The Official Samsung BD-P1500 Owner's Thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 5654 Old 06-01-2008, 03:56 PM
kirbalo's Avatar
Originally Posted by SKoprowski View Post
Based on those chip specs shouldn't the 1500 be capable of decoding DTS-HD?
Can we assume Samsung can enable that in future firmware upgrades?
In theory, yes. I think we can assume all we want regarding future firmware updates, but it does state that they intend to in the product brief.
kirbalo is offline
post #302 of 5654 Old 06-01-2008, 04:34 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 98
It draws air off the bottom and sends it out through the sides.
rwestley is offline
post #303 of 5654 Old 06-01-2008, 10:02 PM
kpmac1's Avatar
Question about audio settings. My 1500 is hooked up to my Yamaha AV receiver via optical. The receiver only decodes Dolby Digital ES and DTS-EX. What audio option should I select in the 1500? Currently I'm using the Bitstream (re-encode) option which sends everything to the receiver as DTS. Should I choose one of the other 2 options? If so, which one? Thanks!
kpmac1 is offline
post #304 of 5654 Old 06-02-2008, 05:41 AM
robotec's Avatar
Based on you having a non-hdmi receiver, you've chosen the correct audio option to bitstream to the receiver.
I'm not snobbish and uninformed.
robotec is offline
post #305 of 5654 Old 06-02-2008, 09:50 AM
mrjktcvs's Avatar
Originally Posted by Targo View Post
My question concerns the quality of up scaling. I'm looking to buy my first blu ray player and my budget is around 400. I'll be playing a lot of older movies and television shows and the only up scaler I've ever seen is the internal scaler that my Mitsubishi has. I'm not sure how it compares to other up scalers, but I'm not terribly impressed with it.
So is this the best sub 400 player on the market, aside from the PS3?
I can't answer most of this, but I can tell you what my limited experience has been:
I have a 1500 and an Onkyo 875 receiver. I hooked up both the component video and HDMI interfaces between the player and the receiver. I now use the HDMI cable for viewing BD and the component cable for viewing SD DVD's on the basis of my experimentation. With this setup, it was easy to do an A/B comparison between the upscaling of the player and the upscaling of the receiver. The Reon chip on the Onkyo does a superior job, particularly in color accuracy and apparent sharpness.
Edit: I should point out that my display is 1080i, so results might vary on someone else's system.
mrjktcvs is offline
post #306 of 5654 Old 06-02-2008, 12:16 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 98
It seems strange to want to play SD through component. DRM will not allow upscailing with component and the max res you can get is 480P. With HDMI you can use upscailing.
rwestley is offline
post #307 of 5654 Old 06-02-2008, 02:07 PM
jfrocke's Avatar
I am not able to get my Sony LCD TV remote to control my Samsung 1500. Any idea what other codes I could try? It is a Sony XBR 40" LCD.
jfrocke is offline
post #308 of 5654 Old 06-03-2008, 08:25 AM
kulims's Avatar
Any playback issues ?
kulims is offline
post #309 of 5654 Old 06-03-2008, 10:08 AM
Blacklac's Avatar
Seems he is having his receiver do the upscaling.
Blacklac is offline
post #310 of 5654 Old 06-03-2008, 11:13 AM
bdraw's Avatar
Quoted: 169 Post(s)
Liked: 82
More on the dropout in Rambo.
I experienced the dropout in the exact same place as others. I'm using the bitstream (non-audiophile) via spdif.
So I pop'd the disc in my HTPC and played the movie back with ArcSoft TotalMedia Theater and the dropout is not there. Not sure what the problem is, but I suppose the BD-P1500 could be more sensitive to errors since there is only one dropout and it occurs in the same place for everyone.
Ben
How good could it be if it isn't HD?
No longer contributing to Engadget HD
bdraw is offline
post #311 of 5654 Old 06-03-2008, 03:52 PM
football751's Avatar
Quoted: 28 Post(s)
Sorry, as I'm sure this has been covered, but just want to be positive before I purchase. The P1500 will bitstream TrueHD and DTS-HD MA; will it bit-stream and/or decode DTS-HD High Resolution audio? I am buying an Onkyo 606 so player decoding of TrueHD and DTS-HD MA is not an issue for me, but I don't think it will decode DTS-HD High Resolution (correct me if I am wrong).
Also, is there any reason to wait on the BDP-350? Seems to be pretty much identical, with the same price and upgradeable to Profile 2.0.
football751 is offline
post #312 of 5654 Old 06-03-2008, 04:25 PM
Andrew P's Avatar
Quoted: 37 Post(s)
I just watched Rambo and I had 2 audio dropouts. 1 about 7:40 into the movie and the 2nd was on the boat with the mercs.
Andrew P is offline
post #313 of 5654 Old 06-03-2008, 07:52 PM
FCEEVIPER's Avatar
So are the drops outs because of the player or the discs themselves?
"Some men aren't looking for anything logical.
They can't be bought, bullied, reasoned, or negotiated with.
Some men just want to watch the world burn."
Dark Knight Saga - 072012
FCEEVIPER is offline
post #314 of 5654 Old 06-03-2008, 10:32 PM
FCEEVIPER's Avatar
Does anyone have a UPC for the Samsung1500 purchased from Walmart?
Thanks in advance!
post #315 of 5654 Old 06-03-2008, 10:37 PM
kirbalo's Avatar
DTS-HD MA "Master Audio" is a lossless, "higher quality" codec than DTS-HD High Resolution which is lossy. As suggested in the P1500 product brief linked to in my previous post, this unit "may" be able to decode DTS-HD at a later date with a firmware update, but it will bitstream both today. Note that the data brief does NOT specify which DTS-HD, "MA" or "HR". They are technically "mutually exclusive". The Onkyo can already decode DTS-HD "High Resolution" and "Master Audio".
For a description of the different DTS-HD codecs and bitrates, etc, see the DTS Product Brief
kirbalo is offline
post #316 of 5654 Old 06-04-2008, 06:04 AM
philnerd's Avatar
Originally Posted by dropzone7 View Post
The resume play function worked like a champ. Stopped the player while still running and hit play, it went right back to where I was. I then stopped the player and powered it down for a few minutes. Powered back up and hit play and it picked right back up where I left it. This is a really nice change from my Toshiba HD-A2 which always started the disc over whether you just stopped it or turned it off completely.
Just to clarify for potential BD-P1500 shoppers; that's a function of BD-J vs. non BD-J movies. BD-J authored discs like Pirates or Cars will restart from the beginning if the player is stopped or turned off. Non BD-J discs (like The Fifth Element) will resume. HD DVD was similar in that HDi authored discs would have to restart if stopped/turned off. In the case of HD DVD, nearly every disc was HDi authored so pretty much every disc behaved this way. In the case of Blu-Ray, a lot of discs are non BD-J authored so its more hit or miss on resume play.
philnerd is offline
post #317 of 5654 Old 06-04-2008, 06:31 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
DTS-HD MA is lossless and the most difficult to decode. DTS-HD HR is actually quite easy to decode. Hence, no receiver bother to even mention of decoding DTS-HD HR if it can decode DTS-HD MA already because it is implied
Foxbat121 is online now
post #318 of 5654 Old 06-04-2008, 06:32 AM
robertc88's Avatar
I already own 2 BD players, BD30 and PS3 60 GIG. I did read most of this thread.
I'm not shopping for myself but based on what I've read, I feel I can safely recommend this player to any friends, family etc if they ask. Some are better than others but there aren't any without at least some faults.
Enjoy your purchase and if this is your first BD player, it appears you have started off well.
robertc88 is offline
post #319 of 5654 Old 06-04-2008, 06:33 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Good to know. However, HD DVDs have bookmark feature to help although not as convienent as auto-resume. Do BD discs all support such feature?
post #320 of 5654 Old 06-04-2008, 09:14 AM
dpcpaul's Avatar
Does anyone know if the 1500 will reliably play BD-Rs?
dpcpaul is offline
post #321 of 5654 Old 06-04-2008, 09:16 AM
Quoted: 28 Post(s)
Thanks for the info, didn't know High Resolution was assumed w/ Master Audio decoding.
Before I pull the trigger on this player, is ther any reason to wait on the BDP-S350?
post #322 of 5654 Old 06-04-2008, 10:08 AM
ElwayLite's Avatar
I see that the 1500 is loading pretty fast and seems to be running well. Anyone had a good compare on BD30 vs 1500 bluray 1080p PQ?
ElwayLite is offline
post #323 of 5654 Old 06-04-2008, 11:26 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Not all BDs, and not all HD DVDs, either, for that matter. Really varies on a studio-by-studio and title-by-title basis.
bferr1 is offline
post #324 of 5654 Old 06-04-2008, 11:54 AM
gja
gja's Avatar
I am considering this player but have a question. My receiver is a Denon 3806 1.1 HDMI. It will not decode the new audio codecs. If a Disc is DTS-MA, but the 1500 and my 3806 doesn't decode this, do I get the core audio tracks or no sound at all.
Sorry if this is a newb question, just can't keep up with all this.
gja is offline
post #325 of 5654 Old 06-04-2008, 12:28 PM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
Very, very close, if not identical. If I were tied-up and tortured until I had to pick one as "better", I'd go with the 1500.
Robert George is offline
post #326 of 5654 Old 06-04-2008, 12:29 PM
ElwayLite's Avatar
Thanks. Thats what Im seeing most say (that they are close). Not enough to make me trade in the panny
post #327 of 5654 Old 06-04-2008, 12:49 PM
Andrew P's Avatar
Quoted: 37 Post(s)
The PQ is very close between the two units. I prefer the Samsung 1500 due to speed, price, and 2.0 capable.
Andrew P is offline
post #328 of 5654 Old 06-04-2008, 03:05 PM
rutlian's Avatar
+10
Peter
Enjoy HD no matter what......
rutlian is offline
post #329 of 5654 Old 06-04-2008, 03:14 PM
ElwayLite's Avatar
As a current BD30 owner, its not enough for me to justify a trade in.
post #330 of 5654 Old 06-04-2008, 03:56 PM
rutlian's Avatar
You already mentioned this on your post number 326. We are glad you're keeping your panny bd30.
Peter
rutlian is offline
Reply Blu-ray Players
