Is Dolby True HD 7.1 or 5.1 with Blu Ray? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-23-2008, 07:03 AM - Thread Starter
dlgreen561's Avatar
Just wanted to be clear on this point....
dlgreen561 is offline
post #2 of 21 Old 05-23-2008, 07:15 AM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
The Blu-ray format supports TrueHD in up to 7.1 channels, but the vast majority of TrueHD tracks are in 5.1.
Aside from a Dolby demonstration disc, I'm not aware of a BD that has a 7.1 TrueHD encode. The recently released Shinobi: Heart Under Blade does have a 6.1 TrueHD track. Anyway, the format does support 7.1 TrueHD.
MSmith83 is offline
post #3 of 21 Old 05-23-2008, 07:39 AM
allargon's Avatar
Quoted: 51 Post(s)
Liked: 44
Look to "Hannah Montana" very soon.
http://bluray.highdefdigest.com/1295...othworlds.html
allargon is offline
post #4 of 21 Old 05-23-2008, 08:37 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2899
The Blu-ray spec supports up to 8 audio channels, irrespective of format/codec (PCM, TrueHD, DTS-HD MA, etc).
TrueHD is lossless compression technology that packs the audio data more efficiently in order to reduce storage space and transmission bandwidth, As such, it has nothing to do with the number of channels in a soundtrack. For example: if Casablanca' were to be released on Blu-ray using TrueHD, it would still be one (mono) channel. At the opposite end, there are examples of 6.1 and 7.1 TrueHD soundtracks (mentioned above).
Film makers decide how many channels are in the soundtrack. TrueHD is just used to losslessly reduce the file size.
Sanjay
Sanjay
sdurani is offline
post #5 of 21 Old 05-23-2008, 08:47 AM
tamahome02000's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=1031386
7.1 lossless titles:
RAMBO
3:10 To Yuma
Tyler Perry's Daddy's Little Girls
Delta Farce
Good Luck Chuck
Ultimate Avengers Collection
National Lampoon's Van Wilder
Waiting...
Weeds Season 2
The Condemned
House of 1000 Corpses
Hairspray
Doctor Strange: The Sorcerer Supreme
The Golden Compass
Mr Woodcock
Oldboy
The Orphanage
Pan's Labyrinth
Rush Hour 3
Saw 4
Shoot Em Up
War
tamahome02000 is offline
post #6 of 21 Old 05-23-2008, 08:58 AM
sdurani's Avatar
Liked: 2899
I don't think any of those are encoded in TrueHD (the topic of this thread).
Sanjay
Sanjay
sdurani is offline
post #7 of 21 Old 07-11-2008, 04:58 PM
fraginsteindod's Avatar
Rambo is DTS-HD Master Audio 7.1.
So, what I am finding out is that if I use TrueHD on my Onkyo TX-SR606 while playing a BD on my Panasonic DMP-BD30 (TrueHD 5.1 soundtrack), I only get the 5.1 (two back speakers are cut out).
I have to switch the receiver to Dolby EX to enable the two back speakers.
Question: Does this mean I have to play a TrueHD (or DTS-HD) 7.1 soundtrack to get TrueHD (or DTS-HD) 7.1, correct?
This would be a bummer then waiting for more 7.1 tracks on BD.
fraginsteindod is offline
post #8 of 21 Old 07-11-2008, 07:01 PM
townofturley's Avatar
RAMBO
3:10 To Yuma
Delta Farce
Good Luck Chuck
Waiting...
Weeds Season 2
The Condemned
Hairspray
The Golden Compass
Mr Woodcock
Oldboy
The Orphanage
Pan's Labyrinth
Rush Hour 3
Saw 4
Shoot Em Up
War
And those are all TrueHD???? NOT. Please read the original post.
townofturley is offline
post #9 of 21 Old 07-11-2008, 07:03 PM
I don't understand what you are asking. Do you expect to get 7.1 from a 5.1 audio track? Does your Onkyo do DPL IIx?
post #10 of 21 Old 07-11-2008, 07:10 PM
mahicks's Avatar
Quoted: 22 Post(s)
I will try to answer for the OP. Yes, reciever does DPL IIx. I think he is asking, if he sets the TRUE HD to DPL IIx, is he loosing something? ie..is it theoretically TRUE HD with matrixed back surrounds, or does it screw it up into something not even close? ie..is it better to leave it, or to use dplIIx for his 7.1 setup..
just my .02
mahicks is offline
post #11 of 21 Old 07-11-2008, 09:33 PM
just my .02
You got it. That's what I'm asking, am I losing quality for quantity? (But it still sounds great on DPL IIx at 7.1).
post #12 of 21 Old 07-12-2008, 08:55 AM
petegtsv10's Avatar
I have the same question, too!!!
petegtsv10 is offline
post #13 of 21 Old 07-12-2008, 10:27 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I have been using DPLIIx for years to get a 7.1 soundfield from a 5.1 program. My suggestion is try it both ways, with and without. It's a personal preference, not a scientific fact of which is preferable.
There are very few 6.1/7.1 soundtracks on DVD, so using DPLIIx to get a 7.1 soundfield is going to be your usual way to take advantage of a 7.1 setup. I am not sure how common 7.1 is on Blu-ray, but it does not sound too common, so the same statement would seem to apply.
Not all receivers can apply DPLIIx to MCPM.
"But this one goes up to 11"
MichaelJHuman is offline
post #14 of 21 Old 07-12-2008, 11:56 AM
jlangner's Avatar
Is DPLIIx the same as PLIIx for the Yamaha RX-V663?
I made the same mistake last night listening to Batman Begins. I was wondering why my back surrounds had no sound...till I noticed it was 5.1.
Blu-Ray: 40
Yamaha RX-V663
Sony BDP-S350
jlangner is offline
post #15 of 21 Old 07-12-2008, 01:17 PM
TuenMuner's Avatar
The Hong Kong release of Dragon Tiger Gate has a 7.1 Dolby TrueHD track.
BD-A1010/CD-S1000/PF60
HTR-6290/A-S1000/KDL46V5100
NS-555/SOAVO-900C/NS-125F
BD - 246
HD DVD - 7
TuenMuner is offline
post #16 of 21 Old 07-12-2008, 02:22 PM
sdurani's Avatar
Liked: 2899
Yes, in both cases it's Dolby Pro Logic IIx.
Sanjay
Sanjay
sdurani is offline
post #17 of 21 Old 07-12-2008, 03:59 PM
petegtsv10's Avatar
Anyone have the answer?? (with regard to lossless to 7.1 and losing quality for quantity)
post #18 of 21 Old 07-12-2008, 05:02 PM
mahicks's Avatar
Quoted: 22 Post(s)
I can tell you I have the same receiver as the OP that originally asked the question. I think the Onkyo does a great job of simply sampling some of the information from the surround channels and puts it into the back surround channels. In our case, I personally think it is better for movies, but that is just my opinion and only based on my limited use with the receiver and quite a few discs. With another receiver, YMMV. Long story short....you don't loose any quality from the original 5 channels, you just "create" 2 more..
Also, I would like to add that when you do have this receiver setup to "turn" HD codecs into 7.1 PLIIx, it automatically turns off PLIIX when a SEVEN channel source is detected. This allows us to "set it and forget it" while still allowing all 7.1 discrete tracks to played only in original format, yet "creating" us a 7.1 automatically when a less than 7 channel track is played.
mahicks is offline
post #19 of 21 Old 07-12-2008, 05:09 PM
Lonely Surfer's Avatar
"you don't loose any quality from the original 5 channels, you just "create" 2 more.."
lose
Lonely Surfer is offline
post #20 of 21 Old 07-12-2008, 05:26 PM
mahicks's Avatar
Quoted: 22 Post(s)
lose
LOL...Thanks. I do that quite often, but I try not to lose sleep over it :-)
Guess I have a loose way with werds..
mahicks is offline
post #21 of 21 Old 07-13-2008, 04:51 AM
Thanks for the answers guys, now I can sleep again LOL!
Reply Blu-ray Players
