Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 1025 - AVS Forum
post #30721 of 30733 Old 05-24-2014, 01:51 PM
vlach's Avatar
Originally Posted by stanger89 View Post
My (likely incorrect) recollection is that the S/PDIF connection only officially supports up to 20/48kHz, anything beyond that is a non-standard implementation that may or may not work.
Yes, DTS 24/96 is a lossy compressed bitstream, so it's still within the bandwidth of S/PDIF, it works just like DD/DTS.
24/96 when lossy...duh...totally makes sense, and i knew that but somehow forgot...thanks for the reminder smile.gif
vlach is offline
post #30722 of 30733 Old 05-24-2014, 03:25 PM
BIslander's Avatar
Quoted: 47 Post(s)
Liked: 125
I believe that support for 96/24 over S/PDIF depends on the specific equipment being used. My Denon 2900 player outputs stereo PCM at 96/24 over S/PDIF, but my Panasonic BD player does not. DTS 96/24 is a different matter since the player is just a transport sending whatever is in the DTS package for decoding and processing by a receiver.
BIslander is offline
post #30723 of 30733 Old 05-27-2014, 04:25 PM
Mkard's Avatar
Hmm. So will Pioneer be able to internally convert full spectrum audio with no loss of density, and then output via Analogs in the case at hand?
Mostly idle curiosity.
Mkard is offline
post #30724 of 30733 Old 05-27-2014, 06:26 PM
BIslander's Avatar
Quoted: 47 Post(s)
Liked: 125
Probably, although it may depend on what DSPs are engaged.
post #30725 of 30733 Old 05-28-2014, 11:47 PM
vlach's Avatar
Thanks for the feedback Bislander. I'm starting to believe this limitation does indeed vary from player to player as opposed to having anything to do with the S/PDIF format itself. I've had no issues whatsoever with my 51FD after 6 years of ownership and swore i would hang on to it until it would just die, however i now have an additional reason (besides slow loading speed, no ethernet connectivity) to switch to Oppo. I want the ability to pass 2 channel of uncompressed PCM at 24/96 & 24/192 to my DAC. SACD & DVD-Audio playback is just icing on the cake.
vlach is offline
post #30726 of 30733 Old 06-03-2014, 06:23 AM
kemitchell's Avatar
This is precisely why I still have my old reliable Oppo DV-981HD in my setup along with my 51FD. wink.gif
~kyle
kemitchell is offline
post #30727 of 30733 Old 07-05-2014, 10:02 PM
Liked: 0
OK, seriously hoping someone can help me here.
I have a BDP-51FD connected by HDMI to a VSX-919AH.
I can not get PQLS to function no matter what I try.
Tried disconnecting all other units (including TV), numerous hard re-starts of both units.
Tried updating firmware to latest versions on both units. (1.74 on BDP and StM 1056 for the AVR)
I have checked all Kuro settings on both units and verified the sound fields are appropriate for 2 channel PQLS playback.
At wits end, any and all suggestions appreciated.
pitfa17 is offline
post #30728 of 30733 Old 07-15-2014, 08:19 PM
johnchabin's Avatar
Anyone have trouble playing LOTR Extended Edition? I can play other Blu-Ray titles, just not this one. The disks are brand new.
I am at FW 1.74.
johnchabin is offline
post #30729 of 30733 Old 07-16-2014, 08:57 AM
johnchabin's Avatar
Update: Got another CAN'T PLAY on a different disk. Blew the player out with clean compressed air and it seems to be ok now.
post #30730 of 30733 Old 08-01-2014, 07:01 AM
kemitchell's Avatar
I am at FW 1.74.
I have all three extended editions and have watched them several times on my 51FD, never had a single issue.
~kyle
post #30731 of 30733 Old 08-06-2014, 01:37 PM
Xtempo's Avatar
I was watching Alantis and not far into the movie the player locks onto the video. near the end of the movie it pauses. I have to unplug it to turn it off and brefily it works normal/.
I have never had this problem with the BDP51FD before. Does it sound like the disc is bad or is the player dying?
Xtempo is offline
post #30732 of 30733 Old 08-10-2014, 05:15 AM
Rick R's Avatar
Sounds like the disc, would not play through otherwise. Make sure there is no dust on the disc, blow it off with compressed air from about a foot away. Similarly as an earlier poster has done it might help to blow out the drive with compressed air. In both cases make sure the can has not been shaken and blow a short burst away from the disc/tray aperture to get rid of any residue. With blowing out the drive I find it best to fit the tube nozzle and with the tray open insert the nozzle through the tray aperture from underneath, this will make sure only a burst of air goes in and not liquid. Hope this helps
Rick R is offline
post #30733 of 30733 Old Today, 05:17 PM
Liked: 0
I've got a BDP-05FD that was picked up cheap. It was a 50/50 chance if it would play a disc or not. I simply opened it up and cleaned the lense with a qtip and 91% isopropyl alcohol, I really didn't have much to lose. Wet one end of the qtip and wiped then dried it with the other. Had to remove the lable and black cover on the drive, they stuck right back no problem, then the little white wheel lifted right out. I also had to pick up a remote just to get it going, got one for another model (VXX3316) and it worked fine.
So far it has played every disc I've put in. Fingers crossed.
BeatnikV is online now
Reply Blu-ray Players
Excellent Pioneer Bdp 05fd Blu Ray Player , Pioneer Bdp 51fd Bonusview Blu Ray Player , Blu Ray Players
User Tag List
