LG BD300 BD-Live player with Netflix video streaming support - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 474 Old 01-25-2009, 09:22 AM
aposperp's Avatar
Originally Posted by oaacdi View Post
It only plays music (mp3-no ID3 tag support and wma) and picture (jpg, png) files from a CD-r/RW, DVD+-R/RW, BD-r/RE in ISO 9660+Joliet, UDF and UDF Brigge format discs or from external USB flash or HDD drives (FAT 16 or FAT32, up to 4 partitions). No divx, xvid, avi, vob support.
Doesn't play DivX at all?
Not even from a dvd or USB?
aposperp is offline
post #362 of 474 Old 01-25-2009, 09:24 AM
aposperp's Avatar
How's picture quality with this player?
I 've read some bad reviews in hdtest etc. about video and sound quality.
aposperp is offline
post #363 of 474 Old 01-25-2009, 10:37 AM
oaacdi's Avatar
Nope At least it plays more formats (mp3,wma, jpg, png) than my HD-DVD player, including PAL DVDs plus Netflix streaming
oaacdi is offline
post #364 of 474 Old 01-26-2009, 05:06 PM
Chris Gerhard's Avatar
DVD-V quality is not as good as my other players but Blu-ray quality appears fine to me, both video and audio. I haven't tried Netflix streaming or anything other than DVD-V and Blu-ray. I would like to read some objective reviews of player performance.
Chris
Chris Gerhard is offline
post #365 of 474 Old 01-26-2009, 07:01 PM
Woodshed's Avatar
Quoted: 16 Post(s)
Hello,
I did a quick search but didnt find an answer to this.
Why is it when I set the HDMI to "pass-thru" I can't turn the "DRC" setting off.
This is a bad thing. Anyone have any hints for me please?
Woodshed is offline
post #366 of 474 Old 01-27-2009, 01:45 AM
billt1111's Avatar
How is everyone connecting this player to the internet on their wireless LAN? Are you using a Game Adaptor like the Linksys WGA54G or are you just using a USB wireless adaptor like the Linksys Wireless-G USB Adapter WUSB54G?
bill
billt1111 is offline
post #367 of 474 Old 02-08-2009, 09:49 AM
craigjenh's Avatar
I am using the Belkin F5D7330 wireless gaming adapter to hook up th BD 300 to my network. It was a little squirrely during set up, but now works like a champ. 95% of the HD content streams no problem
craigjenh is offline
post #368 of 474 Old 02-08-2009, 10:20 AM
billt1111's Avatar
I had to give up connecting the player to the Internet using the linksys WGA54G and WGA54AG game adaptors. They just would not connect. I have no idea why. However the player connected immediately with a WGA600N dual band game adaptor. I didn't do anything special. It just worked using DHCP and a static IP. Oh well.
bill
post #369 of 474 Old 02-09-2009, 10:44 AM
hifibitn's Avatar
Originally Posted by sharrowm View Post
I have the same router (Dlink DIR-655) and was experiencing the same problems with my BD-300 connecting to netflix, downloading firmware updates, etc. Basically, it would seem to be connected at times (notifying me that a firmware update was available, show movies in my queue, etc) but would not update firmware or stream movies. LG tech support was no help. In fact, they told me that I had to update the firmware in the unit and that it will not update directly from the internet. They told me that I had to do it via a USB drive and this would fix the problem (it did not fix the problem).
I found this post and I followed the directions above and set up my unit and router for static IP, pointed it directly to my ISP DNS and now it works great! Thanks for posting this oacdi.
Yes, LG's tech support was very uninformed here and for that matter so was NetFlix tech support. This is quite surprising since this has been widely discussed for Roku players and the DLink DIR-655 router using the v1.21 firmware. Quite disappointed in this actually. Anyways, thanks OACDI for this posting as well, I believe it will solve my issues. Oh and FWIW, if you downrev the firmware in your DIR-655 to v1.11, you will have no problems with the LG player (repeating info already in this forum, but it is info worth repeating, esp if folks are uncomfortable with the router settings mentioned above).
Thousands of experiments have conclusively proven that beating drums and clashing cymbals brings back the sun after a total eclipse.
hifibitn is offline
post #370 of 474 Old 02-09-2009, 04:09 PM
Fede84's Avatar
I'm new, from Italy, so excuse my english, i'll want to buy this player but i can't understand one imporatant thing.
If i make a backup copy of one of my blu ray disk on a BD-R or a BD-RE, a copy 1:1, i can see the copy in this player?
Else, for this it's better the Sony BDP-S350 ?
Thx
Fede84 is offline
post #371 of 474 Old 02-09-2009, 04:29 PM
hifibitn's Avatar
I saw a "No" to YouTube support on the BD300, but anyone have any idea if they will enable Amazon streaming? If Roku can do it, not sure why this player can't.
hifibitn is offline
post #372 of 474 Old 02-09-2009, 05:23 PM
oaacdi's Avatar
Glad that my post has been useful to others! I know about the frustration from both LG and Netflix support. At least we have the internet and forums like this one!
Oh, I read somewhere around here that an NTFS HD worked fine, while the manual specifies FAT32. I hooked up my 1 TB USB drive and it had no problem playing the pictures and audio files. Sadly they did not added xvid/divx/mkv support!
oaacdi is offline
post #373 of 474 Old 02-10-2009, 01:59 PM
bdraw's Avatar
Quoted: 169 Post(s)
Liked: 82
When I talked to LG at CES, I asked them about new video streaming for the existing players. They said no, you'll have to upgrade to get the new features. Although they wouldn't admit it, we all know there is no technical reason why they couldn't add it, they just want us to upgrade our players.
Ben
How good could it be if it isn't HD?
No longer contributing to Engadget HD
bdraw is offline
post #374 of 474 Old 02-12-2009, 02:12 PM
samsungmaster's Avatar
You can now stream You Tube with your BD300 with the new software released today. Check your network update to download it.
Life is Good
samsungmaster is offline
post #375 of 474 Old 02-12-2009, 10:46 PM
oaacdi's Avatar
For what it is, the Youtube streaming is nice and fun to have/watch. Guess less hours in the PC but on the TV streaming youtube through BD300!
Will it be close to stream the Pandora service, or something similar?
oaacdi is offline
post #376 of 474 Old 02-13-2009, 07:23 AM
JVs_Dad's Avatar
I downloaded the latest update and tried the Youtube. It's pretty cool, not something I'll be watching all the time but still cool. I watched the Letterman/Pheonix train wreck interview and the picture and sound is pretty much what you'd think. Now all we need is Hulu integrated, that would be grand.
JVs_Dad is offline
post #377 of 474 Old 02-13-2009, 08:16 PM
eyager's Avatar
The ability to watch youtube with the firmware update was a bit of a surprise to me. I can't say its really all that useful or an essential feature. Is there a way to queue up youtube vids you want to watch via an external computer as is the case with netflix? Are you just stuck watching the vids youtube preselects for you?
The feature I would like to see is a media server app for your PC that will let your BD300 play divx movies/mp3s off your hard drive. The media server app would have to transcode divx movies on the fly to a format the BD300 can handle with its hardware decoders as Hauppauge did with the Media MVP. If LG had enough free space in the BD300's flash rom to add youtube capabilties, then they can also add LAN based streaming if they wanted. The problem is there is no corporate bribery *erm* "media partnership" to compel them to add such a feature.
Maybe someone could reverse engineer the protocol the BD300 uses to talk to youtube, set up a PC to emulate a youtube server and use that as a way to get the BD-300 to stream whatever video file of their choosing. It would be a complicated backdoor method that most programmers would choose not to tackle but its entirely possible to do provided youtube isn't using any encryption.
eyager is offline
post #378 of 474 Old 02-14-2009, 07:55 AM
oaacdi's Avatar
No, there is the search function, and you can connect to international versions of youtube as well.
Other units can do this through TVersity. Maybe the BD300 can be twicked to be recognized by this server?
oaacdi is offline
post #379 of 474 Old 02-15-2009, 05:01 AM
XBR23's Avatar
thanks for posting, i downloaded the update and installed with no issues.
XBR23 is offline
post #380 of 474 Old 02-15-2009, 09:13 PM
tji
tji's Avatar
I went to my local Fry's Electronics to pick up a BD300 today, and was told that it was discontinued and they didn't have any more.
Is this true? If so, is there a replacement?
tji is offline
post #381 of 474 Old 02-16-2009, 04:25 AM
The BD390 with wireless internet built in is the next model, not sure when it will be in stores.
Chris
post #382 of 474 Old 02-18-2009, 10:43 AM
tennisplay's Avatar
I got this player recently and have been satisfied so far. I set it up using a Linksys WRT54G router flashed with dd-wrt to act as a wireless bridge.
The Netflix streaming content was good, but I would have liked it more if it had captions. Not sure when Netflix is going to add that feature.
The YouTube access is also nice, but it would be great if other sites such as Hulu were also supported.
If there is a working hack to support multi-region, please let me know.
tennisplay is offline
post #383 of 474 Old 02-18-2009, 05:25 PM
vinylprimate's Avatar
I've had the BD300 since the middle of November and have been pleased with it until recently. About two weeks ago I began noticing that anything I viewed, whether it was Netflix, YouTube, or DVDs, the video and sound was not in sync. There is nothing worse than lips moving and the sound coming later. I brought this too LG's attention, and they want me to pay $69 for a diagnostic fee. That stinks. I paid like $300 for this box. I would expect it to work longer than 3 months.
Is it possible that there is something else amiss? My HDMI cable or TV?
vinylprimate is offline
post #384 of 474 Old 02-19-2009, 11:32 PM
ian67's Avatar
I just bought a display model LG BD300 at Circuit City was told it worked fine (my mistake for not making them plug it in and prove it, stupid I know), got it home plugged it in and when i put a disc in I get a NO DISC reading. Tried a couple different discs, same problem. The disc doesn't even spin. Put a disc in upside down, and it spins then says error reading disc.
ian67 is offline
post #385 of 474 Old 02-20-2009, 04:24 AM
Same exact thing happened to me with a Samsung BD-UP5000. I had to send mine to Samsung for warranty repair at my expense for shipping. No returns are accepted according to all signs I saw at my local Circuit City and the written terms on your receipt probably override any verbal guarantee of a working player. I would say try to return it with the explanation that you were told it was working which I expect will get the response that it was working when they checked but you will have to deal with LG since it is no longer working. LG should be able to repair the player but my guess is you will have to ship it to LG.
Chris
post #386 of 474 Old 02-20-2009, 05:51 AM
I have the WRT54G and would like to be able to use it with my BD300. How do I flash the WRT54G with dd-wrt?
Chris
post #387 of 474 Old 02-20-2009, 12:25 PM
tennisplay's Avatar
I used the instructions on the web page below to flash my wrt54g router with dd-wrt. It is specific for v8.
http://www.dd-wrt.com/wiki/index.php...h_the_WRT54Gv8
Specific instructions for other versions are also available on the same website. You may have to dig through this page to find the right one:
http://www.dd-wrt.com/wiki/index.php...GX#v7.2_and_v8
It is important to follow the instructions verbatim, including the wait times, otherwise, you may end up bricking the router. There are ways to get around this as well, though.
I used the instructions here to configure the router as a wireless bridge:
http://www.dd-wrt.com/wiki/index.php...Bridge#Example
Hope this helps.
post #388 of 474 Old 02-21-2009, 12:18 PM
Hope this helps.
Thanks guys, I am not much with a wireless network and the instructions to get dd-wrt working were a bit overwhelming so I went to Circuit City and purchased a WGA600N adapter and it set up like a charm and finally I don't have to walk my 50ft ethernet cable to get connected. I guess I will see if there are any issues with speed and connection quality but so far it seems to work great.
Chris
post #389 of 474 Old 03-03-2009, 06:34 AM
bradavon's Avatar
The BD370 is a slight upgrade from the BD300, I would wait on the BD390 which will have wireless capabilites and DLNA. There will also be several home theater systems coming out that will have netflix/youtube/pandora if those are of interest to you.
I wish LG would release some bloody BD Players outside of North America. All we got is the BH100 (properly) and BH200 (on extremely limited, barely non-existent). We've never got the BD300 at all, even with Netflix or removed or something else added. It seems they've given up on the rest of the world (maybe Europe) entirely. The BH200 could've definitely sold well enough here, if given a chance.
What's the quality like? Youtube is so low quality, surely it looks awful?
bradavon is offline
post #390 of 474 Old 03-08-2009, 07:38 PM
Tom Negrino's Avatar
"Awful" is a relative term. The YouTube videos normally appear embedded in an interface, so they don't take up your whole screen; perhaps a quarter of the TV screen is used by the video.
Given that it is being upscaled, it's actually not so bad. I would certainly not say that it is anything close to HD, but for what it is -- Internet-quality Flash video being streamed -- it is acceptable. YouTube is not a "serious" viewing experience anyway. But I've enjoyed using the streaming with the BD300 to view a bunch of rare music clips of some favorite performers. Sure, I can do that on my computer, but I've got lots better speakers in the living room.
Tom Negrino is offline
Reply Blu-ray Players
Lg Bd300 Network Blu Ray Disc Player
