The Official Sony BDP-S350 Owners Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 07-08-2008, 12:03 PM
Allan2's Avatar
Originally Posted by gordon@1310 View Post
Alan,
Which Oppo do you have? I have the 980 and am curious how it looks compared to that.
981HD
Allan
Forum Admin
Tweaks.com
Allan2 is offline
Old 07-08-2008, 12:04 PM
hellerbrewing's Avatar
David Vaughn from Ultimate AV Mag has said he is going to review this one this month. Hopefully this will be coming soon.
hellerbrewing is online now
Old 07-08-2008, 12:05 PM
rveras's Avatar
Originally Posted by hellerbrewing View Post
Only 5.1 with DTS-MA?
Of course since the player is only decoding the core which I don't believe can be anything above 5.1.
rveras is offline
Old 07-08-2008, 12:07 PM
That is for 5.1 DTS-MA for the Auto setting which I assume is bitstream.
edit: I guess it says LPCM so I guess that means it is decoding it. Confusing that it only mentions bitstream for optical and coax and says you can only get 2 channel with it.
Old 07-08-2008, 12:11 PM
Micah008's Avatar
Originally Posted by rveras View Post
Yes if you set the HDMI audio out to Auto instead of PCM.
According to the manual, the only settings from are Auto and 2ch PCM. How can you tell it to do a bitstream of DTS MA, rather than decoding the DTS core and outputting as 5.1 LPCM? Both of these would fall into the Auto setting, right?
Micah008 is offline
Old 07-08-2008, 12:12 PM
rveras's Avatar
Auto could be bitstream or internal decode depending on the capabilities of your receiver. The table is showing you what the player will do if your receiver can't accept TrueHD/DTS-HD-MA bitstream.
rveras is offline
Old 07-08-2008, 12:13 PM
rveras's Avatar
See my previous post above.
rveras is offline
Old 07-08-2008, 12:16 PM
pnkflyd51's Avatar
Location: Hopkinton, MA (originally from Bloomington, IN)
> I was just looking at that as well. Bummer.
That can't be right. I'm reading the footnote for #5 on 1444_001.pdf, and it doesn't have an entry for "When the AV amplifier does support HD Audio". I think it does bitstream 7.1 out though, it just cannot output 7.1 LPCM- which we knew.
pnkflyd51 is offline
Micah008's Avatar
So essentially you are saying that there is a column missing from their table on pg 62 of the manual, that would have been labeled Bitstream if the Receiver can support it?
I think this table is what is causing confusion since it says LPCM 5.1 ch (DTS core), and never refers to bitstreaming the full 7.1 DTS MA.
Micah008 is offline
Old 07-08-2008, 12:17 PM
Darth Indy's Avatar
If it only does 5.1 via DTS-HDMA then what would it do if you had a disc with 7.1 HDMA and bitstreamed it to the receiver???
Darth Indy is offline
Old 07-08-2008, 12:19 PM
rveras's Avatar
Read the #5 footnote.
rveras is offline
Old 07-08-2008, 12:28 PM
beckp's Avatar
I'm a newbie as well and have the same receiver limitations as you ... I believe the answer to your question is yes, optical out to your AVR and you will get DD5.1 or DTS as you currenty do.
beckp is offline
Old 07-08-2008, 12:29 PM
jimbo88's Avatar
Originally Posted by Allan2 View Post
...you can only set the 350 to ouput to one connection and if you configure it for HDMI and set it for AUTO or 1080P, the other connections will not output. However, I set it up for composite output instead of HDMI and ALL connections work fine - including the HDMI. I don't know if it's outputting 1080i or 1080p, but either way it looks GREAT.
Can the video output be set for COMPONENT and have audio output via HDMI at the same time? Thanks
LG 55E6P, Oppo UHD-203 & BDP-93, Onkyo NR709
jimbo88 is offline
Old 07-08-2008, 12:30 PM
gordon@1310's Avatar
981HD
Thanks. So I guess it should look at least as good as my 980. Maybe a little different, but no major faults like most other BR players. I will have to check it out while waiting to see the new Pioneer.
gordon@1310 is offline
Old 07-08-2008, 12:33 PM - Thread Starter
jlangner's Avatar
Pretty standard remote.
Also, from reading the manual, you need to buy the memory to even do the bonus view, correct?
1449_001.pdf 334.056640625k . file
Blu-Ray: 40
Yamaha RX-V663
Sony BDP-S350
jlangner is offline
Old 07-08-2008, 12:35 PM
D_B_0673's Avatar
Quoted: 17 Post(s)
Originally Posted by Ruined View Post
Well, scratch this one and the BDP-S550 off my (already very short) list.
For me at least,
No Source Direct = No Reon/Realta/VP50/etc for 1080i Blu-ray and 480i DVD = NO SALE!
Can you explain that a little more
Are you saying that it cannot output 1080i into a video processor?
Are you saying the 550 cannot do that also
I don't want any video processing from a dvd player, just 1080i from bluray into video processor for deinterlacing
thanks
Dan
D_B_0673 is offline
Old 07-08-2008, 12:37 PM - Thread Starter
jlangner's Avatar
Here is the Bonus View Page:
1450_001.pdf 187.333984375k . file
Blu-Ray: 40
Yamaha RX-V663
Sony BDP-S350
jlangner is offline
Old 07-08-2008, 12:46 PM
GizmoDVD's Avatar
pictures?
GizmoDVD is offline
Old 07-08-2008, 12:52 PM - Thread Starter
jlangner's Avatar
Originally Posted by GizmoDVD View Post
pictures?
Have to be Alan...stuck at work.
Blu-Ray: 40
Yamaha RX-V663
Sony BDP-S350
jlangner is offline
Old 07-08-2008, 01:33 PM
bpdunsta's Avatar
In the absence of pictures, can you tell us if the front of the unit is black or blue? There were some differing photos over the last couple of weeks.
bpdunsta is offline
Old 07-08-2008, 01:39 PM
stephenC's Avatar
BD-Live flyer in the box. Says 2008 will be BD-Live.
Excellent work. I hope all you new owners enjoy your new toy. I've subscribed to this thread and will be watching for information about the BD-Live firmware update. Reading the PDF about this indicates that you have to register on the Sony website with your serial number to gain access. I probably will wait to purchase this player until after the firmware is released.
stephenC is offline
Old 07-08-2008, 01:44 PM
Pugnax555's Avatar
Please tell me how you get that from "If you would like to be notified via e-mail when this update is available..." Not to mention the second sentence of the flyer says "This enhancement will be delivered to your player over the internet through the network download service or, if you prefer, by a disc-based update." Neither one of those in any way indicates that you need to register with Sony to gain access. Then again, maybe I just have poor reading comprehension skills....
Pugnax555 is offline
Old 07-08-2008, 01:46 PM
MrLatte's Avatar
Quoted: 14 Post(s)
This is from the SonyStyle website description for the 350:
DTS-HD (High Resolution/Master Audio) Bitstream Out
DTS-HD gives you sound quality that matches the crystal clear image of Blu-ray Disc™. With up to 7.1 channels of surround sound and audio that is indistinguishable form the original studio version, DTS-HD promises you an extraordinary surround experience.
MrLatte is offline
Old 07-08-2008, 01:47 PM
slimm's Avatar
How are the disc seeks with this player? The Samsung 1500 I just returned sounded like a meat grinder.
slimm is offline
Old 07-08-2008, 01:53 PM
lovswr's Avatar
Quoted: 39 Post(s)
Liked: 25
Send a message via AIM to lovswr
Buy memory? As in Memory Stick (uggh, & I am a complete Sony Fanboi) or just any old USB jump drive will do?)
I think I still have a few days before my 30 days is up on my Samsung BD-P1500, so c'mon S350 owers, we need a full review ASAP!
carry on with your HD-Lite Directv loving banter! <--Comedy Gold
Don't fall for the HDMI 1.3 Hype!
PSN = lovswr
XBOX Live = lovswr
lovswr is offline
Old 07-08-2008, 02:05 PM
Looks to me like it is a USB based memory unit (proprietary of course). They say that other USB drives "may" work but they cannot guarantee compatibility. Figures sony would not use an SD card, seems kind of dumb to have a usb drive sticking out the back of the player.
Old 07-08-2008, 02:06 PM
Micah008's Avatar
USB flash drive, not Memory Stick. They recommend (not require) a specific one, but I would guess that most would work. They don't say much about sizes it can or can't be... but it would be good to have someone try out some larger ones just to make sure it works.
Micah008 is offline
Old 07-08-2008, 02:13 PM
Pugnax555's Avatar
Again, are you guys reading the same things that I'm reading?
"Insert the external memory device (1GB or larger USB flash memory, such as Sony USM1GH) into the EXT slot as your local storage."
That seems pretty clear to me that it should be a (nonproprietary) standard USB flash drive with a capacity of at least 1GB.
Old 07-08-2008, 02:18 PM
Micah008's Avatar
Correct.
They do say "... we cannot guarantee compatibility with all USB flash memories" So, it would still be good to have someone try out a few to see how well it is supported or if this statement is just a CYA for them.
Micah008 is offline
Old 07-08-2008, 02:25 PM
This might be a cool one to try. I'm sure you could find it cheaper somewhere, but it would minimize the protrusion out the back.
Blu Ray Players , oldest sony blu ray still working , Sony , Sony Bdp S350 1080p Blu Ray Disc Player , sony bdp-s350 , sony blu ray players , unable to get 7.1 sound
