogdoctor's Avatar
Guess I need to check his site more often. As for my H800. LOL. Yeah the 880. Love the remote - icons would be cool. What is triangle? I see square is a ALT variation.
PSN ID: dogdoctor
post #101 of 252 Old 06-11-2008, 11:30 AM
turbe's Avatar
Liked: 95
To verify, I need to purchase the official Sony BT Remote for the PS3 no matter which of these I buy (PS3IR-Pro, IR2BT or PS3Toothfairy)?
Thanks in advance
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #102 of 252 Old 06-11-2008, 01:40 PM
Liked: 24
No you do not need to purchase the PS3 remote if you buy the PS3IR-Pro, or the IR2BT. Depending on which PS3Toothfairy you purchase you may or may not have to buy one (you need the Sony remote for the bare model, but you do not need it for the standard or the elite).
Sharkshark, I did not say anything about the IR4PS3 because I do not know much about it. There still isn't a website, and all I have seen online about it is the article that was written months ago, and a few posts by users that say it works well. When you get yours feel free to post any information you can, and hopefully some pictures as well.
It appears that Dogdoctor has included my summary on the first page now also.
Dogdoctor, I'm not sure where the triangle text icon originally came from. I just copied and pasted it from another forum into the Logitech software and it worked fine.
post #103 of 252 Old 06-11-2008, 03:49 PM - Thread Starter
dogdoctor's Avatar
PS. I've downloaded the new PS3IR-PRO firmware...I just can't get it to load. I'm emailing Mike to see if I'm doing something wrong.
PSN ID: dogdoctor
post #104 of 252 Old 06-12-2008, 02:19 PM
afarias's Avatar
I've read this whole thread, and only seen maybe two mentions for the ir4ps3. I personally have the ir4ps3 so I might be bias, but it works great. The power off embedded macro was the selling point for me. I hear a lot of other people having trouble programming the macro in their remotes, and on the schmartstuff.com forums their are nothing but complaints regarding the firmware update.
afarias is offline
post #105 of 252 Old 06-12-2008, 03:35 PM
sharkshark's Avatar
Quoted: 14 Post(s)
http://www.avsforum.com/avs-vb/showp...&postcount=181
More love for it - got it within 24 hours of payment, set it up in 30 seconds and it immediately outperformed my PS2 IR>USB adapter hack.
Merci Bien Benoit!!!
ps. I actually -offered- to do Ben a site, and he turned me down, he wants to keep it fairly quiet so that he isn't bombarded. In other words, if you're in the know, and lord knows y'all in this thread are, it'd be best to do so asap while he's still having a go at it.
pps. I do like that the other equivalent unit uses battery or USB power, but this one is not only significantly cheaper, but the inclusion of the power macro seems like a boon to those using Harmony or other similar remotes. As per my thread above, my Nevo Q50 seems to handle the power sequence without a need to use the built-in macro, so I can actually have a speedier power-off if I'd like.
post #106 of 252 Old 06-13-2008, 11:47 AM
jdsnov73's Avatar
I have to agree. The IR4PS3 works great and setup was a breeze. I already had a PS3 remote that I wasn't using, so I figured why not put it to use.
I had the Nyko and it worked fine for me, but really wanted the power option.
Well worth it to me.
Ben is very quick to respond to questions.
Very highly recommended.
jdsnov73 is offline
post #107 of 252 Old 06-14-2008, 12:48 AM
rudolpht's Avatar
Congrats on 1K posts.
In contrast I got a PS3IR-PRO today and upgraded firmware without a hitch. The device driver was slow to load on my PC, but it worked great and downloaded perfectly.
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #108 of 252 Old 06-14-2008, 02:32 AM
SDRANGER619's Avatar
subscribing.
huh?
SDRANGER619 is offline
post #109 of 252 Old 06-14-2008, 09:21 AM - Thread Starter
dogdoctor's Avatar
Thanks I didn't even see the 1000 mark.
As for the PRO - I think since mine was beta - there might be something different. I've spent nearly 2 hours trying to follow the instructions and still nothing. HMM...I'll call Mike this afternoon.
PSN ID: dogdoctor
post #110 of 252 Old 06-15-2008, 06:26 PM
sharkshark's Avatar
Quoted: 14 Post(s)
super nerdy question - anybody else try to play games with their remote?
You have to of course change the controller number to 1 usually, but, yeah... kinda works...
Ah, rediscovering IR... So hilarious we've got to hack this thing just to make it work with dino-tech like a lightbulb that we can't see...
post #111 of 252 Old 06-16-2008, 07:19 PM
T_Nugent's Avatar
I couldn't be happier with my PS3IR-PRO now that Logitech was able to give me the PowerOff button that activates the discreet Power Off macro in the new firmware. Everything works like a charm and the PS3 powers down all the time. I was quite frustrated early on when it seemed like I had a 50/50 chance of the PowerOff macro programmed into my Logitech 880 of working as expected.
Hopefully support for hardwired IR repeater/flashers is coming soon. Being able to update the firmware via computer after just one firmware update has been huge for me changing me from disgruntled to very pleased.
Trent
T_Nugent is offline
post #112 of 252 Old 06-16-2008, 11:03 PM
bpratt2's Avatar
Originally Posted by MMuecke View Post
I respond only because you seem to cast doubt on my integrity. This info is useless but, there you are.
A late reply to an old post, but....
I am glad that someone small has taken a patent out on it before one of the big guys jump in on the bandwagon and take over the whole project, do all of you guys out of business.
Sure MMuecke has made some silly PR mistakes, but let's get over it and buy from whoever we want to buy from.
bpratt2 is offline
post #113 of 252 Old 06-17-2008, 12:07 AM
so any new news if the IR2BT will be available? I'm torn between that and the PS3IR-PRO.
huh?
post #114 of 252 Old 06-17-2008, 02:33 PM
Liked: 24
The IR2BT website says they have ordered more parts and expect to have more units ready by the end of June. I would expect them to start taking pre-orders around that time.
The PS3 Toothfairy website just says that they are sold out and hope to have more soon. No mention of any timeframe.
The Schmartz PS3IR-Pro is in stock and supposedly shipping within a day or two of order placement.
post #115 of 252 Old 06-17-2008, 02:51 PM
JayMan007's Avatar
I also think you can get the IR4PS3....
so, which one you gonna get?
JayMan007 is offline
post #116 of 252 Old 06-17-2008, 03:17 PM
sharkshark's Avatar
Quoted: 14 Post(s)
...I really can't speak to the USB solutions, but my experiments with basically cloning the PS2 remote proved to be pretty shoddy...
I continue to be very happy with my IR4PS3. As it tracks ON/OFF states you have to be a bit wary of, say, turning on the unit using the controller and then expecting functionality, but since the command is discrete it's easy to program my Nevo to send the ON command when switching to the device with no trouble.
And, yeah, driving games with the Nevo are kinda fun...
post #117 of 252 Old 06-17-2008, 03:28 PM
Baconbeard's Avatar
Add me to the group that has an IR2BT, an so far it works great. Setup is a snap and so far it works flawlessly. The only thing I have to do manually is flip the switch on the back of the PS3. I can do everything else with my Harmony 670.
Baconbeard is offline
post #118 of 252 Old 06-17-2008, 06:13 PM
Liked: 24
Sharkshark, is there any chance you can post some pics and maybe the instruction manual for hte IR4PS3? There is very little info available about it on the web.
post #119 of 252 Old 06-17-2008, 08:09 PM
ody
ody's Avatar
Quoted: 25 Post(s)
Liked: 54
It's all here:
http://www.avsforum.com/avs-vb/showt...ghlight=ir4ps3
http://www.avsforum.com/forum/19-ded...-bar-game.htmlThe "WAF" - Open Concept Theater / Bar / Game
ody is online now
post #120 of 252 Old 06-17-2008, 10:29 PM
anezthetik's Avatar
I have found another remote for the ps3, well sort of. I use the gyration media center remote (mainly because harmony can't do the wii type of mouse control for my HTPC)..... Anyway, I stuck the usb port into the ps3 just for fun, and it sort of worked....
Just for those who do not know. Gyration uses wii-like technology (without the need of a sensor bar) for your computer. With it I can do everything as a mouse. In addition, the numbers double as letters (like in texting someone) so I can even use it to type in small things like usernames or search items. It also doubles as a standard universal remote (no macros but every IR button is programmable). It uses blue-tooth to communicate with the computer, and IR to communicate with everything else.
on the ps3, I was able to scroll through the menus, even fastforward and rewind blue-rays. The problem is that the gyration doesn't seem to allow you to program blue-tooth signals. In other words, I can't get the ps3 button, triangle, or any other buttons. I just lucked out that the default directional signals the remote used were the same that the ps3 used.
The beauty of the gyration remote is that it is BOTH IR and blue-tooth.... so in essence, it basically needs a software code written for it, and wallah you have ps3 remote with all the functions of the regular remote. I don't think something like that exists, but I do not think it would be that hard to either program the remote, or to program the ps3 to respond to the pre-programmed blue-tooth buttons.
Anyone out there have any advice?
anezthetik is offline
Reply Blu-ray Players
