Bluray Player Audio Support Comparison Chart - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #541 of 666 Old 06-17-2009, 10:29 PM
ekb
ekb's Avatar
Isn't the info on the Oppo 83 in the chart in the first post completely wrong? I thought that chart would be kept up to date?
Ed
ekb is offline
post #542 of 666 Old 06-18-2009, 08:04 AM - Thread Starter
adidino's Avatar
Quoted: 322 Post(s)
Liked: 257
SUO - If you're comfortable with the current information on the commuinity chart, I can paste it to post #1
adidino is offline
post #543 of 666 Old 06-23-2009, 11:50 AM
SUOrangeman's Avatar
OK, I'm back ... for now.
The image in the first post of this thread captures the chart as of early March. adidino mentioned the community-drivern version which has two updates in June. So, yes, that live document (GoogleDocs) should be much more accurate. Unfortunately, Google doesn't have a nice "live-preview" that could be easily embedded in the first post of this thread. In the mean time, feel free to take a snapshot of the current file for the first post.
I been thinking about merging the read-only and editable versions of my chart. I've successfully done some similar work for the other GoogleDocs stuff I've got linked in my signature This Blu-Ray chart is just the next file in line. I'd like to get everything on a signle worksheet (HTIBs, standalone players, and BR+TV combos). I just don't yet have a clean instance.
-SUO
AVS files (Charts): GoogleDocs
SUOrangeman is offline
post #544 of 666 Old 07-17-2009, 06:13 PM
jgantert's Avatar
With todays firmware upgrade, you can move the LG BH-200 up to Profile 2.0!
jgantert is offline
post #545 of 666 Old 07-20-2009, 02:04 PM
Done. I also added the two Marantz models that have been announced.
I know, I still have yet to merge the editable and read-only charts into a single document as I offered/promised/suggested months ago. Shame on me.
-SUO
post #546 of 666 Old 07-20-2009, 04:15 PM
WhatHappend's Avatar
The Sherwood 5003 should be changed from complete to Stream for all advanced codecs. The audio output should be changed to 2.0.
This player will only output 2 channel PCM down mix when set to PCM mode and only has 2 channel analog outputs so complete is not appropriate. Only when set to raw mode will it output a PCM 5.1 or PCM 7.1 track as multichannel PCM.
It does have an interesting feature that might warrant a new column in the table. It will re-code any codec to full rate DTS legacy.
TRUEHD 5.1, PCM 5.1, DD+ 5.1 is converted to DTS 5.1 1.536Mbps legacy for older receivers.
WhatHappend is offline
post #547 of 666 Old 07-22-2009, 09:18 AM
Slooshy's Avatar
Yes
Slooshy is offline
post #548 of 666 Old 07-22-2009, 09:51 AM
iontyre's Avatar
Doesn't the Pioneer BDP-320 bitstream DTS-MA? Why is it listed as Decode in the chart? (I have one on the way, so I am interested in this!)
Proud Galactic Imperialist
iontyre is offline
post #549 of 666 Old 07-22-2009, 09:54 AM - Thread Starter
adidino's Avatar
Quoted: 322 Post(s)
Liked: 257
Latest BD Player chart has just been added to post #1.
adidino is offline
post #550 of 666 Old 07-22-2009, 02:39 PM
As adidino's luck would have it, I sat down this afternoon and merged the contents of the read-only chart into the main document. There is now only one Blu-Ray Audio Specs chart! As far as I can tell, I've incorporate the changes listed here from the last few days.
Anyone feel like updating the availability of certain units? Quite a few were listed as Q2-2009 (or earlier). I'm sure that a numberof old units are now discontinued.
-SUO
post #551 of 666 Old 07-22-2009, 03:48 PM
-SUO
For the Sherwood 5003, the HDMI PCM max should still be listed as 7.1, since when set to RAW mode it will send a LPCM 7.1 signal as PCM 7.1 over HDMI.
Otherwise the changes for the Sherwood look good.
post #552 of 666 Old 07-23-2009, 09:58 AM
Sherwood update done on the editable worksheet. Added Samsung HT-BD3252 as well
-SUO
post #553 of 666 Old 07-26-2009, 04:30 PM
gsRt5's Avatar
+ 2 I am also intrested as this is one I am looking at buying.
gsRt5 is offline
post #554 of 666 Old 07-27-2009, 12:01 PM
Poe44's Avatar
Howdy,
Just got the 390 and cant for the life of me successfully set up bit stream to my Pio elite 92. Can anyone tell me the correct setting so My receiver decodes the audio? Not matter what I do i cant gett he Dolby Truhd or DTS master aduio to light up on receiver. No such issues with my panny 60. Thanks!!
Poe44 is offline
post #555 of 666 Old 07-27-2009, 12:01 PM
Poe44's Avatar
Howdy,
Just got the 390 and cant for the life of me successfully set up bit stream to my Pio elite VSX 92. Can anyone tell me the correct setting so My receiver decodes the audio? Not matter what I do i cant get the Dolby Truhd or DTS master audio to light up on receiver. No such issues with my panny 60. Thanks!!
Poe44 is offline
post #556 of 666 Old 08-02-2009, 05:05 AM
rizzlehd's Avatar
+3
Also, doesn't the BDP-51FD decode and stream DTS-HD MA post FW 1.32 update?
I dream in HD
rizzlehd is offline
post #557 of 666 Old 08-03-2009, 09:49 PM
I added the Momitsu BDP-899 to the list of 2.0 SA players. It is the only region free bluray player (just need to enter region free code via remote.)
The FW for this player will load on the Sherwood player and than the Sherwood gains Complete audio decode across the board. But the Profile 2.0 features don't work on the Sherwood due to lack of Ethernet and USB ports.
I hope I edited the chart correctly.
post #558 of 666 Old 08-04-2009, 01:52 PM
WH, those edits look fine to me. It inspired me to look up some 'formerly unknown profile' devices that I've determined are 2.0.
-SUO
post #559 of 666 Old 08-05-2009, 10:58 AM
iontyre's Avatar
So, how about fixing the Pioneer BDP-320? It does not only decode DTS-MA, it bitstreams too. And from what I hear the 51d does too now after a firmware update.
iontyre is offline
post #560 of 666 Old 08-23-2009, 09:17 PM
StevenC56's Avatar
Quoted: 187 Post(s)
Liked: 77
The Analog #Channels for the Denon 3088 are listed as 5.1. Shouldn't that be 7.1? The Marantz 8002 which is a clone shows 7.1.
StevenC56 is offline
post #561 of 666 Old 08-25-2009, 07:29 PM
Can anyone confirm or provide a link?
Anyway, I "archived" the editable chart a day or three ago. Feel free to update the first post accordingly.
-SUO
post #562 of 666 Old 08-27-2009, 12:13 PM
Hewk's Avatar
What does the "F" in "Complete (F)" mean? Available via Firmware?
Hewk is offline
post #563 of 666 Old 08-27-2009, 12:23 PM
Should another PS3 be added to the list? The PS3 Slim?
The PS3 Slim is complete accross the board, it has a different HDMI chipset.
post #564 of 666 Old 08-27-2009, 06:44 PM - Thread Starter
adidino's Avatar
Quoted: 322 Post(s)
Liked: 257
(F) Firmware.. correct.
adidino is offline
post #565 of 666 Old 08-29-2009, 05:45 PM
funwithstereos's Avatar
pioneer 09 decodes hd master audio internaly now, has for a while.
so It should be changed to complete
funwithstereos is offline
post #566 of 666 Old 09-02-2009, 06:29 PM
pdxjazz's Avatar
Op,
No 7.1 or even 5.1 analog output on the new Vizio VBR 100.
pdxjazz is offline
post #567 of 666 Old 09-11-2009, 12:25 PM
iontyre's Avatar
Pioneer BDP-320 still listed as DTS-MA Decode instead of the proper Complete.
iontyre is offline
post #568 of 666 Old 09-15-2009, 06:32 PM
I think I've incorporated the changes mentioned here as well as the announcements from CEDIA.
I'll "archive" the editable version to a read-only worksheet in a week or so.
-SUO
post #569 of 666 Old 09-15-2009, 09:17 PM
StevenC56's Avatar
Quoted: 187 Post(s)
Liked: 77
I must be doing something wrong. I tried to change the Denon 3800 to 7.1 analog using the edit link, however nothing changes on the chart that's on the first page of the thread.
post #570 of 666 Old 09-15-2009, 09:24 PM - Thread Starter
adidino's Avatar
Quoted: 322 Post(s)
Liked: 257
When the chart is up to date, I will post it on post #1
adidino is offline
Reply Blu-ray Players
Panasonic Dmp Bd85k Wifi Enabled Blu Ray Disc Player Black , Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player , Sony Bdp S570 3d Blu Ray Disc Player
