Bluray Player Audio Support Comparison Chart - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #631 of 666 Old 10-11-2010, 02:29 PM
musicmafia's Avatar
this is a great chart!!
ps does anyone know audio support on the panny dmp-bd85k? still not listed on the chart...thanks!
musicmafia is offline
post #632 of 666 Old 10-11-2010, 08:20 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
It does everything - lossless codecs via bitstream and player decoding along with 7.1 analog outputs.
BIslander is offline
post #633 of 666 Old 10-12-2010, 12:39 PM
musicmafia's Avatar
Thanks friend! My set up is 5.1 and receiver is Rotel RSX-1057. I found out too late that the HDMI (v1.1) on this unit carries video only. (From Rotel: RSX-1057, 1067 and any models prior: To decode Dolby True HD and DTS-HD you will need to connect multi-channel analog outputs from your HD Media Player to multi-channel inputs on your Rotel product. This will utilize the internal decoding capabilities of your player allowing you the audible benefits of the lossless codecs).
Since I don't really understand this stuff, is the Panny 85 the best option for my non-hdmi-audio and for possible ugrading in the future? I am not prepared to buy a new receiver so I need to find a player that works best with what I have. Thanks!
post #634 of 666 Old 10-31-2010, 08:16 AM
generallee's Avatar
From what I gather all players hooked HDMI through AV Amps must be PCM and through a HDCP/HDMI port in order to pass a 7-1/5-1 signal so that the AV does the decode process. Since you don't have that function it appears that optical passed from the 85 already decoded would be the choice. I am no expert so if I am wrong...please correct me There is a thread about this on the forum
generallee is offline
post #635 of 666 Old 10-31-2010, 08:30 AM
Kal Rubinson's Avatar
Quoted: 748 Post(s)
Liked: 518
It is really simple. Have the Panny 85 (or any other BR player) set to decode all audio to PCM. That is compatible with HDMI 1.1 and your Rotel will accept both video and audio on that format. From the Ultimate A/V review of the RSX-1057: "There are two HDMI inputs (version 1.1, which means multichannel PCM from Blu-ray and HD DVD players is a go)....." See: http://www.ultimateavmag.com/avreceivers/506rotel1057/
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #636 of 666 Old 11-07-2010, 09:09 AM
Kalt45's Avatar
Hello all. I'm planning to put together a home theater soon on a tight budget and am starting from scratch. I'll be getting an Epson PowerLite Home Cinema 8350 projector with a 100 or 110 inch screen and a 5.1 audio system to be run through a receiver. To keep costs low I want to get a blu-ray player for about $200 or less. I figure at the cost I could buy a better one in about a year without it hurting.
What I would like the player to have is: play basic blu-rays and DVD formats, good upconversion of DVDs, and wifi with apps (Netflix, Pandora, etc). i would fast load speeds put I'm willing to put that aside. I have found some close matches but I think I am missing the DVD upconversion. Any recommendations would be very helpful?
Kalt45 is offline
post #637 of 666 Old 11-09-2010, 01:24 PM
chexi1's Avatar
Quoted: 64 Post(s)
Liked: 115
LG BH200 super multi-blu does NOT have 5.1 analog audio outs. The older BH100 had them, but they dropped them in the 200 series.
chexi1 is offline
post #638 of 666 Old 12-05-2010, 06:17 AM
Ebucel's Avatar
Is this graphic up to date?
Ebucel is offline
post #639 of 666 Old 12-05-2010, 06:27 AM - Thread Starter
adidino's Avatar
Quoted: 354 Post(s)
Liked: 278
It is now.. first post is updated with 12/1 chart
adidino is offline
post #640 of 666 Old 01-06-2011, 06:32 AM
StephaneDufault's Avatar
Hi,
I was not able to find an explenation of the difference between Yes and Ready for 3D, can someone clear this up for me?
StephaneDufault is offline
post #641 of 666 Old 01-09-2011, 01:37 PM
Mantas's Avatar
Does the word "Universal" used in the chart mean that the player is Pal/NTSC? Or am I wrong?
Aside from the Oppo line (as I already have the DV983H), I am looking for sub u$s 300 Pal/NTSC Blu ray player?
And is there any with region codes unblocked?
Mantas is offline
post #642 of 666 Old 01-09-2011, 02:16 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
You're wrong. "Universal" in this chart means that the player will play SACD and DVD-A discs, in addition to BD, DVD, CD, CD-R music discs (and usually mp3 files on a CD-R data disc).
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #643 of 666 Old 01-24-2011, 01:03 PM
avsforumnewbie's Avatar
My receiver, a Yamaha RX-V367, does not have TrueHD and DTS-HD support. I might be in the market to purchase a BluRay player soon. What does this mean for me? Will i not hear any audio because of this?
avsforumnewbie is offline
post #644 of 666 Old 01-24-2011, 01:18 PM
Geaux Tigers's Avatar
If your A/V Receiver has HDMI inputs then you can get a blu-ray player that has internal decoding and it will send the the decoded audio signal to your A/V Receiver and you can get the high resolution audio codecs that way. You can run a toslink cable or coaxial digital cable to your A/V Receiver and still get Dolby Digital and DTS if your receiver has these connections. You can also buy a Blu-ray player that has 5.1 or 7.1 analog outs and connect these to the 5.1 or 7.1 inputs on your A/V Receiver if you have them and get the high resolution audio codecs that way. If your receiver is so old it only has stereo inputs then you can connect the stereo analog connections and get stereo.
What A/V Receiver do you own and what connections do you have?
Geaux Tigers is offline
post #645 of 666 Old 01-24-2011, 01:44 PM
Thanks for the help.
I have a Yamaha RX-V367 receiver. Its the most current model however it lacks the TrueHD and DTS-HD. It does however have four HDMI inputs. I have HDMI and Toslink cables available to use.
Do most BluRay players have TrueHD and DTS-HD decoding? I was planning to purchase a cheap LG BluRay player.
*edit* i just checked and the lowest end LG BluRay player (BD530) has TrueHD and DTS-HD decoding. If most BluRay players have decoding, why do most people prefer a receiver that does it also?
post #646 of 666 Old 01-24-2011, 02:55 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
I don't know if most people prefer it in their receivers. But a player that has it does not need to have 7.1 analog outputs for use with receivers that don't decode those codecs, so the player is cheaper to build.
post #647 of 666 Old 01-24-2011, 03:26 PM
moxie1617's Avatar
With the Yamaha RX-V367 you can not get either Dolby TrueHD or DTS HDMaster. It cannot process either of the lossless codecs over HDMI and it has no multi channel analog inputs should you buy a player that has analog outs. The best you can do is run a coaxial Toslink cable from the LG player to your receiver and you will get the lossy Dolby Digital and DTS tracks. These tracks may be lossy but they are less compressed than tracks found on DVD's and sound quite good. The LG you are interested only has the coaxial audio out, no optical that I could see from the picture on the Yamaha web site.
moxie1617 is online now
post #648 of 666 Old 01-24-2011, 05:02 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
?? I believe the RX-V367 processes PCM over HDMI. So, as long as the player does the decoding, he gets the same lossless audio as he'd get with the receiver doing the decoding.
post #649 of 666 Old 01-24-2011, 05:14 PM
moxie1617's Avatar
When I looked at the specs it appears to be HDMI switching only, no audio processing over HDMI, just a switch.
post #650 of 666 Old 01-24-2011, 08:11 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Here's the product description:
RX-V367 AV Receiver
3D-Ready AV Receiver featuring 1080p-compatible HDMI repeater (4 in/1 out)
SCENE functionality and Upgraded CINEMA DSP.
The manual says it supports up to 8 channels of PCM over HDMI.
post #651 of 666 Old 01-24-2011, 08:16 PM
moxie1617's Avatar
RX-V367 AV Receiver
The HDMI repeater part threw me. I thought it was sales speak for we don't do audio, just video.
post #652 of 666 Old 01-24-2011, 08:34 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Repeater is the good one.
Pass-through and switching are the terms that mean no audio. Or, more accurately, they mean the receiver simply passes both video and audio through to an attached device without processing either of them in any way.
post #653 of 666 Old 01-24-2011, 11:19 PM
Pardon me cause the technical jargon got me lost. So the LG BD530 and Yamaha RX-V367 will work together in regards to TrueHD and DTS-HD if i hook up using HDMI?
post #654 of 666 Old 01-24-2011, 11:40 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes. Have the player do the decoding and send the resulting multichannel PCM to the receiver for processing.
post #655 of 666 Old 01-24-2011, 11:47 PM
You da man!
post #656 of 666 Old 03-15-2011, 04:54 PM
SUOrangeman's Avatar
Is this chart serving any useful purpose any more? I haven't touched it in a while and I know a bunch of players have been announced (or discontinued).
-SUO
AVS files (Charts): GoogleDocs
SUOrangeman is offline
post #657 of 666 Old 03-16-2011, 05:07 AM
rallen's Avatar
Quoted: 12 Post(s)
Yeah, it's getting out of date. Maybe it's time to just have a list of players that don't decode the lossless formats.
rallen is offline
post #658 of 666 Old 04-06-2011, 04:06 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
One helpful feature is the info about which players have 7.1 analog outputs.
post #659 of 666 Old 06-17-2011, 07:42 PM
AdmSpruance's Avatar
Sorry for being a newb. My wife purchased a Sony BDP-S570 for its internet connectivity. According to the chart at the top of this thread the Sony BDP-S570 has no analog outputs. Are analog outputs irrelevant if you are connecting directly to your AVR via HDMI 1.4a output?
AdmSpruance is offline
post #660 of 666 Old 06-17-2011, 07:48 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
You don't need analog outputs if you are connecting with HDMI. Any kind of disc that the 570 handles, including SACD, can have its audio transmitted digitally over HDMI to a receiver that can handle it.
Reply Blu-ray Players
Panasonic Dmp Bd85k Wifi Enabled Blu Ray Disc Player Black , Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player , Sony Bdp S570 3d Blu Ray Disc Player
